Restoring black mesh tramp ? #56129
08/28/05 02:44 PM
08/28/05 02:44 PM
Tom_Robbrecht Offline OP
I have a black mesh trampoline that is starting to show its age, it is turning gray. Has anyone tried restoring the black color succesfully and if so, using which product ?
Re: Restoring black mesh tramp ? [Re: Tom_Robbrecht] #56130
09/09/05 12:37 PM
09/09/05 12:37 PM
Ontario, Canada
Captain_Dave Offline
Ontario, Canada
Tom,
I used an automotive vinyl dye (not paint) quite successfully on an old vinly tramp. I did this after I stripped the tramp of all contaminants (see previous posts "major restorations" for more details). It is holding up well. However, after a week of solid sailing, I had to touch up the area under the rear hiking straps. My original color was mustard/yellow and I dyed it black. In your case, staying with the original colour, you will have less of a problem. If the mesh tramps are vinyl as well (??) you should be happy with the result. Vinyl dyes can be found at autobody supply centers.
Good Luck,
Dave
0 registered members (), 320 guests, and 35 spiders.
