| Re: Help, an older cat that needs work?
[Re: swampy]
#5632 03/22/02 09:59 PM 03/22/02 09:59 PM | Anonymous
| Anonymous
Unregistered | I went to the Marine store where I live, and told the guy that I didn't want to much work. So he said that I should sand down the Paint that's on there right now only a bit, so that the new paint will bond well. He also said that if I did it this way, I'd only have to buy one paint can. So no primer would be needed. | | | Re: Help, an older cat that needs work?
[Re: swampy]
#5633 03/23/02 10:35 PM 03/23/02 10:35 PM | Anonymous
| Anonymous
Unregistered | Swampy, I have a nice solid '72 and went through the same thing...just paint it and get it back out on the water. Nothing special, just a good hardware store enamal will do the trick. There is some good marine paint available but I don't have a store near me so filled the big stuff with a poly filler and painted. Looks good and most importantly is ready to sail.
Good luck,
Tom | | | Re: Help, an older cat that needs work?
[Re: swampy]
#5634 03/23/02 11:24 PM 03/23/02 11:24 PM | Anonymous
| Anonymous
Unregistered | Hey Swampy I have a personal mix that works wonders and is cheap to make, I used it to do my bottom, fill nicks and reshape the rear of the hulls where it had brokern away from the rudder pins. Here it is: Fairing Putty: Resin - 3 to 4 parts microspheres - 1 part cabosil Mix well will turn into a think marine tex looking mixture, apply with squeegy and sand smooth(3 sandings by hand 100 light, 300 light, 600 wet) Give the whole boat a light sand to rough up the gelcoat and have it painted I had both my hulls profesionaly shot with Emron for $200.00. This is the long but proper meathod of doing it, I'm all about looking good as well as sailing fast so this meathod was worth it for me on my 79 boat. Here are a couple more useful mixes: Glazing Putty: Resin and Cabosil mix to desired texture Bonding Putty: Resin - 3 to 4 parts microsphere - 1 part milled glass fiber Good luck Peter Cherrick H16 ElDiablo USA 37848 http://groups.yahoo.com/group/necatsailors | | | Re: Help, an older cat that needs work?
[Re: swampy]
#5637 04/02/02 08:58 AM 04/02/02 08:58 AM | Anonymous
| Anonymous
Unregistered | Try using Interlux Bridhtside Polyurethane. After a little sanding and priming, you can roll on that stuff with ease. I would say three coats at 20 mins a coat for each hull, and your boat will be gleaming. Worth it when you see the results! | | |
2,475
guests, and 285
