When do you put the Main Sail Up? #52919
07/10/05 10:52 PM
07/10/05 10:52 PM
Jeremy Offline OP
Jeremy  Offline OP
So i don't really know when to put the sail up and when to take it down. Should i put the sail up while still on the trailer or should i wait till i get on the water?
Re: When do you put the Main Sail Up? [Re: Jeremy] #52920
07/11/05 02:34 AM
07/11/05 02:34 AM
West Texas
JaimeZX Offline
JaimeZX  Offline
West Texas
If you can pull the boat up on a beach, that's probably the easiest time to do it; but I've done it on the trailer, on the beach, on teh dock, and floating in the lake. It's definately hardest to do it when you're in water over your head. ;-) It's easiest when the boat is stable and pointed into the wind; whether that's on the beach or on the trailer.
Warm regards, Jim
Re: When do you put the Main Sail Up? [Re: JaimeZX] #52921
07/11/05 08:16 AM
07/11/05 08:16 AM
Saint Simons Island, GA
aaronhoy Offline
aaronhoy  Offline
Yeah, it can be really anoying trying to put it up OR down if you're not facing into the wind. Where I sail, everyone wheels their boat down to the beach and puts it just barely in the water to its still sitting stable on the ground but you can easily pull it into the water. Then you rig everything up and then give the boat a little shove into the water when a wave is comming and off you go. More annoying than the main though is the jib. No matter what direction you're facing it flaps and thrashes violently if there is any good wind when you're trying to take it down. I've just learned to deal with it, but my friend has a roller jib and he hoists it up in the boatyard where it's less windy and then rolls it in to wheel the boat down to the beach. Then once he's there he can rig everythign and just pull the jib back out and he's ready to go.
Re: When do you put the Main Sail Up? [Re: aaronhoy] #52922
07/11/05 08:36 AM
07/11/05 08:36 AM
North Carolina
hrtsailor Offline
hrtsailor  Offline
North Carolina
Most of my sailing is on a lake. I never put the sails up until I launch the boat and pull it up on shore facing into the wind. Don't put the sails up on the trailer.
Howard
Re: When do you put the Main Sail Up? [Re: hrtsailor] #52923
07/11/05 08:48 AM
07/11/05 08:48 AM
Jeremy Offline OP
Jeremy  Offline OP
Thanks for all your help guys!
0 registered members (), 2,530 guests, and 406 spiders.
