Spreaders bent? #57825
09/22/05 05:24 PM
09/22/05 05:24 PM
PTP Offline OP
PTP  Offline OP
Oh knowledgable ones:
I just realized that my spreaders are off balance. One is maybe 3 inches too high and the other 3 inches low on the diamond wires. I think they were making a sound when gybing last weekend- everytime we changed tacks you heard a loud pang. I didn't really notice until today. The mast is still up and I am going to be taking it down to take the boat home, but I was wondering if anyone had any experience with this and have any suggestions on how to fix it. Could it be as easy as making sure the attachment to the mast isn't horrendously bent, straighten them, then use seizing wire to make them stay put again. Any suggestions?
Re: Spreaders bent? [Re: PTP] #57826
09/22/05 06:17 PM
09/22/05 06:17 PM
Atlanta
bvining Offline
bvining  Offline
Atlanta
I have a set of Proctor adjustable spreaders for sale if you need them.
Bill
Re: Spreaders bent? [Re: PTP] #57827
09/22/05 06:36 PM
09/22/05 06:36 PM
Toronto, Ontario
pitchpoledave Offline
Toronto, Ontario
I just had a spreader break on my N6.0na, and that caused the mast to break. The front adjuster screw sheared right at the Y. The only cause I can think of is metal fatigue when I had the spreaders go up/or down and had to slightly close the Y with pliers. I think this caused metal fatigue. I would recommend that if in doubt, get a new spreader kit and then tie the spreaders tight to the diamond wires with several short stainless wires..
Dave
Re: Spreaders bent? [Re: PTP] #57828
09/22/05 07:07 PM
09/22/05 07:07 PM
Central California
ejpoulsen Offline
ejpoulsen  Offline
Central California
If you have any question about the structural integrity of your spreaders, by all means replace them--a lot cheaper than a mast.
58173-picture 120.jpg (94 downloads)
Eric Poulsen
A-class USA 203
Ultimate 20
Central California
Re: Spreaders bent? [Re: ejpoulsen] #57829
09/22/05 07:32 PM
09/22/05 07:32 PM
PTP Offline OP
PTP  Offline OP
I will let you know when I get the mast down and take a look. What are Proctor adjustable spreaders?
will they work on a 6.0ex?
Re: Spreaders bent? [Re: PTP] #57830
09/22/05 08:34 PM
09/22/05 08:34 PM
Central California
ejpoulsen Offline
ejpoulsen  Offline
Central California
Proctor spreaders--see my photo above
Eric Poulsen
A-class USA 203
Ultimate 20
Central California
Re: Spreaders bent? [Re: pitchpoledave] #57831
09/22/05 08:44 PM
09/22/05 08:44 PM
Dave,
For a short period, there was a problem with the 6.0 spreaders where the threads of the adjustable part were threaded too closely to the slot milled out for the attachment to the mast. It took too much meat away resulting in occasional failure. I'm not sure if there was any factory warrantee on that or not (probably not).
PTP,
The Nacra spreaders have a good deal of play up and down - we could move the Nacra 20 spreaders up and down 3 to 4" as measured at the tip with no diamond wire tension. This is not a problem as long as you keep them perpendicular to the mast when tightening the diamonds. You should always have at least 300 to 400 lbs of tension on the diamond wires which should easily keep the spreaders in place...chances are that your diamond wires are too loose. A little retaining wire won't hurt either.
Re: Spreaders bent? [Re: Jake] #57832
09/22/05 08:52 PM
09/22/05 08:52 PM
PTP Offline OP
PTP  Offline OP
Jake,
Thanks, you said what I wanted to hear. I will see how things look when I get the mast down. What is the best way to check/measure the tension on the diamond wires?
BTW... I just ordered the Vertglas kit and will back you up if all goes well
Re: Spreaders bent? [Re: PTP] #57833
09/22/05 09:34 PM
09/22/05 09:34 PM
Use a loos gauge. You can usually find them on ebay for about $25 if you wait a week or so.
Re: Spreaders bent? [Re: PTP] #57834
09/23/05 06:55 AM
09/23/05 06:55 AM
Crofton, MD
Chris9 Offline
Chris9  Offline
Crofton, MD
We had the same problem last year with one of the spreader working its way down a little, not as much as yours. Certainly check your spreader screws, we replaced our because of the threads. There was a notice from the factory to replace the spreader screws, but it was some time ago. We replaced the screws and made sure to tie them tightly in place with some thin stainless wire as I recall. Jake mentioned 300 – 400 lbs. In talking with Rick Bliss, he directed me to the NENSA website that has a tuning guide. From this guide we set the mast up according to the big crew setting since we average between 380 and 400 lbs. From memory, so check the tuning guide, with the mast on supports we set the spreader rake to 1.75” and then tighten the outer diamond wires to 500lbs, resulting in 1.5” of pre-bend. There is a note that also says never let the pre-bend be less than 1.25”.
Your post signature says …6.0Ex. Does that mean you have the actual, much talked about and feared “Express”? The first race we did with our 6.0NA with Smyth square-top main and big jib, we were hammered with the Express rating even thought we didn’t carry a spin. Since then we have over come the “Express” fear by comparing the square-top main to the standard class sail. It was noted that the square-top sail was not bigger, but that the sail area was allocated differently. We did not that the jib was about 6% bigger than the standard NA jib. Do you have any other pictures to share? Rick Bliss is a very valuable resource for the 6.0.
Chris Allen
Nacra 20 Gertie
www.wrcra.org
Re: Spreaders bent? [Re: Chris9] #57835
09/23/05 01:39 PM
09/23/05 01:39 PM
PTP Offline OP
PTP  Offline OP
Yep, I have an "express" (as far as was told to me when I bought the boat and everything else I know about it). It has a monstrousity of a jib that does backwind the main pretty quickly if you aren't paying attention. I have been told that the downwind performance of the express is almost second to none (except spin boats of course). HOWEVER, I have yet to experience it and am workign on practicing downwind runs better. I know that my total weight is an issue (not me, I am 160, crew is 230) for downwind but it seems like there is something else we are missing. I am somewhat new to catamaran racing so I am figuring things out as I go along. I sort of like tinkering with the boat but am afraid of breaking stuff as I tinker with and/or fix it. I did check out the NENSA site and it does seem to be helpful. I will let you know how it turns out.
BTW- the problem with the threads on the spreaders- what model years had that problem? Mine is a 1990.
Re: Spreaders bent? [Re: PTP] #57836
09/23/05 01:50 PM
09/23/05 01:50 PM
PTP Offline OP
PTP  Offline OP
another pic
Re: Spreaders bent? [Re: PTP] #57837
09/23/05 01:58 PM
09/23/05 01:58 PM
REPLACE THE SPREADER ENDS! REPEAT! REPLACE THE SPREADER ENDS!
Two things: the threads on the lower one in this picture are too close to the milled grove resulting in weakening the material badly there. Secondly, the 'ear' is bent on it which will quickly lead to a fatigue failure. Seriously, replace those adjustable ends before sailing again and make sure you are running adequate diamond wire tension. The parts and tools are a lot cheaper than a new mast.
Re: Spreaders bent? [Re: Jake] #57838
09/23/05 02:01 PM
09/23/05 02:01 PM
PTP Offline OP
PTP  Offline OP
You're killing me. but you seem to know what you are talking about
I appreciate it... now, how to get new ones?
Re: Spreaders bent? [Re: PTP] #57839
09/23/05 02:27 PM
09/23/05 02:27 PM
You can find your nearest dealer by going to www.performancecat.com. Rick Bliss at www.new-england-catamarans.com or the guys at Key Sailing in Pensacola, FL come to mind first.
Re: Spreaders bent? [Re: Jake] #57840
09/23/05 02:46 PM
09/23/05 02:46 PM
Chelmsford, MA
Barry Offline
Barry  Offline
Chelmsford, MA
Rick has them is stock. Just bought some. He may be out of town for the weekend if you call.
Re: Spreaders bent? [Re: Barry] #57841
09/23/05 03:10 PM
09/23/05 03:10 PM
PTP Offline OP
PTP  Offline OP
New Eng Cat referenced Murray's site so I just ordered them from Murrays- I called Rick but they are closed until monday. Should have waited, given that they are on back-order at Murray's. oh well... MO MONEY MO MONEY... ordered a loos meter as well... and awaiting my new mainsail. Gotta start working more (gotta work hard to play hard)
thanks for your help.
Re: Spreaders bent? [Re: PTP] #57842
09/23/05 11:49 PM
09/23/05 11:49 PM
Dang, you are going to be stylin' soon! (sorry - just watched "Joe Dirt"). I'm glad you got everything in the works! You'll have to take me for a ride if I make it down that way.
Re: Spreaders bent? [Re: Jake] #57843
09/24/05 08:31 AM
09/24/05 08:31 AM
PTP Offline OP
PTP  Offline OP
Jake,
I figure I owe you more than a few beers by now so if you make it down here I would be happy to (you probably could teach me a lot too.. which would lead to more beers, I think you'd be set)
pp
