Re: Is a Wave the Correct Choice? [Re: Jeff_P] #56470
09/12/05 11:22 PM
09/12/05 11:22 PM
Thanks for the tips. I would not have thought of spraying the lacing rope. I guess this means you don't lie on your back under the trampoline tightening the lacing with vice grips, as we have been doing for 25 years.
Re: Is a Wave the Correct Choice? [Re: Mary] #56471
09/13/05 06:27 AM
09/13/05 06:27 AM
RickWhite Offline
RickWhite  Offline
Mary, I don't do that either.., grass makes me itchy. On the Wave you can reach the middle of the tramp easily from the side.
John McKnight has a great tool he built for tightening lacings. It is a flat piece of alum sheet with a cam cleat mounted at one end. On the other end he cut a hand hold and padded it.
You simply grab the line with the cleat and pull. Jam a fid into the grommet to hold the lacing, and get another grab.
It really does a great job.
One of these days I will have to try and duplicate that tool.
Rick
Rick White
www.onlinemarinestore.com
Re: Is a Wave the Correct Choice? [Re: RickWhite] #56472
09/13/05 07:39 AM
09/13/05 07:39 AM
Well, Rick, I can't reach the middle from the side, so I guess that means you have to lace my tramp for me.
And on the Hobie 18, as I recall, it was always me underneath with the vice grips.
Re: Is a Wave the Correct Choice? [Re: RickWhite] #56473
01/15/06 03:59 PM
01/15/06 03:59 PM
rbj Offline
rbj  Offline
Rick, what's a "fid"?
Re: Is a Wave the Correct Choice? [Re: rbj] #56474
01/16/06 04:44 AM
01/16/06 04:44 AM
A fid is sort of like a fat knitting needle that is usually made out of wood and tapers down to a sharp point. It is used to spread apart strands of line for splicing or to open stubborn knots.
If you have a stainless rigging knife that has a knife on one side and a long pointed thing on the other side, that pointy thing can be used as either an awl or a fid.
(When dealing with rope, a fid is also a unit of length defined as 21 times the diameter of the rope that is being worked with.)
Re: Is a Wave the Correct Choice? [Re: Mary] #56475
01/16/06 03:34 PM
01/16/06 03:34 PM
rbj Offline
rbj  Offline
Thanks, Mary.
0 registered members (), 657 guests, and 321 spiders.
