| Re: not a golf cart
[Re: DVL]
#58075 10/02/05 11:14 AM 10/02/05 11:14 AM |
Posts: 364 | Here is an electric aircraft tug on Ebay. It's set up for AC, but could likely be converted, or the idea adapted, relatively easily.
Andrew Tatton
Nacra 20 "Wiggle Stick" #266
Nacra 18 Square #12
| | | Re: not a golf cart
[Re: davidtilley]
#58078 10/02/05 04:38 PM 10/02/05 04:38 PM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | How about beach wheels that are a modified version of a Segway? Get the boat balanced on the wheels, turn it on, and when you dip the bows down, it goes forward, dip the sterns down, and it goes backward.
I found a web site that says you can build a Segway-type thing yourself inexpensively. | | | Re: not a golf cart
[Re: Mary]
#58079 10/02/05 07:51 PM 10/02/05 07:51 PM |
Posts: 12,310 South Carolina | Or an old set of blocks to give you 2:1 or 3:1 purchase and a lot of 3 strand cheap rope. Tie one end to the boat and the other to a stake in the sand (or something) and start pulling - however, this doesn't really solve your single handing issue. I sometimes have to move my trailer in my backyard using this method.
Jake Kohl | | | Re: not a golf cart
[Re: DVL]
#58081 10/03/05 08:04 AM 10/03/05 08:04 AM |
Posts: 306 St. Louis, MO | Just remember when adding an electric motor to anything that will be submerged is going to make it complicated.
Having worked on the Segway develpoment, I can tell you there are no cheap alternatives to a Segway, yet. The components that make it work are still very expensive.
The aircraft tug (if it is one of those small ones designed to fit on the front wheel of a small plane) will definitely not work on sand. They are designed ot work on fairly level paved surfaces. Plus you would have to seal everytign to keep the sand from tearing up the bearings.
After reading all of these posts, it seems the simplest solution would be to mount an ATV winch to a post. Then take the post to the top of the hill, bury the other end of it an inch or two in the ground with it angled "uphill" and have guy wires, two of them, like you would when putting up a cheap dining shelter you can get a Wal-Mart. Use a 12V battery to power the winch and a remote switch to operate it.
This is a totally portable system, the mechanism is kept out of the water, and there are no powered "vehicles" on the beach.
With a little bit of experimentation this could be worked out.
Nick
Current Boat Looking for one
311
guests, and 359
