EPO rudders in old-style H18 castings #53400
07/17/05 07:17 PM
07/17/05 07:17 PM
SF. Bay Area
mwr Offline OP
mwr  Offline OP
SF. Bay Area
I have an older(1977) Hobie 18. Well, at least the rudder system, which is just about all that is left of the original boat is 1977. I got a great deal on a set of EPO rudders to replace the reeally bendy black plastic ones that I have.
The problem is, they don't fit! The castings, both upper and lower, have these molded-in bushings that limit the space for the head of the rudders. I sanded the ruders, but I am getting to the glass and can't go any thinner, so I am left with having to modify the castings. Any ideas other than grinding the heck out them? And what should I use to do the grinding?
Michael Rossney West Oakland, Ca. H-18
Re: EPO rudders in old-style H18 castings [Re: mwr] #53401
07/17/05 08:49 PM
07/17/05 08:49 PM
Westport, Ma. U.S.A.
Brian_Mc Offline
Brian_Mc  Offline
I don't know what the answer is, but you might try posting on the Hobie Forum: www.hobiecat.com/community/index.php , and the Beachcats Yahoo forum/list. You can find the link at www.thebeachcats.com . Good luck!
Re: EPO rudders in old-style H18 castings [Re: Brian_Mc] #53402
07/17/05 09:56 PM
07/17/05 09:56 PM
Newport, RI
wildtsail Offline
wildtsail  Offline
Newport, RI
When I had my 82 18 mine were too wide for the castings as well. I sanded them down alot and bent the rudder casting out a just tiny bit. They eventually fit, it was tight but they fit and the tight fit eliminated all slop.
Good luck, just keep sanding away.
-Todd
Re: EPO rudders in old-style H18 castings [Re: wildtsail] #53403
07/18/05 05:01 PM
07/18/05 05:01 PM
catman Offline
catman  Offline
I had the same set up and problems. I sanded the hell out of the blade tops and used a angle grinder on the casting cleaning that up with a flat file. Keep at it.
0 registered members (), 2,652 guests, and 166 spiders.
