| Cleaning the white hulls of a hobie 16 #56266 08/30/05 05:42 PM 08/30/05 05:42 PM | Anonymous
| Anonymous
Unregistered | Hello!
I have a 1984 hobie 16 with white hulls. Since I wasn't able to finish my ramp for the boat, it was sitting around in the lake by my house all summer. (A dumb idea I'm sure) So as you can bet, there are some nasty brown stains on my otherwise wonderful boat. I have been scrubing with some bon-ami and a brush to get the grime off. It seems to work alright but it is real hard on my arms. Any suggestions for cleaning these hulls that might take alittle less 'arm power' and maybe might work better?
Thanks!
David | | | Re: Cleaning the white hulls of a hobie 16
[Re: ]
#56268 08/30/05 06:13 PM 08/30/05 06:13 PM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | Try Snobol toilet cleaner. It's cheap and all you have to do is wipe it on and walk away for ten minutes (no scrubbing) then rinse. Make sure you have good ventilation (acid in lungs bad). You might want to wear gloves also.
[Re: catman]
#56269 08/30/05 06:19 PM 08/30/05 06:19 PM | Anonymous
| Anonymous
Unregistered | Thanks for the tips, I think I will try and get to west marine and find some FSR. I actually have never heard of snobol, but I will look for it when I go to the hardware/grocery store.
When I do attempt either of these options should I apply something afterwards to protect the hulls? Maybe a wax or something? | | | Re: Cleaning the white hulls of a hobie 16
[Re: Dan_Delave]
#56274 08/31/05 03:05 PM 08/31/05 03:05 PM |
Posts: 393 Syracuse,N.Y | The oxalic acid is the key. The cleaner ZUD seems to have the highest concentration in it. You can usually find it at a local grocery store near Comet and others. ON/OFF also works great,but you need to be real careful with the acids.
Pat Bisesi
Fleet 204
[Re: rbj]
#56277 09/11/05 09:39 PM 09/11/05 09:39 PM |
Posts: 122 | Rubbing compounds are designed for a machine with a far more agressive action. Without this scrubbing rotary action, the compound cannot remove any significant amount of material, which is the purpose of rubbing compound. This action is also needed so that the compound 'breaks down' during the buffing process. As the compound abrasives break down into finer and finer pieces, the compound transitions from 'cutting' to polishing. Without this agressive rotary action this just does not happen. The result is poor removal of oxidation and poor surface finish. Actually, as a professional refinisher I can tell you that orbital buffers are not of much use at all. Before foam pads came along, an orbital buffer was the only way to get a swirl free finish when buffing really soft new finishes like some clearcoats. But with the advent of the foam pad you can get a swirl free finish on all but the very softest finishes with a rotary buffer. Remember that a rotary buffer is like 10X faster than an orbital. For those few times in the shop when we feel like we need an orbital for that final touch, we just use a wool buffing pad on a air DA sander. The DA is much smaller and more nimble than those big electric orbitals anyway. The caveat is of course that if you are unskilled with a rotary buffer you can screws thing up, even get hurt(I knocked myself out cold with a rotary buffer, once. Yup  ) It's about impossible to screw anything up or get hurt with an orbital buffer because they basically don't do much. I think that's why they got so popular; retailers are not afraid they will get sued since you are unlikely to ruin your finish or whack yourself in the head with an orbital no matter what your skill level, so they began to push them as the latest and greatest thing. Just a new way to sell surplus washing machine motors  IMNSHO Jimbo | | |
2,523
guests, and 702
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online7,715 2 hours ago | | |
