| Re: Sorry to hear it too ...
[Re: Robi]
#52894 07/12/05 08:20 AM 07/12/05 08:20 AM |
Posts: 552 | Robi, 1. Ouch!........ugly for sure!...........but not that bad of a fix. 2. We would just repair it,...like you said, part of the fun. Heck, when you travel to regattas, 'bites' like that are common,..and you have to fix them on the beach that night,....so to be ready to race the next morning. 3. However, ..if the builder is a truck ride away,...by all means go there,.....it will be a perfect job.. 4. Why did you not dissassemble the hulls and pull them in your living room?......you pull everything else in there..:-)  ,.......heck, you could rest your feet up on them as you watch TV... Bruce I-17 St. Croix ( by way of Tampa) | | | Re: Need suggestions
[Re: Darryl_Barrett]
#52895 07/12/05 09:16 AM 07/12/05 09:16 AM |
Posts: 122 | Just one small recommendation, don't use epoxy resin, the hulls are, I believe laid up with vynalester resin for the blade, so do the repair with vynalester resin and finish with polyester gelcoat, that way there is complete compatibility between materials. I have to respectfully disagree with this recommendation. There is no compatibality issue between epoxy and CURED polyester or vinylester resins. The Cte between the three is close enough to be inconsequential. The most important property for a repair resin is adhesion and epoxies have unquestionably superior adhesion to the other two types for at least two reasons: 1) uncured epoxy resin hass far lower surface tension (it is 'wetter', like comparing soapy water to pure water)and 2)epoxies are solvent-free resin systems. Vinyl and polyester resins both depend on the solvent styrene(vinylbenzene) to reduuce viscosity to a usable level. This is a 'reactive' solvent which means some of it becomes part of the cured resin. But not all of it does so. The part that does not evaporates shortly after the resin transitions to a solid. The loss of this free solvent ALWAYS results in significant shrinkage of the cured mass thus reducing adhesion further. Look at the shrinkage numbers for epoxies vs vinyl/polyesters and you will see something like 10X more shrinkage compared to epoxy. Shrinkage is not necessarily a bad thing in production; it helps de-mold the part. The lighter viscosity, faster processing times and cheaper price for vinyl/polyester makes them the right choice in production,especially since the advent of resin infusion. But repairing and manufacturing are definitely different games. For repairs 'stick' with epoxy  Jimbo | | | Re: Need suggestions
[Re: Jimbo]
#52896 07/12/05 09:57 AM 07/12/05 09:57 AM |
Posts: 12,310 South Carolina | I agree and typically use epoxy for repairing any composite structure. However, if you choose to finish the repair with gelcoat, you may have an issue getting it to adhere well to the epoxy.
Jake Kohl | | | Re: Need suggestions
[Re: Jimbo]
#52897 07/12/05 11:45 AM 07/12/05 11:45 AM |
Joined: Aug 2001 Posts: 190 Long Island, NY Steven Bellavia
Posts: 190 Long Island, NY | Hi I have to vehemently disagree with Jimbo's suggestion of using aluminum as the backing plate. Use a piece of 1/32" (.031") thick G10/FR4 (this is a fiberglass-epoxy composite already cured). The aluminum will rot away (unless it is anodized first), very tricky to get a good bond, and is twice as heavy and stiff as the G10 - which more closely matches the resin/cloth your boat is built with. For 1/32" G10 go to McMaster.com PN:8667K111 (6" x 6" for $2) or 8667K51 (12" x 12" for $3.95). Otherwise all the other advice seems correct. Also, a great source for quality cloth is: www.uscomposites.com. I highly recommend using the 4 oz 6oz S-glass. I've done over 100 fiberglass repairs on foam cored boats, etc. E-mail me directly if you need more info. Steven Bellavia Hobie FX-1, Sail # 211
#52902 07/12/05 11:37 PM 07/12/05 11:37 PM |
Posts: 606 League City, TX | How on earth do you equate my previous post to something as far out as, epoxy with vynalester will be vulnerable to galvanic corrosion errr... you used a comparison to repairing aluminum with stainless and suffering electrolysis (galvanic corrosion) to make some kind of point about not using epoxy to repair a vinyl ester construction hull. My flippancy was a polite way of highlighting your comparison was bull. As is your statement that using the same materials as original construction is always "logical". I thought you could put gel coat over epoxy repairs if you remove the amine blush? Not that you'd want to thought - Awlgrip paint or similar can be simpler and quicker than using gel coat - as a professional boat builder and repairer once told me... | | | Gilligan's Run
#52906 07/13/05 06:42 AM 07/13/05 06:42 AM |
Joined: Dec 2003 Posts: 1,066 Wellington, FL-Singer Island, ... cyberspeed
Posts: 1,066 Wellington, FL-Singer Island, ... | Hi Robi, I saw you were registered for Gilligan's Run, are you still going. One solution would be to stop at Vector on the way up and have them do a fix on it and drop it off on the way back home to have them make it look pretty. It was great meeting you at the Delray and was looking forward to sailing against you this weekend on your new sled. | | | Re: Need suggestions
#52907 07/13/05 07:59 AM 07/13/05 07:59 AM |
Posts: 12,310 South Carolina | It's obvious that what you don't know about boat building and boat repairs would fill ten thousand volumes Flump, and what you think that you do know is dangerous advice for unsuspecting others. Your manners are in a similar state I'm sorry to say. Woaaahh Darryl...chill - sam's not in on this thread yet. What the flump is saying is well documented. Epoxy adheres better to cured ester resins that ester resins but ester resins adhere to epoxy even less. In this case, I agree that the difference is negligable as it applies to the repair area and that if gel coat will be the end finish method that the same vinylester or polyester resin should be used.
Jake Kohl | | | Re: Gilligan's Run
[Re: cyberspeed]
#52909 07/13/05 10:17 AM 07/13/05 10:17 AM |
Joined: Jul 2004 Posts: 2,718 St Petersburg FL Robi OP
Posts: 2,718 St Petersburg FL | Hi Robi, I saw you were registered for Gilligan's Run, are you still going. One solution would be to stop at Vector on the way up and have them do a fix on it and drop it off on the way back home to have them make it look pretty. It was great meeting you at the Delray and was looking forward to sailing against you this weekend on your new sled. Nah cant make it out. I prefer to sail the boat intact than with masking tape. Dunno its just the way I am. Thanks for the invite though. Awesome door idea BTW!!  Talked to a local beachcat guru, we are going to repair it. Should be done in the next couple of weeks. | | |
20,217
guests, and 543
