Hobie 17 fx1 #5593
03/21/02 02:58 AM
03/21/02 02:58 AM
Somerset UK
huw Offline OP
huw  Offline OP
Somerset UK
Thinking of buying one for single handed plus spini
anyone any comments - good/bad otherwise
Huw
Bristol Channel UK
Re: Hobie 17 fx1 [Re: huw] #5594
03/21/02 05:43 PM
03/21/02 05:43 PM
San Diego, CA
whitecaps Offline
whitecaps  Offline
San Diego, CA
I would highly recommend that you take a test-sail if at all possible, on both the FX1 and the Inter17 and compare them.
I haven't seen the FX1 here in San Diego, CA, but I have seen the Fox and it did not seem as nice as the I20 (which I have). I have sailed the I17 and it is nearly identical to the I20 in all respects (w/o a jib, of course).
The Inter's are very, very nice boats, much nicer than previous boats I've sailed (several Hobies and Prindles). They have put a lot of thought into making them very user-friendly, in addition to having outstanding performance. After riding with friends on their I20's, getting back on my previous P19 felt like driving a truck in comparison. It took me 3 years of drooling over them, but I finally got one.
Try it for yourself and you'll be convinced too.
Sail fast and have fun,
Alan Thompson
I20 - San Diego
Re: Hobie 17 fx1 [Re: whitecaps] #5595
03/22/02 04:07 PM
03/22/02 04:07 PM
Somerset UK
huw Offline OP
huw  Offline OP
Somerset UK
Yes the Inter17 is on the list - but there aren't many around in the Uk to race. The FX1 sail went well - flying hull singlehanded in a F2 uphill and downhill.
Fittings seem quality and robust - took a different style of sailing to get going - lots of tweeking out/down haul/mast rotation on each leg, and i was lying in the front of the tramp forward of the daggerboads to keep the stern out.
Seemed responsive without being twitchy.
I did capsize (intentionally) but my 14s with righting line needed a little help from the RIB safety boat. If I buy this I will need the frame when I solo in F2 ( particularly as I insist on spending my time on the leeward hull (single man's wild thing) at every opportunity.
Those of you F16 fans - as the following comparisons show the FX1 and (Spitfire) are quite similar: - taking from manufact. brochure
length 5.25m (5m)
beam 2.55m (2.52)
Mast 8.5 (8.5)
Sailing Weight 135kg (139)
Main 16 sqm (15.5)
Spinaker 19m2 (18m2)
SCHS 1.09 (1.04)
Why am I going to find the spitfire any easier to right singlehanded in F2 ??
Huw
Re: Hobie 17 fx1 [Re: huw] #5596
03/22/02 06:38 PM
03/22/02 06:38 PM
Depends on the mast weight. I don't know how the Spitfire behaves when righting. I do know that FX-one was very difficult to right. I couldn't do it at 180 lbs = 13,5 stone.
To compare :
F16 boats
Bim F16 carbon mast weight = about 9 kg's
Taipan 4.9 alu mast weight = about 13,5 kg's
Stealth F16 carbon mast weight = about 10 kg's
I expect the Spitfire to be a little bit heavier than the Taipan mast. Something like 15-16 kg's, but this is just a rough estimate. I really don't know what to think of the FX-one mast weight.
0 registered members (), 2,823 guests, and 139 spiders.
