ALUMINUM SUPPLY SOURCE? #59068
10/14/05 05:03 PM
10/14/05 05:03 PM
South Florida & the Keys
arbo06 Offline OP
arbo06  Offline OP
Can anyone give me the name and or number of a company that can provide me with aluminum tubing / pipe suitable for beams?
Thanx in advance....
Eric
Jolly Roger
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: ALUMINUM SUPPLY SOURCE? [Re: arbo06] #59069
10/14/05 05:36 PM
10/14/05 05:36 PM
Re: ALUMINUM SUPPLY SOURCE? [Re: Robi] #59070
10/14/05 06:45 PM
10/14/05 06:45 PM
arbo06 Offline OP
arbo06  Offline OP
Thanx Robes....
i am going doublewide!
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: ALUMINUM SUPPLY SOURCE? [Re: Robi] #59071
10/14/05 09:34 PM
10/14/05 09:34 PM
BobG Offline
BobG  Offline
I put the Ims leed on the Delray site a little late though I see. Good job Wilder I did'nt even know about the company right under our noses here in Delray. I like the site with anodized colours and paint choices thats off the hook.
Re: ALUMINUM SUPPLY SOURCE? [Re: arbo06] #59072
10/14/05 09:38 PM
10/14/05 09:38 PM
BobG Offline
BobG  Offline
Eric
Jolly Roger
I think tubing is square and piping is round or is it tubing is measured from the inside diameter and piping is the exterior diameter,better check before you end up with 40ft of the square stuff
Re: ALUMINUM SUPPLY SOURCE? [Re: BobG] #59073
10/14/05 09:42 PM
10/14/05 09:42 PM
BobG Offline
BobG  Offline
Can I answer this on all three forums in duplicate Eric? Somebody buy my I17 please,Nudge,nudge ,wink,wink includes shrimp net!
Re: ALUMINUM SUPPLY SOURCE? [Re: BobG] #59074
10/14/05 10:03 PM
10/14/05 10:03 PM
Hey Erick I am carless right now, but if you need any help let me know. I would not mind helping you out with this project at all. Sounds like fun.
And seriously dont thank me for the sites, thank google.
Re: ALUMINUM SUPPLY SOURCE? [Re: BobG] #59075
10/15/05 11:26 AM
10/15/05 11:26 AM
Québec, Canada
CharlesLeblanc Offline
Québec, Canada
Eric
Jolly Roger
Hi there, I work in an fabrication shop and I order both tubing and pipe on a regular basis.
Pipe: Round section (duh!), measured with the inside diameter but around 10", the measure becomes outside diameter. Pipe is designed to carry fluids (liquid, gases, vapor).
Therer are a few wall thickness but for aluminium, I think that you can only have Ced 20, Ced 40 and Ced 80. Pipe can be purchase at an industrial plumbing supply. Finally, there are fittings available for Pipes ,like elbow and flanges.
Tubing is designed for a mechanical or structural purpose. It havee round, square or rectangular sections. It is also called HSS for Hollow structural section or mechanical tubing.
The dimension are always quoted for the outside wall. You can quote the structural pipe with ED-ID or ED-WT where ED is exterior diameter, ID interior diameter and WT is wall thickness.
These is one major exception: Hydraulic system use tubing instead of pipe and it is quoted by the external diameter and the wall thickness.
One last thing: All pipes are usually available in 21 feet length and mechanical tubing is usually available in 24 feet length.
NEVER WELD AN ALUMINIUM CROSSBEAM IN THE MIDDLE. The aluminium is usually 6061T6 alloy and it looses 40% of it strength at the weld. If you have to weld a crossbeam, have a continuous central section and extend it on both sides.
You can purchase Structural tubing at your local industrial steel supplier
Price wise, they are about the same price but the piping is quoted be the foot and structural steel is quoted by the pound.
One last thing: You can also purchase a raw mast extrusion. or a used mast. This will allow you to have a build it rail for your trampoline.
I have also saw peoples using light poles but the wall are very thick and they have to be machined. It might be an idea for a much larger boat.
Charles Leblanc Nacra 5.2 #26
Re: ALUMINUM SUPPLY SOURCE? [Re: CharlesLeblanc] #59076
10/15/05 11:38 AM
10/15/05 11:38 AM
I have two H17 mast extrusions that would be suitable for this purpose.
One is punctured right below the sail track. The other is bent about 3' from the end of the extrusion. Either one would give you more than enough for two 10' beams.
12 Foot [Re: MauganN20] #59077
10/15/05 03:55 PM
10/15/05 03:55 PM
cyberspeed Offline
cyberspeed  Offline
the length is 12' X 2 not 10'. If you are going wide, you might as well do it right.
craig van eaton
Supercat 20
TEAM CYBERSPEED
www.TeamCyberspeed.com
Endurance Series
www.SailSeries.com
Re: 12 Foot [Re: cyberspeed] #59078
10/15/05 07:28 PM
10/15/05 07:28 PM
arbo06 Offline OP
arbo06  Offline OP
Correct....
Eric Arbogast
ARC 2101
Miami Yacht Club
