Spreader Rake #55429
08/17/05 09:20 PM
08/17/05 09:20 PM
Tn
JACKJACK Offline OP
JACKJACK  Offline OP
Tn
How do you determine the ideal spreader rake for a rig? I have a P-19 with older Smyth dacron sails(soft rig), crew weight of about 310 lbs, and need to know the what spreader rake to use. On the water, what can I look for to determine this?
Jack
Re: Spreader Rake [Re: JACKJACK] #55430
08/18/05 08:50 AM
08/18/05 08:50 AM
Andrew Offline
Andrew  Offline
If someone doesn't answer this for you, I'll look it up in my factory manual tonight. Good luck.
Re: Spreader Rake [Re: Andrew] #55431
08/18/05 02:44 PM
08/18/05 02:44 PM
Tn
JACKJACK Offline OP
JACKJACK  Offline OP
Tn
Thanks for the reply Andrew. My problem is that the old manual reccomends a 1-1/2 inch spreader rake for the Prindle 18,18-2,and 19. Big difference in boats. Second, dacron sails get fuller as they age (opposite of mylars). I'm sure this is a factor. And finally, the spreader rake is currently set at 1/2 inch with the diamonds tighter than hell (the way I received the boat) which I know is incorrect for a soft rig(this is the prebend setting for mylar sails). It flies a hull in 6 knots. So I'm going to reset everything including the spreader rake. Come on guys/ladies, give me a number or a way to determine this.
TIA
Jack
0 registered members (), 4,310 guests, and 573 spiders.
