| Re: How Lift Is Created... If you are interested
[Re: Jimbo]
#55744 08/25/05 11:41 PM 08/25/05 11:41 PM |
Joined: Jun 2001 Posts: 733 Home is where the harness is..... Will_R
Posts: 733 Home is where the harness is..... | First, Tami, that kills me, glad somebody said it (42..love it) Second, I didn't read more than 30% of those long posts, I don't have the time (or attention span). Like my boss says, "get to the point". Tami said it once, I said it once, read a Marchaj book, he's not written the "definitive" books on the subject for no reason. I deleted my post explanation here, b/c.... I'm tired and don't feel like finishing it now. In short, the circulation effect accelerates the air on the lee side in comparison to the windward side. SINCE THE LEEWARD FLOW IS FASTER, THE PRESSURE EXERTED (BERNI) IS LOWER ON THE LEE SIDE THAN THE WINDWARD SIDE. Berni is able to tell us the pressure differential b/c of the differing velocities. Berni, then tells us part of the lift coeff. This guy uses the same type of information as Marchaj. http://www.av8n.com/how/htm/airfoils.html#fig-flow-pastI can't find my Marchaj book otherwise I'd post a pic of the graphs of pressures and resultant vectors. He did wind tunnel testing with pressure readings. It's hard to argue with numbers. As he explains it, the jib pulls 4-5x harder per in^2 than the main does. The jibs main purpose is, however to aid in keeping flow attached to the lee side of the main thus reducing drag and increasing efficiency. It does decrease pointing ability, however provides quite a bit of driving force on reaches. Was I pissy and terse, possibly.... am I about to get done with a week of AF inspections w/sh*tty inspectors and bogus findings... yes. Have I worked 50+hrs in 4 days and only had ~4-5 hrs of sleep/night... yes. I'm going to bed. p.s. Under the "fallacies" section, he kills the Coanda argument. http://www.av8n.com/how/htm/airfoils.html#sec-other-fallacies | | | Re: How Lift Is Created... If you are interested
[Re: Jimbo]
#55746 08/26/05 02:49 AM 08/26/05 02:49 AM |
Posts: 9,582 North-West Europe | Jimbo, There are actual real world physical phenomena described well by complex numbers such as electromagnetic wave theory ..
You misunderstood my statement. I myself wrote :"this math structure we humans are able to solve many complicated problems". Sound like "... actual real world physical phenomena described well by complex numbers ... " to me. What I was referring to is that an imaginairy number has no meaning in the real world. Example. If a wave has a frequency of say 10 Hertz that we know what that physically means. If however a wave has a frequency of say (10 + 4J) (= imaginairy number, with the J identifying the imaginairy part and the 10 being the real part) than nobody knows what that means in physical terms. Nor does such a wave form exist in the real world or can ever be made to exist. Such a construction that is very much possible in mathematical terms, is simply non-existant (impossible) in the real world where ONLY REAL numbers exist. That is why I say that an imaginairy number is just plain BS in the real world. It is as concrete in the real world as little wood elfs. Did I loose any of the other guys yet ? Yep we are talking about imaginairy numbers, no kidding they really do exist in mathematics and are quite helpful, especially in the analysis of oscillating systems. So for you guys the answer to how can imaginairy numbers be helpful in real life problems ? Because any system that initially is worded in real valued equations will produce real valued answer even though the path in between is using imaginairy numbers. In such a case the imaginairy numbers occur in what is called complex conjugate pairs. Example : whenever the number 10 + 4j arises than somewhere else its mirror image 10 - 4j arises as well; that is when the original problem is real valued. The math structure around these numbers keeps the pair linked to one-another so they constantly are added/subtracted or multiplied with eachother. Often right before the final sought after answer, which always is a value with meaning in the real world, the two mirror images are added or multiplied by one another resulting in a real valued number. example : (10 + 4j) + (10 - 4j) = (10 + 10) + (4j - 4j) = 20 + 0J = 20 = real value. Similar thing happens when multiplying to mirror complex numbers. The structure that enforces this behaviour is linked to wether a problem exist in the real world. If the final answer is NOT a real value then either you have made a calculation error or the original problem you were analysing simply does NOT exist in the real world. Funny stuff this is, right ? Who said Mathematics are boring ? The further you get into studying mathematics to more wild the phenomenons get. You just need a good teacher to get through the basics after that it gets mind blowing Wouter
[Re: Will_R]
#55749 08/26/05 09:34 AM 08/26/05 09:34 AM |
Posts: 16 | Will Again I only ask that people think for them self. We have all read Marchaj's books. I have every book he wrote. Marchaj didn't come up with these theories, he only rewrote them. Secondly your referance to John Denker's page does not in any way "kill" the Coanda arguement. I have read all of Denker's theories and again he did not create them, he simply restates them. Denker's barn door analogy is an excellant example of how wrong he is. The air flow "or water" will adhear to a flat plate at low angles of attack. If you don't believe it, try it in the sink with a sheet of plastic or metal. One of the mistakes he makes is using a fast stream that is broken and full of air. Just like a cavitating prop, the water will not adhere as well when mixed with air. Again the coanda effect doesn't create lift. Changing the direction of the air flow does. You can't just say that Newtonian physics does't apply to wings. It does, it always has and always will. The ONLY way to create lift is by changing the direction of the fluid flowing past the wing. The forces must be equal and opposite each other. Another on of the completely ridicules arguments by the "circulation beleivers" is that air is like "be bees" shot from a gun and bouncing off the bottom of the wing. I think we have all seen the diagrams of the wing with the be bees flying at it. There explination is that the only the air that strikes the bottom of the wings would change direction and therefore Newtonian physics can only account for a fraction of the lift. Use a little bit if common sense here and look at there diagram. If air were like be bees, there would be a perfect vacuum behind the wing because the wing has deflected those be bees away. Air is not like be bees, it's a fluid. Take a look at any of the diagrams in Marchaj's books of the fluid flow around a wing or sail. Look at the direction of the free fluid flow well ahead of the wing and look at the direction of flow behind the wing or sail. If there is lift, there is a directional change in the fluid flow. This whole circulation theory comes out of a misunderstanding of the Kutta-Joukowski lift on a rotating cylinder. The rotation of the cylinder is causing a change in the directional flow of the fluid flowing past the cylinder. See this link for a complete explination. http://www.lerc.nasa.gov/WWW/K-12/airplane/beach.html . | | | Re: How Lift Is Created... If you are interested
[Re: sailwave]
#55750 08/26/05 10:09 AM 08/26/05 10:09 AM |
Joined: Jun 2004 Posts: 141 Panama City Beach, FL steveh
Posts: 141 Panama City Beach, FL | Will R wrote: Bernouli works b/c of pressure differential produced by longer/shorter flow paths created by varying angles of attack. and Tami said it once, I said it once, read a Marchaj book, he's not written the "definitive" books on the subject for no reason. I haven't picked up a Marchaj book in about 15 years, but I doubt he uses the unequal flowpath theory. If he does, I think I'll take a pass. I'm sorry about being longwinded, but it takes a bit of explanation and detail to dispell myths and present (I hope) a clear and correct explanation. The true situation is a bit more complicated than just saying, "Unequal flowpaths!" or "Coanda!" or "Bernoulli!" and not nearly as sexy as those East European or Italian names. You think it's BS? Fine, present your case. But referencing this or that expert does not necessarily mean that there's understanding. I've read Rick's cat racing book, but until I can successfully apply it, I sure won't feel like I understand it. Don't like it, find it boring, think it's all hot air, well, there's a thread full of pithy rejoinders on light air racing to enjoy. | | | Re: How Lift Is Created... If you are interested
[Re: deseely]
#55753 08/26/05 11:00 PM 08/26/05 11:00 PM |
Posts: 141 Panama City Beach, FL | 10 Steps to Circulation Enlightenment1. Obtain CAD program 2. Draw circle of radius 5 3. Draw rotation vectors tangent to circle of length 0.5 pointing in clockwise direction 4. Draw horizontal linear flow vectors of length 1.41 at the tip of each rotation vector pointing right (the length makes it easy later) 5. Draw the resultant flow vectors 6. Measure the length of each resultant flow vector 7. Assume upstream pressure of 1 and density of 1 8. Using the upstream pressure and velocity and the velocity vector measurements in the Bernoulli equation, calculate the pressure at each point 9. Plot results on corresponding points 10. Analyze pressure field and determine that the lower pressure values above and the higher pressure values below will result in lift Almost as hot as the Nacra 580. That's it, I'm goin' to Disney World. | | | Re: How Lift Is Created... If you are interested
[Re: deseely]
#55754 08/26/05 11:36 PM 08/26/05 11:36 PM |
Posts: 122 | No problem with it Steve, in the real world a spinning cylinder or ball in a flow will produce lift but that is becauce it alters the direction of the fliud flow. Altering the direction of flow is the function of a foil. By altering the direction (velocity) of the flow, lift is converted from the kinetic energy of the flow. The spinning cylinder or ball is a type of foil. The key here is that the fluid produced a force on the cylinder or ball and the ball or cylinder provided an equal but opposite force on the fluid flowing past it. The spinning ball alters the flow because the flow adheres to the ball on the retreating side more than on the advancing side or more than it would on a stationary example. This increased adhesion prevents the flow from separating from the cylinder, thus it follows the cylinder's surface and it undergoes a continuous change in velocity (acceleration) as it does so. Lift is a reaction to this acceleration and the boundary adhesion. Jimbo | | | Re: How Lift Is Created... If you are interested
[Re: deseely]
#55756 08/30/05 01:13 PM 08/30/05 01:13 PM |
Posts: 9,582 North-West Europe | ... Looks like Jimbo is among the ever growing number of people who have realized that lift is just simple Newtonian physics. My sail puts a force on the air that passes by it and the air puts an equal and opposite force on my sail. That’s all, nothing more.
Pardon my amusement here but you don't need any knowlegde of physics to come to that conclusion. This is like saying that when you put your hand in the fire your hand will be heated up and the fire will get cooled. Leaving us no further in understanding WHY this is the end result of such an action. In effect everybody knows that a car will accellerate when you press on the gas pedal but doesn't mean that everybody understands what happens between pressing the peddle down and the car accellerating. In short, you haven't provided much clarity to the issue apart form something that is almost obvious. Also I think that a quatum physicist will have a problem or two with your statement that it is all JUST Newtonian physics. The point you are still trying to make about circulation theory is still a mute point as it is nothing more than a different mathematical model of the same lift producing proces. It is not an explanation but rather a way of looking at that proces from a modelling (mathematical) viewpoint with certain characteristics. In some applications it is handy, in most however it is not. There is not much point in disproving as it very much is mathematically correct. Meaning that the results acquired by using this model are accurate. It is just like prefering to say that 2 = (2*7 - 4) / 5 instead of 2 = 1 + 1, both are correct expressions although the first isn't very practical at first sight but never the less could be very handy in certain special cases. Wouter
[Re: Wouter]
#55757 08/30/05 04:00 PM 08/30/05 04:00 PM |
Posts: 141 Panama City Beach, FL | "That's it, I'm goin' to Disney World" was rhetorical. I did the vector math (with 23 points, not 4), worked up an Excel sheet and I got lift. In addition to no net flow deflection, I also got no drag, so what good is this circulation nonsense? Oh yeah, I got lift. And without all that mess of viscosity, Reynolds number, boundary layers, separation points and 3D, Navier-Stokes CFD codes. The spinning cylinder example you posted earlier doesn't have any net deflection, either, nor any drag. deseely, my question for you is, how does all that downward deflected air from simple Newtonian physics hold up the airplane? In F=ma, how do you measure or estimate mathematically the mass of air moved and its acceleration in order to calculate your lift force? Also, how and where is that lift force applied to the wing? Crack smoking circulationists have used circulation and idea of superposition of flows to develop a very successful aerodynamic modeling tool called panel methods** for estimating forces on a body. Including in three dimensions. If they can do it, I would hope that simple Newtonian physics could do the same. ** - PMARC is just an example. I liked it because in the description, they use the term "ficticious flow." So what comes from circulation really is cracksmoking bs. | | |
2,423
guests, and 262
