Re: nacra 5.5 uni - definitely want to add a jib [Re: Steven Bellavia] #54557
08/05/05 12:59 PM
08/05/05 12:59 PM
Salt Lake City, UT
utahsailor Offline OP
Salt Lake City, UT
Steve, you make a good point. The more I think about it, it's questionable what difference the jib would make upwind - the uni is already a very fast boat. If I had to stab a guess, the crew weight (~360 lbs) and the fact that my fiancee likes to sit smack in the middle of the tramp despite my efforts to balance the weight onto a single hull, have a lot more to do with speed than any lack of sail area!
Tacking/turning is remarkably easy with the 5.5u, at least in comparison to the hobie 14 and my sunfish.
Where did you find the boomless spinnaker? If you see it again, do let me know! It sounds like it would be faster to rig, and perhaps easier to use also?
Re: nacra 5.5 uni - definitely want to add a jib [Re: utahsailor] #54558
08/05/05 02:01 PM
08/05/05 02:01 PM
Salt Lake City, UT
Salt Lake City, UT
Another question - completely off topic.
I found the pole that should be used to right the catamaran (attached to the underside).
Where should I store this when I'm sailing?
Re: nacra 5.5 uni - definitely want to add a jib [Re: Steven Bellavia] #54559
08/06/05 12:53 AM
08/06/05 12:53 AM
Central California
ejpoulsen Offline
ejpoulsen  Offline
Central California
I was wondering if anyone has messed around with a pole-less spinnaker
Yes--Kirt Simmons, who posts under a variety of different user IDs, including "Kirt" and "Arsailor"--he has been testing a pole-less spinnaker on his Taipan. There was a thread about it way back on the F16 forum with photos.
Eric Poulsen
A-class USA 203
Ultimate 20
Central California
Re: nacra 5.5 uni [Re: utahsailor] #54560
08/06/05 07:15 AM
08/06/05 07:15 AM
Gulf Coast
tami Offline
tami  Offline
Gulf Coast
Don't add a jib.
First, it will compromise your upwind performance, as jibs are useful really only for reaching. A jib, upwind, creates more drag than lift and you can't point as high. The sail area isn't enough to be really useful sailing deep downwind. That's why all these people add chutes.
If you note, a lot of the 'hot' new designs are going with the unirig configuration with a chute. Best of both worlds. Reference Marstrom 20, I-17, Javelin, etc.
As for your under-trampoline pole, that's a 'righting pole' and you stow it by drawing the pole up under the tramp and bungee-ing the pole somewhere on the aft crossbar.
Re: nacra 5.5 uni [Re: tami] #54561
08/06/05 08:40 AM
08/06/05 08:40 AM
Panama City, Florida
Redtwin Offline
Redtwin  Offline
Tami,
I did a search in the F-16 discussion for "poleless" and it came up with nothing. I made sure I was searching all posts. Could it be in another discussion? I'd really like to see some pictures of that setup.
-Rob V.
Panama City
Rob V. Nacra 5.2 Panama City
Re: Spinnaker tacked off bow bridle- [Re: ejpoulsen] #54562
08/06/05 11:35 AM
08/06/05 11:35 AM
Arkansas, USA
Arsailor Offline
Arsailor  Offline
Arkansas, USA
Here's my post-
web page
I had Goodall make a spi just for this purpose but unfortunately they cut the luff too long so I'm still dealing with that-
Another option for "turbocharging" a uni is to just add a roller furling jib- If it gets really light air, your crew weight goes up, or whenever you go downwind it helps a lot IMO.
Kirt
Kirt
Taipan 4.9 USA 159, Flyer USA 185
Will sail for food...
0 registered members (), 2,858 guests, and 353 spiders.
Yesterday at 10:10 AM
