| Mast Pin #54722 08/07/05 12:52 PM 08/07/05 12:52 PM |
Posts: 106 NW Washington | Great sailing weather for me today. Unfortunately, I got as far as the boat launch when I realized I didn't have my mast pin for my Nacra 450. So I came home :-( Can't find it anywhere and don't know what size it is, but I found a long shank padlock that fits not quite snuggly. Don't think I'll try that.
Anyway, I thought the mast hinge pin was a safety feature that prevented the mast from coming off the ball. But after doing a search on this site, I've seen mention of leaving it off when sailing. So what's its purpose? I don't want to head out if it's supposed to be on.
Next question is what size is it?
Danno
| | | Re: Mast Pin
[Re: Rolf_Nilsen]
#54724 08/07/05 01:15 PM 08/07/05 01:15 PM |
Posts: 106 NW Washington | That makes sense, Rolf, thanks :-)
I also found that it's a 1/4 x 2" shaft. And I found a 1/4" x 2.5" bolt. Even has a hole drilled in the shank, but looks like it's not needed now.
Had I not lost it originally, wouldn't have learned this. One way to learn, I guess.
Danno
| | | Re: Mast Pin
[Re: utahsailor]
#54727 08/07/05 11:57 PM 08/07/05 11:57 PM |
Joined: Jun 2004 Posts: 141 Panama City Beach, FL steveh
Posts: 141 Panama City Beach, FL | But on my Nacra, the pin only seems to hold the mast to the ball bearing, without controlling direction. Unfortunately this doesn't do any good whatsoever. One time we dropped the mast while raising it; the force was so great that it removed the mast from the ball and shattered the pin! (amazingly, the mast and the ball were both unharmed).
I worked out a couple of short lines with a loop on one end that hooks over the crew trap handle and a clip on the other that clips onto the barberhauler attachment loops that are clamped under the main beam clamps. Even if you don't have a barberhauler, you could add the loops for this purpose. The trap lines then keep the mast from swaying side to side from lowered to raised position. Don't make them too tight. You'll need several inches of slop to get them clipped on with the mast rotated and they need some slack to get the clip unclipped. Even with a little slop, the mast will only sway side to side a few inches. Works great for lowering in a cross breeze. | | | Re: Mast Pin
[Re: steveh]
#54728 08/08/05 07:39 AM 08/08/05 07:39 AM |
Posts: 12,310 South Carolina | None of the mast step pins are designed to keep the mast in column while raising. The Hobie pins and plates are nice in that the mast can be pointed straight forward instead of rotated 90 degrees but are not strong enough to keep the mast from going side to side either. I had a 5.2 that didn't originally have a captive system for keeping the mast base on the ball during stepping and it was a PITA.
The reason that we remove the pin while sailing is a safety thing. Imagine that a shroud or forestay were to fail and the mast came down. If the pin was in the mast base, you've just built a 26' nut cracker - and you're the nut. If the mast base is free the rig comes down rather gently and slowly (not that I've experienced this personally, but I've seen it happen) without damaging anything.
Jake Kohl | | |
3,591
guests, and 847
