| H16 assembly problem...help! #52593 07/07/05 11:19 AM 07/07/05 11:19 AM |
Joined: Apr 2005 Posts: 292 Ontario, Canada Captain_Dave OP
Posts: 292 Ontario, Canada | I am assembling a 1977 H16 for my first time. I have the manual from Hobie, but the photo quality is poor. My problem involves the orientation of the side-rails. The manual seems (?) to suggest the "flared" portion (where the tramp inserts) should be towards the front of the boat. But this does not make sense to me. I think it may be better with the flared opening in the side-rail towards the back of the boat. I have tried it (un-laced) in both positions. Can someone set me straight here? Which way should it go ...and WHY? I don`t want to lace her up and have to re-do it again. Dave | | | Re: H16 assembly problem...help!
[Re: Captain_Dave]
#52594 07/07/05 11:36 AM 07/07/05 11:36 AM |
Posts: 123 Syracuse, NY | Here's a manual - it may be the one you have: http://www.hobiecat.com/support/pdfs/H16_Manual.pdf The flared ends of the rails go to the front - the grommets on the tramp go to the back. Lacing goes down the center and along the back. I have seen it the other way but that is unusual. Why? I guess this gives you more tramp in the front where the crew sits. Usually - you will find skipper and crew forward more than back on a 16 (unless it's blowin like snot). better tramp pic Good Luck RQ
[Re: deq204]
#52595 07/07/05 01:34 PM 07/07/05 01:34 PM |
Posts: 152 Central Texas | Hmmm, If I understand the situation right he is not planning on having the lacing on the front crossbar rather than on the rear. I think he is asking why the flared part of the side bar is facing towards the front of the boat. Actually this is a good question - something I assumed was not properly assembled on my boat. When I research the issue I learned that Hobie installed the sidebars in this manner because they were concerned that a sailor could suffer an injury by inserting a finger in the widened part of the side rail if it would be left exposed in the rear. When I installed my new tramp I decided to disregard these concerns - Now my sidebars have the widened part in the rear while the front of the tramp is nicely supported in the extrusion. In order to avoid injury I inserted a piece of PVC hose that covers the flared area of the sidebar. Tapeing over the flared area would do the job as well. I will post some pics of my tramp … it is kind of a different approach to the one pice tramp (highly class illegal).  Patrick
Patrick, Hobie 16 '85
[Re: yoh]
#52596 07/07/05 01:52 PM 07/07/05 01:52 PM |
Posts: 292 Ontario, Canada | Patrick,
You definitely "hit the nail on the head" and answered my question. You obviously had the same concern as to why the front/lateral corners of the tramp are clearly left unsupported when one follows the manual. But the real question is "why" and I believe you have answered that as well.
From a mechanical standpoint it seems the "open" or flared part of the sidebar is best to the rear(stern)- contrary to the manual. But for safey reasons, it is best toward the front(bow) - in accordance with the manual.
I will place it to the rear, just as you have, and plug/block the flared opening to protect fingers...Unless someone else can share a different view on this.
Thanks a lot,
Dave
[Re: aaronhoy]
#52600 07/08/05 01:25 PM 07/08/05 01:25 PM |
Posts: 152 Central Texas | Dave ... read Jim's posting again... he stated that the flared part in the front makes it more likely that the tramp would come out of the sidebar...
O.K. If you go with one of those "one pice bias cut tramps" than you would have to keep the flared part in the front to mount and remove the tramp - or you would have to remove the rear cross bar from the hulls and sidebars. (this is what I do for my version of the one pice)
Patrick
[Re: yoh]
#52602 07/08/05 01:41 PM 07/08/05 01:41 PM |
I just re-read Jaime`s post and I think you have misquoted him (although my brain is giving me trouble today, so perhaps I`m the really confused one). Jaime said:
"Over time, if the flared part is to the rear, the tramp is more likely to pull out of the crossbars than if the flared part is to the front".
It seems to me, this is opposite to what you are saying. Am I correct? Or...well...having troubles!!
Aaronhoy and HRT
I am fairly certain you are not really seeing the point here. Re-check the posts and look at your boat - the back (stern) portion gets no less or extra support with either setup. Only the front and lateral portion is affected.
Dave
[Re: JaimeZX]
#52607 07/08/05 03:46 PM 07/08/05 03:46 PM |
Posts: 292 Ontario, Canada | Howard,
I think you have it now. Yes, when the side-rails are reversed (flared opening to stern) the trampoline is unaffected by the opening because neither extends far enough to contact each other. The advantage to this arrangement seems to be that the front part of the tramp now gets full support where it did not previously (according to the manual). However, your point is well made insofar that there is little force on the tramp up front anyway...regardless of the setup. My feeling is, if it makes no difference at the stern either way (safety issue notwithstanding), then why not orient the siderails so as to give that extra support up front. The "holding" problem Jaime is referring to is obviously a real concern, but a separate one altogether, as it is not caused, or solved by the orientation of those side-rails. Perhaps Jaime has a different tramp. But the one I have could not possibly pull out of the flared opening if the opening is oriented to the rear of the boat(contrary to the manual). The tramp simply does not extend far enough back to even touch that opening.
...I actually never thought this issue would become so verbose. I just thought I had it wrong. I appreciate the input from everybody.
Dave
2,423
guests, and 262
