Page 4 of 6 1 2 3 4 5 6
Re: Hull Oxidation [Re: bullswan] #57386
09/28/05 10:25 AM
09/28/05 10:25 AM
Greg- did you do the whole kit or just the vertglass part? I just got the whole kit in the mail today and will probably start the process today.
Re: Hull Oxidation [Re: PTP] #57387
09/28/05 10:45 AM
09/28/05 10:45 AM
Northfield,NH USA
bullswan Offline OP
bullswan  Offline OP
Northfield,NH USA
I did the Oxidation Removal with the scrubby pad they provided. I went around twice washing the boat off periodically. Then I waited a day and washed the boat using Step 2 boat wash. Let that dry completely..
Finally I painted on Step 3 and I just continuously painted till I had 6 or 7 (I lost track, quite frankly, cause I was listening to the Red Sox game at the time)coats on. My hands were sick of painting and it was getting dark so that is all I've done and I still have enough stuff to put more coats on at the beginning of next season if I want.
Good Luck. Hope you get the same results I did.
Greg
Re: GRUNT LABOR VS BEING OUT SAILING [Re: Mary] #57388
09/28/05 11:48 AM
09/28/05 11:48 AM
I'm talking hypothetically here, Jake. If it IS faster in water, would it also be faster in air?
Yes - but the affect would be ever so slight and tiny that it wouldn't be measureable. If you were trying to move the hull through air closer to the speed of sound - yes, it might make a measureable difference. However, at highway speed, the resistance due to airflow is more about profile drag than skin drag...and when changing the finish of a suface on the magnitude of these coatings, you would be affecting skin drag.
Skin drag is largely affected by how thin/thick the boundary layer of turbulent airflow is between the skin of the object and the smooth laminar air flow around the object. There is so much outside turbulance coming from other cars, the tow vehicle, and cross breezes that your not going to get a steady boundary layer no matter what you do. Hence the skin drag (through air) can't be significantly impacted by a coating on this level and at these speeds.
Re: GRUNT LABOR VS BEING OUT SAILING [Re: Jake] #57389
09/28/05 01:21 PM
09/28/05 01:21 PM
Panama City Beach, FL
steveh Offline
steveh  Offline
Disrespecting laminar flow?!? BLASPHEMY!!
I've already commented on the failures of wax. To summarize: wax is hydrophillic, when instead hydrophobic characteristics are far more desirable. This means wax attracts water, hangs onto; with the net effect that it increases drag on the boat.
I'll Paypal money for a six of Newcastle Brown Ale to anyone that can post a reference to a credible, objectively executed drag test that puts to rest the hydrophobic/hydrophilic debate. Preferably with a .edu, .nasa.gov or .navy.mil URL. I have yet to find one.
Re: GRUNT LABOR VS BEING OUT SAILING [Re: steveh] #57390
09/28/05 01:32 PM
09/28/05 01:32 PM
Just finished with the oxidation removal (FLIPPIN WATER STAINS!) and wash... looks better already... but as with washing anything- the flaws really stand out when you look at it THAT closely.
Re: GRUNT LABOR VS BEING OUT SAILING [Re: PTP] #57391
09/28/05 01:40 PM
09/28/05 01:40 PM
Northfield,NH USA
bullswan Offline OP
bullswan  Offline OP
Northfield,NH USA
Did you take "before" pictures???? Hope so. Love to see them.
Greg
Re: GRUNT LABOR VS BEING OUT SAILING [Re: bullswan] #57392
09/28/05 01:43 PM
09/28/05 01:43 PM
Northfield,NH USA
bullswan Offline OP
bullswan  Offline OP
Northfield,NH USA
More after photos......
Re: GRUNT LABOR VS BEING OUT SAILING [Re: bullswan] #57393
09/28/05 01:44 PM
09/28/05 01:44 PM
Northfield,NH USA
bullswan Offline OP
bullswan  Offline OP
Northfield,NH USA
Last one....
Re: GRUNT LABOR VS BEING OUT SAILING [Re: steveh] #57394
09/28/05 02:01 PM
09/28/05 02:01 PM
I'll double that ante!
Re: GRUNT LABOR VS BEING OUT SAILING [Re: Jake] #57395
09/28/05 02:15 PM
09/28/05 02:15 PM
Jake,
Check out Bethwaite's book. I believe he mentioned something about waxing vs. not waxing his "GREAT ALMIGHTY AUSSIE SKIFF".
It's not documentable enough to win the brew, but it's a start.
I agree with the comments that polishing hulls does accomplish two things:
(1) it puts you in a racing mindset by focusing your brain on going fast
(2) it offers you the opportunity for CLOSE inspection of the hull, and you can spot and repair scratches, road grime, crud, etc. that could slow you down.
Last time I polished the hulls (about every 6 months), I noticed some scratches that I repaired. I wash the hulls before every race, and I once found that my daggarboard tape was sticking down (which has GOT to be slow), and fixed it.
This probably is only something the top sailors need worry about, since more of us blow races from bad tactics, bad technique, or just bad manners....
Re: GRUNT LABOR VS BEING OUT SAILING [Re: Jake] #57396
09/28/05 02:19 PM
09/28/05 02:19 PM
steveh Offline
steveh  Offline
Either that or someone can Paypal me $100k and I could get some time in the Navy's tow tank at Carderock.
Re: GRUNT LABOR VS BEING OUT SAILING [Re: Jake] #57397
09/28/05 05:42 PM
09/28/05 05:42 PM
RickWhite Offline
RickWhite  Offline
OK, but you owe me big time.
I was RC at the Savannah Olympics and we had a couple of lay days. I was staying in my RV behind a warehouse that had a couple of old wrecked cars.
So, I decided to do a speed test on surfaces.
The hood of this car was slightly downhill.
I set up several race tracks for drops of water to compare the time it took for each drop of water to move down it's race course.
Here are the race tracks
1)nothing
2)polish and/or wax
3)McLube
4)Rainex
5)McLube and Rainex
Results (as I vaguely remember them):
1)nothing = the drop did not move
2)polish and/or wax = the drop did not move
3)McLube = 9 seconds
4)Rainex = 11 seconds
5)McLube and Rainex = 1 second
Now if we could just keep McLube and Rainex on our hulls all the time, we would really be hot. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
When I got my diesel RV Stan Woodruff and I pushed it pretty hard and when we arrive at Sandy Hook for the Wave NAs, the boats were pretty dirty from the diesel soot.
Stanly worked hard for hours cleaning his hulls, but meanwhile I had talked to Mary. She explained that diesel soot is a long chain polymer.
I won the regatta. <img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" />
Rick
Rick White
www.onlinemarinestore.com
Re: GRUNT LABOR VS BEING OUT SAILING [Re: RickWhite] #57398
09/28/05 07:41 PM
09/28/05 07:41 PM
Popeye Offline
Popeye  Offline
Greg,
Your original hulls looked pretty good compared to many I've seen. I recall you did a lot of work on them a little while back. Now that you've "Verted" your hulls they look great. Congratulations! If you applied the stuff correctly and continue to re-apply it according to the specs, you'll be a happy guy. By some of your comments, I noticed you misunderstand some of my comments. As do several others. You don't have to appologize to me. Listening to the feedback, I think we're talking past one another. I'm pleased somebody finally did something. Several times now I suggested some advantqages to using UV protectants, irrespective of brand. If it makes anyone feel better to use one instead of the other, by all means do so. Something is usually better than nothing. If you're the kind of person who's curious, or even skeptical, about the kind of marketing claims we are all continually bombarded with in this country, then you'd probably want to ask any number of probing questions to help yourself sort things out to your advantage, not Madison Ave. advantage.
I'm loath to open up Pandora's box (sorry Jake) and start discussing avionics. If I read this thread correctly it seems that it's more important to be right than correct. Jake is incorrect regarding whether these products, when properly applied, decreases drag. I don't think anything I can say will change that. I'm not even sure Rick's experiment will suffice. Jake and SteveH and those who doubt the drag reduction comment, would be better advised to go to a credible Physics Department on their local college campus and see if they can bend the ear of one of the post docs for an explanation.
Mary,
It sounds like you first must determine if this stuff makes things go faster in water, before you can move on and discover whether it does the same for an airfoil. I think you've indicated that your boat already goes fast enough, so I fail to see any advantage in doing a test. And you'd also have to move from the hypothetical to the material. I think the greater advantage for you may be in trailering. You would arrive at your destination with a cleaner pair of hulls or hulls that would wash the road grim off with less effort.
SteveH,
A six pack of beer, especially Newcastle, isn't much of a stimulus. Last time I was there the Britts don't even drink the stuff since they started pasturizing it; it's kinda like Bud for them. However, as I suggested a visit to your local campus may find a more willing taker. There is a caveat though, in addition to maintaining healthy skepticism when you walk through the doors of the physics lab, your required to have an open mind.
PTP,
Whether you need to use the entire kit depends upon the condition of your hulls.
In case any of you are still sailing out there, today was nasty. Steady between 20 and 25 and frequent gusts of 30 and better. As a newcomer I reserve the right of silence regarding whether we went over or not. Unfortunately no other cats were on the lake. There was a group of diehard boarders and some fall kite sailors out. Sailed an F18 all morning and a 6.0 this afternoon. We could take all but a couple of the boarders, I suppose because of the heavy waves. I'm sworn to secrecy so I can't disclose whether the hulls were coated and if so, what with. You know how it goes, ...orders from headquarters.
Daniel
Re: GRUNT LABOR VS BEING OUT SAILING [Re: Popeye] #57399
09/28/05 11:28 PM
09/28/05 11:28 PM
steveh Offline
steveh  Offline
OBJECTIVE DATA!!! Rick, you've at least earned a couple of bottles of substandard beer. However, not sure that it's 100% applicable. The surface tension of the droplet would play a part in the race and wouldn't on a hull. Also, in my googling of 'hydrophobic hydrophilic drag test,' I came across a reference stating that some coatings can be hydrophobic in air and hydrophilic in water. So if the RainX/McLube coating is hydrophobic/hydrophilic, which side wins? Yeah, I know, doesn't make sense to me, either.
Daniel, thanks for the suggestion, but almost half the people in my hallway at work are physics Ph.D's and I wouldn't trust them on SWAGging this nor on running the test. All I've seen for both sides until Rick's results is ad claims and intuitively obvious anecdotal evidence put forth by messageboard experts based on some other messageboard expert's intuitively obvious anecdotal evidence. I'm not claiming to be either right or correct, but if you can't bring anything objective to the table, then no beer for you. BTW, I'm fine with Pandora's boxes.
Re: GRUNT LABOR VS BEING OUT SAILING [Re: steveh] #57400
09/29/05 07:49 AM
09/29/05 07:49 AM
How about the one where Hydrophobic wax (regular 'ol wax) would make your boat float higher because it pushes water away?
I'm an enginerd and have never heard any testing that anyone performed that was objective and thorough in relation to waxy, oily, or wetsanded hull bottoms flowing through water. You can tell me until you are blue in the face that you think your boat is faster with this coating or that or that you were faster than sombody else without but it's not objective. As an example, it always seems like my truck runs better after a washing although I know it's physically impossible. Point is, personal opinion and "feel" are not adequate enough to stake a claim on some scientific result. Show me the money! Until then, I'll focus on keeping the bottom of my boat clean and fair and trying to avoid mistakes on the course.
Re: GRUNT LABOR VS BEING OUT SAILING [Re: Jake] #57401
09/29/05 09:01 AM
09/29/05 09:01 AM
steveh Offline
steveh  Offline
Here's the kind of test that doesn't cut it. It's for the hydrophilic coating, Hyspeedkote. The results look interesting. Interesting enough to include in a test, but there are too many uncontrolled unknowns in real-world testing. This is what it takes for a thorough, objective test. A controlled environment, a carriage that can maintain a set speed and electronics to measure small differences in forces.
BTW, that's me on the plank. Seriously, $100k and a week at that tank and the answer is known.
Would a hydrophilic coating make the boat sit lower in the water?
Re: GRUNT LABOR VS BEING OUT SAILING [Re: steveh] #57402
09/29/05 03:04 PM
09/29/05 03:04 PM
Northfield,NH USA
bullswan Offline OP
bullswan  Offline OP
Northfield,NH USA
All this stuff is bringing back my ice cream headache. Hydrophobic, Hydrophilic, it's all Hydro-PHALLIC to me....
All I wanted was purty, shiny hulls and I got em.
New question..... Triradial vs. Horizontal-cut dacron sails.
What is the difference? Why do I want one or the other. Why does Triradial cut cost a lot more? $820 vs $ 975 from Calvert for a 5.0 oz Yellow Square-Top Dacron Main.
Thanks
Greg
Re: GRUNT LABOR VS BEING OUT SAILING [Re: bullswan] #57403
09/29/05 03:24 PM
09/29/05 03:24 PM
St. Louis, MO
hobienick Offline
hobienick  Offline
St. Louis, MO
Wouldn't a thicker boundary layer produce less drag? Wouldn't a surface that is not as slippery to water produce that thicker boundary layer? Wouldn't this lead us to the non waxed/coated/slippery hulls being faster?
The box has been opened further.
Nick
Current Boat
Looking for one
Previous Boats
'84 H16
'82 H18 Magnum
'74 Pearson 30
St. Louis, MO
Re: GRUNT LABOR VS BEING OUT SAILING [Re: bullswan] #57404
09/29/05 04:35 PM
09/29/05 04:35 PM
St. Louis, MO,
Mike Hill Offline
Mike Hill  Offline
St. Louis, MO,
Thanks
Greg
Triradial is better because it aligns the fibers in the direction of stress on the sail. Thus the sail is consistently stretched throughout.
Triradial costs more because you waste more material when building the sail because of the many cuts.
Mike Hill
www.stlouiscats.com
Mike Hill
N20 #1005
Before and After [Re: Mike Hill] #57405
09/30/05 11:59 AM
09/30/05 11:59 AM
The pre pictures are further back in this forum. I am not sure the pictures do it justice, but the system is pretty amazing with vertglass... it was amazing to see all the oxidation washed off the boat with the first step.. I have no idea how many coats I did with the vertglas- maybe 6 or so- some parts more than others. It DOES look like a new boat... now I guess I have to do the centerboards.. ugh
0 registered members (), 15,505 guests, and 1,352 spiders.
Most Online22,490
6 hours ago
