| Re: Nacra traveler car and track replacement
[Re: DougSkinner]
#59377 10/19/05 12:15 AM 10/19/05 12:15 AM |
Posts: 364 | I'd never go that short unless the boat was ALWAYS to be sailed with a spinnaker. I sailed a 5.O for a couple years, and you need all the traveller track it comes with. Good luck.
Andrew Tatton
Nacra 20 "Wiggle Stick" #266
Nacra 18 Square #12
[Re: DougSkinner]
#59380 10/19/05 08:17 PM 10/19/05 08:17 PM |
Posts: 623 Gulf Coast | Keep the length, as has been said. Go with the Harken track and traveler car: http://store.catsailor.com/tek9.asp?pg=products&specific=jndmfrpok0(that should be one line) In any case, right here in Cat Sailor City, you can go to the store, do a search for 'traveler track' and get a page with a listing of various tracks. Pick the best for your specifications. If in doubt, go bigger. Do the same for 'traveler car'. Good luck Connection: close with it. At least there are lots of convenient holes drilled in your beam so you can undo the screws... imagine trying to reach something to the centre of the crossbar, whoo hoo! | | | Re: Nacra traveler car and track replacement
[Re: DougSkinner]
#59381 10/20/05 02:38 AM 10/20/05 02:38 AM |
Posts: 4,451 West coast of Norway | I wasn't looking forward to setting and tightening all the nuts and screws through the beam on a longer track. Oh well, it'll give me something to do. It's not to difficult. Just tape your tool of choice (i prefer pipes) to a stiff batten. It's easier if you can get a friend to help you, but I have done it alone. A small bit of double sided tape in the bottom of the pipe holds the nut in place while you are turning the bolt/screw. Locksafe nuts are preferred, and if you can find them, some sturdy nylon washers. If you dont find the right washers, you are probably better off without. Rolf, if I make to Scandinavia next summer, maybe I could meet you and go sailing.
Sure, just let me know when you are in the area. You should not visit Namdalen without seeing the area I live in (Romsdal/Molde). You would get the completely wrong picture of coastal Norway. http://www.namdalen.com/ http://www.visitmolde.com/ http://www.romsdalsalpene.com/
[Re: Rolf_Nilsen]
#59382 10/20/05 06:48 AM 10/20/05 06:48 AM |
Posts: 12,310 South Carolina | Some of the older Nacras have holes in the underside of the beam for getting some sort of implement in there to the nuts. It shouldn't be too tough once you work out what kind of tool you need.
Jake Kohl | | | Re: Nacra traveler car and track replacement
#59383 10/20/05 05:27 PM 10/20/05 05:27 PM |
Joined: Apr 2005 Posts: 473 Panama City, Florida Redtwin
Posts: 473 Panama City, Florida | My 5.2 is a 1980 model and it has the holes... very convenient.
-Rob V. Panama City Rob V.
Nacra 5.2
Panama City | | |
526
guests, and 564
