| Re: G-cat ??
[Re: PDB]
#57311 09/16/05 10:01 AM 09/16/05 10:01 AM |
Posts: 284 Norfolk, VA | G-cats are nice, sturdy boats and they are great for non-sailors because they have a really open tramp and a forward tramp! I have only seen a few and I've owned one for a short while, but I was impressed.
There are two versions--one is a rental boat with a shorter mast and the other is a standard G-cat. If you get the rental version, you may not be happy with it, but it would be about impossible to get a used stock G-cat mast. However, I replaced my 5.0 mast with a Nacra 5.2 mast. I had to move the tang and all connectors, but it was almost the same size extrusion. The mast base even fit in!
The boat has enough hull to it, that it is screaming for a spinnaker or Hooter sail!
Dan Berger Norfolk, VA A Cat USA139 Supercat 15
| | | Re: G-cat ??
[Re: Dan Berger]
#57312 09/18/05 09:21 PM 09/18/05 09:21 PM |
Posts: 591 Bradenton, FL | He's looking at a 5.0 mast, which should be identical to a H16 mast with the G-Cat mast-step base. My G-Cat 5.7M mast is a H16 extrusion that is (obviously) longer and has spreaders added.
I believe the mast and rear crossbeams are the same extrusion, while the forward crossbeam is a H14 mast section. There are no complicated systems on the boat, and if the rudders fail you and you cannot repair the (absolutely wonderfully designed) system a H16 or TheMightyHobie18 system can be retrofitted. Vector Marine will be producing a G-Cat F16 in the near future, though I doubt it will have much in common with it's predecessors beyond hull design.
Hobie 14T
713
guests, and 42
