| Re: Safety and the Full Harness
[Re: Tracie]
#5995 04/05/02 07:29 AM 04/05/02 07:29 AM |
Posts: 12,310 South Carolina | What would be nice (be it for man or woman) is a lifejacket that's built into a harness or the other way around. (Murray's, Gul, ... you listening?).
Jake Kohl | | | Re: Safety and the Full Harness
[Re: samevans]
#5997 04/05/02 08:29 AM 04/05/02 08:29 AM |
Posts: 2,844 42.904444 N; 88.008586 W | I wear the Murray's sit Racing harness, with a spreader bar, and no other keeper for the dogbone/trap line. It's also crotchless. It has the vertical batten-like strips paralleling your spine. It is soooo comfortable. It would be easy to get off in an emergency.
I have let many borrow it thatr have the full harness and they can;t believe how comfortable it is. I've been on the wire for hours at a time, no problem. IMHO, full harnesses are not more comfortable, are bulky, too hot in warm weather, etc.
F-18 Infusion #626- SOLD it!
[Re: Todd_Sails]
#5998 04/05/02 09:11 AM 04/05/02 09:11 AM |
Posts: 1,459 Annapolis,MD | I guess I've always thought it would be easier to cut the trap line if it was stuck on my harness hook. The lower part of my traps going to the dogbones are line, not wire, as I suspect most are. For the range of motion needed to get out of most harnesses (over or under the vest) I've also thought through cutting the webbing on the harness to release the buckle. I keep my safety knife mounted to my vest where I can get it one-handed with either hand.
Of course, probably the real danger of the harness is that the hook can get inadvertantly caught on anything when you capsize, not necessarily being hooked in to the traps.
My brush with this was a pitchpole in which a sheet wrapped my ankle. I easily unwrapped it but it was enough to make me think about it!
In the recent Sportscar magazine (SCCA monthly rag), there's an article that talks about being mentally prepared for what happens and what to do during and after an accident. Once things begin to go wrong, your actions may make a difference between life and death. Thinking through these situations and what you might do in response to them before hand may help you make the right decisions with less panicking if doo-doo does happen. Perhaps this a good lesson for sailors too.
I too like the idea of a combined vest and harness. Except that if you do need to get out of your harness, you'd lose your flotation as well. It would need a way to release the buckle/hook without compromising the function of the vest. | | | Re: Safety and the Full Harness
[Re: H17cat]
#6001 04/05/02 09:28 AM 04/05/02 09:28 AM |
Joined: Jul 2001 Posts: 397 Burlington, Vermont USA Kevin Rose
Posts: 397 Burlington, Vermont USA | Prior to taking up sailing, the majority of my "on-water" time was in a kayak. A common piece of equipment carried by paddlers is the rescue knife. The blade is designed to quickly cut one's way out of an entanglement (including the boat itself). I always carry one in the front pocket of my PFD, attached by a tether (I'd hate to drop it in a time of need). The other carry-over from kayaking is the PFD that I use. In recent years, paddlers' PFD's have evolved into models that keep the flotation high on the chest, unlike the older, longer waisted models. (A kayaker needs a PFD that rides well above the sprayskirt.) ![[Linked Image]](http://a248.e.akamai.net/f/248/2630/1h/www.patagonia.com/images/store/products/regular/L1001_391.jpg) The new designs also include much larger arm holes for superior arm mobility. While I only wear a half harness, I find that the Lotus Designs Sherman vest that I wear does not interfere with the spreader, is very comfortable, and does not appear to pose any safety issues. (If one does rear its head, I've got the knife!) Cheers,
Kevin Rose
N6.0na #215
Lake Champlain (New England's "west coast")
Burlington, Vermont
[Re: Keith]
#6002 04/05/02 09:42 AM 04/05/02 09:42 AM |
Posts: 12,310 South Carolina | Keith,
I have always understood that a majority of the trapeze hook getting lodged in something problem is related TO the bouyancy in the life vest making it difficult to unhook when under the water. No while I certainly wouldn't want to be out in the ocean with out a vest, I think that once I got unhooked and got some air, I could find a way to get the vest back on. Not sure the coast guard would feel the same way though!
#6003 04/05/02 10:35 AM 04/05/02 10:35 AM |
Posts: 397 Burlington, Vermont USA | Jake, After countless hours if leading/observing groups of paddlers on the ocean, I've seen a few mishaps unfold (all with happy endings ![[Linked Image]](/forums/images/icons/smile.gif) ). Experience has shown that once things begin to go wrong, it has a tendency to snowball. With the kayak, I've always taught, "NEVER let go of the boat" and "NEVER take off the PFD." The way that things seem to go wrong, I would not want to take the risk of having the boat and/or the PFD blow out of reach. (I never allow participants in my groups to even paddle with the PFD unzipped.)
Kevin Rose
N6.0na #215
Burlington, Vermont
[Re: Tracie]
#6005 04/05/02 03:45 PM 04/05/02 03:45 PM |
Posts: 371 Michigan, USA | Tracie,
I wear my life vest (Lotus kayak vest) under my harness and then clip the harness shoulder straps into the strap that is the closure for the vest pocket. This pocket closure is a vertical strap with a plastic male clip on it that clips into the female end of the clip attached to the vest. The harness straps come straight up from the spreader, the right strap comes to left of the female clip and over the right shoulder. Then the left harness strap comes to the right of the female clip and over the left shoulder. I then slide the male clip into the female clip which closes the pocket and keeps the harness shoulder straps from sliding off the shoulders. That pocket is in the center of the vest. It is all very comfortable and when trapezing, I can lay completely back and have my shoulders supported, my weight evenly distributed over harness. I hope this is helpful.
Les Gallagher
[Re: H17cat]
#6006 04/05/02 11:23 PM 04/05/02 11:23 PM |
Posts: 283 | Without a doubt, a river or diving knife should be standard equipment for any catamaran sailor. I never thought so until my harness hook caught on the hiking strap of my 20 as I was capsizing. The boat started to get pulled over on me, and luckily the mast stuck in the bottom before I could be trapped under water.
Very scary! I now have a Gerber River Guide knife strapped to my harness, and like knowing it's there!
Fair winds,
Tim J.
Tim D. Johnson
Hobie 20 #690
Bald Eagle Yacht Club, Fleet 52
www.beyc.org | | | Re: Safety and the Full Harness
[Re: hobie541]
#6007 04/06/02 12:59 AM 04/06/02 12:59 AM |
Joined: Jun 2001 Posts: 733 Home is where the harness is..... Will_R
Posts: 733 Home is where the harness is..... | I like as much of my gear to fit tightly as possible, so as not to get caught on lines or other stuff. I wear an Extrasport Excaliber (side zip) OVER my Magic Marine/Aquata Equipe' full harness. This harness has almost nothing for lines to hang on, but fits sooooooo tight, that no matter what I do, there is NO way that I'm comming out of it easily. (I have to do this little dance to get into it (with the straps loose) and a weird sort of reverse wiggle dance on the beach to get it off. There is no in or out of this harness with the straps tight. There are four straps to tighten/loosen to get it on/off. It really is the BEST harness that I've found (most comfortable/supportive).
I don't see any safety reason for wearing it anyother way. The hook is fairly low profile and not hard to clear. I like useing SS rings instead of any other sort of hooks (dogbones, can't hurt's, can't miss...etc) They take some getting used to, but once you get if figured out, it is so nice. Lines don't get caught or tangled on them, they stay out of the way and easy to clear off the hook.
I make a conscious effort to make sure that no lines are wrapped around ANY part of me (excluding hands) while sailing. Do a lot of "house cleaning"... very important for not getting tied up. I was trapped once under a sunfish once... yeah, I know... only has one line, but... I was tangled up there anyway. Now, I carry a big honk'n Merchin (spelling?) safety/dive knife. I've only had to use it once, but..... who knows when I will have to again. You know what they say, "be prepared"
Will | | | Reprecussions of Will's "Wiggle Dance"
[Re: Will_R]
#6010 04/07/02 11:21 AM 04/07/02 11:21 AM |
Posts: 3,293 Long Beach, California | I've seen Will's little "wiggle dance" on the beach before. The Department of Fish and Wildlife have contacted him directly to get him to dress in more privacy, as his "wiggle dance" has thrown the entire bee population into confusion.
Charles Harp, with the Florida DEP, had this to say:
"It's the damnedest thing - apparently, this movement closely emulates the dance executed by drones in the local bee poulation to communicate with the rest of the hive. As near as we can tell, Will's frenetic body movements when he's getting dressed for a race roughly translate to 'I am with Local 475 - there is a four-acre field of Black-eyed-Susans at 16 degrees to the current solar azimuth. Look for the hot dog vendor and turn left.' These directions are, of course, totally bogus. There hasn't been a hot dog vendor on the beach in years."
Alger Letson, a bee enthusiast and apiary owner in Milton, is considering legal action.
"Dammit - my bees is gone! They's last seen up in Flomaton headed northwest! I demands reparations! There's no honey in th' pot and that ain't funny!"
Will could not be reached for comment.
273
guests, and 37
