Cat trax/roleez wheels #55947
08/25/05 06:48 PM
08/25/05 06:48 PM
PTP Offline OP
PTP  Offline OP
I know that catsailor sells complete cat trax and some parts but I figured out a way to fix old cracked roleez wheels used in a lot of the trax (and probably works for other types as well). The set I got were old and one of the wheels had cracked and this let air out despite trying all sorts of glues and tire-sealant. I tried one last effort- I drilled a hole in the tire, let as much air out as possible and squirted in 2 cans of expanding foam insulation/sealant (from hardware store). It works... and beats the 100$ replacement cost. HOWEVER, I encourage everyone to support catsailor
Re: Cat trax/roleez wheels [Re: PTP] #55948
08/25/05 07:37 PM
08/25/05 07:37 PM
I think I've heard of doing that before....and that that foam tends to absorb water.
Re: Cat trax/roleez wheels [Re: Jake] #55949
08/25/05 09:53 PM
08/25/05 09:53 PM
PTP Offline OP
PTP  Offline OP
yeah, it might... but we'll see. by the time I just give up and buy a new wheel I will likely have already spent more than the 100$! But hey, whatever works... gives me something to do when I am not sailing
Re: Cat trax/roleez wheels [Re: PTP] #55950
08/26/05 06:46 AM
08/26/05 06:46 AM
Pensacola, Florida / Katy, Tex...
Cookie Monster Offline
I had a tire that was leaking too. I filled it with air, and submerged the tire in my pool and you could see the air bubble coming through the cracks. I spent $28 on a tire tube from an ATV / Lawn Mower shop. Took me all of 10 minutes to install the tube. Trax are like new. I filled the tire and haven't touched it, including adding more air. I'm on my second year.
Don Cook ARC22 #2226 ADRENALIN
Re: Cat trax/roleez wheels [Re: Cookie Monster] #55951
08/26/05 09:00 AM
08/26/05 09:00 AM
PTP Offline OP
PTP  Offline OP
well... CORRECTION! The split in the tire was taped with duct tape but when the foam worked so well I took the tape off.. bad idea... the foam expanding split the tire along that splt. looks like I over thought this one.
0 registered members (), 2,666 guests, and 463 spiders.
13 hours ago
