| Spinni Pole / Boom material spec #56780 09/08/05 07:21 AM 09/08/05 07:21 AM |
Posts: 145 Cheshire, UK | Does anyone know what spec aluminium should be used for a spinni pole and boom?
I'm specifically looking for the 60xx number for Nacra F18 spinni pole, and a Spitfire spinni pole & boom (appears to be the same tube is used for both, certainly in diameter and thickness).
I've identified a supplier of 6082T6, 16swg, 1.5" OD, anodised. Another has mentioned 6063T6. Should I give a damn?
This is for myself and a few mates with a mix of boats as above, who are finding breakages expensive!
Thanks, Simon
Simon Shadow 067 | | | Re: Spinni Pole / Boom material spec
[Re: Simon]
#56782 09/08/05 11:34 AM 09/08/05 11:34 AM |
Posts: 545 Brighton, UK | Simon From those specs I would guess you are based in the UK, I'm going to respectfuly disagree with Carl, I beleive the normal alloy for this application in the UK is 6082-T6. Most reputable manufacturers use 6082-T6 for masts, booms, beams etc. 6082-T6 is superior to 6063-T6 in terms of strength, but most grades are similar in terms of stiffness. Check if the anodising is on inside and outside of tube, if only on the outside you may want to follow Carls advice. If you want more info on the different materials mentioned try using http://www.matweb.comAll that said, 6063-T6 is probably cheaper, so if your components are breaking in compression then you may not see any real difference in terms of strength. You pay your money you take your choice. All the best Gareth www.fourhulls.com | | | Re: Spinni Pole / Boom material spec
[Re: grob]
#56783 09/08/05 12:44 PM 09/08/05 12:44 PM |
Posts: 145 Cheshire, UK | Carl, Gareth, Thanks for your feedback. This forum never ceases to amaze me in terms of the expertise that's available out there. Yep, I am based in the UK (Cheshire, sail at the Dee SC).
[Re: carlbohannon]
#56786 09/08/05 08:32 PM 09/08/05 08:32 PM |
Posts: 122 |
If I am looking for aluminum, my 1st choice is 7075 T6 or T651 with 6061 T6 2nd.
7075 is about 1.5 times as strong as 6061
Ditto for 2024 which is much easier to find. The trouble with these 'higher' alloys of aluminum is that they corrode like mad; terrible fatal intergrannular corrosion with the slightest provocation. This is espeially true of 7075. That's why you don't see them used in marine extrusions very often. Anodizing would be absolutely mandatory; paint would just not cut it. I've seen 7075-T6 go from uncorroded bare clean metal to intergrannular (trashed) in a month by sitting outside in weather. And not on the beach, mind you but at an inland airport! We had to instruct our paint crew to carry a spray can of green primer to 'touch-up' any bare spots at the end of each work day in case the job got held up so as not to create a bunch of skin repairs! What a nightmare! Also these alloys are not weldable, if that matters to you. 6061 happens to be the strongest weldable alloy. Also 6061 has a much better fatigue life than either 2024 or 7075. There's a reason the marine industry uses what they use. If you want stronger/lighter, go with carbon. Since 7075 is used almost exclusively by the aircraft industry, it costs about like a carbon pole anyway, unless you just happen to find the right size in a surplus store or scrap bin. IMHO Jimbo | | | Re: Spinni Pole / Boom material spec
[Re: flumpmaster]
#56787 09/09/05 03:05 AM 09/09/05 03:05 AM | Anonymous
| Anonymous
Unregistered | Hi all,
Chris you beat me to it.
My friends and I use Sailboard Masts almost exclusivly in both Carbon and Alloy, they have proven to be more than up to the job for booms and poles. The tapers allow you to reduce weight and windage at the outer ends where the stiffness is not needed.
Second hand one piece Sailboard Masts are very cheap in OZ, of course you have to look closely at what you are buying but misuse is generaly easy to see. The Alloy masts are getting harder to find, but if you can find Serfiac a european brand which I believe where very popular in UK as well as OZ they are excellent, anodised models are very resistant to corosion. The carbon mast vary alot in stiffness and strength racing mast are stiffer, wave masts are stronger.
Regards Gary. | | |
2,106
guests, and 181
