Safety and the Full Harness #5993
04/05/02 01:45 AM
04/05/02 01:45 AM
Issaquah, WA, USA
H17cat Offline OP
H17cat  Offline OP
Issaquah, WA, USA
I have been wearing my full harness inside my life jacket. In view of recent near accidents, I would like to hear comments about best way to wear the full harness. Initial comments seem to be to wear the full harness over the life jacket, to make it easier to get out if fouled or trapped under the boat.
Caleb Tarleton
Re: Safety and the Full Harness [Re: H17cat] #5994
04/05/02 06:38 AM
04/05/02 06:38 AM
Hampton, Virginia
Tracie Offline
Tracie  Offline
Hampton, Virginia
Good question.
I too wear my full harness under my life jacket. Oddly enough, my worst fear in regards to cat sailing is getting tangled and/or trapped in the lines during a capsize, and until you posted this, I had not thought of wearing my life jacket under the harness.
It makes complete sense. The fastener for the harness is resting under your life jacket. If in trouble, you'd either have to remove the jacket then release the harness buckle, or try to wiggle your way off the trapezze line...which might not be at all possible either.
The reason I wear my life jacket on top of my harnesss is to get a better fit. The shoulder straps on my harness seem to slide off my shoulders no matter how I adjust it.
This brings up another question. Are there harnesses made specifically for women? I've not seen any.
Tracie
Re: Safety and the Full Harness [Re: Tracie] #5995
04/05/02 07:29 AM
04/05/02 07:29 AM
What would be nice (be it for man or woman) is a lifejacket that's built into a harness or the other way around. (Murray's, Gul, ... you listening?).
Re: Safety and the Full Harness [Re: Jake] #5996
04/05/02 08:05 AM
04/05/02 08:05 AM
samevans Offline
samevans  Offline
I wear my harness over my lifejacket because it makes it easier to reach the hook with the trap bone and it doesn't push the lifejacket up.
Re: Safety and the Full Harness [Re: samevans] #5997
04/05/02 08:29 AM
04/05/02 08:29 AM
42.904444 N; 88.008586 W
Todd_Sails Offline
Todd_Sails  Offline
I wear the Murray's sit Racing harness, with a spreader bar, and no other keeper for the dogbone/trap line. It's also crotchless. It has the vertical batten-like strips paralleling your spine. It is soooo comfortable. It would be easy to get off in an emergency.
I have let many borrow it thatr have the full harness and they can;t believe how comfortable it is. I've been on the wire for hours at a time, no problem. IMHO, full harnesses are not more comfortable, are bulky, too hot in warm weather, etc.
F-18 Infusion
#626- SOLD it!
Re: Safety and the Full Harness [Re: Todd_Sails] #5998
04/05/02 09:11 AM
04/05/02 09:11 AM
Annapolis,MD
Keith Offline
Keith  Offline
Annapolis,MD
I guess I've always thought it would be easier to cut the trap line if it was stuck on my harness hook. The lower part of my traps going to the dogbones are line, not wire, as I suspect most are. For the range of motion needed to get out of most harnesses (over or under the vest) I've also thought through cutting the webbing on the harness to release the buckle. I keep my safety knife mounted to my vest where I can get it one-handed with either hand.
Of course, probably the real danger of the harness is that the hook can get inadvertantly caught on anything when you capsize, not necessarily being hooked in to the traps.
My brush with this was a pitchpole in which a sheet wrapped my ankle. I easily unwrapped it but it was enough to make me think about it!
In the recent Sportscar magazine (SCCA monthly rag), there's an article that talks about being mentally prepared for what happens and what to do during and after an accident. Once things begin to go wrong, your actions may make a difference between life and death. Thinking through these situations and what you might do in response to them before hand may help you make the right decisions with less panicking if doo-doo does happen. Perhaps this a good lesson for sailors too.
I too like the idea of a combined vest and harness. Except that if you do need to get out of your harness, you'd lose your flotation as well. It would need a way to release the buckle/hook without compromising the function of the vest.
Re: Safety and the Full Harness [Re: Tracie] #5999
04/05/02 09:12 AM
04/05/02 09:12 AM
Wilmington,NC
Dlennard Offline
Dlennard  Offline
Wilmington,NC
Tracie
I used to have that problem now I put on my full harness (don't hook up the front straps)and then put on my life jacket(put the life jacket under the front harness straps)and hook up and tighten the front harness straps. Wearing it this way the harness straps don't fall off your sholders and the life jacket does not ride up around your neck and you can see to hook up on the wire better. If you don't understand this I will show you next time I see you.
David Lennard
Re: Safety and the Full Harness [Re: Dlennard] #6000
04/05/02 09:27 AM
04/05/02 09:27 AM
Texas
majsteve Offline
majsteve  Offline
Texas
I wear my harness over my vest and a camelbak over the lot. On the camelbak I keep my strobe, knife and gps. I have found that if I need to get free all I have to do is bend forward and the hook collapses into my body and I float back up to the surface. To unhook in a weird position all I have to do is relax and straighten out. Once clear Ijust place my hand over the hook and I can swim clear.
I crashed my boat hard once breaking a few ribs. The post mortem done by my doctor said that I probably would have had more serious injuries had my gear not absorbed most of the punishment. The vest is trashed and now hangs on the wall as a reminder.
In short the most important thing to remember when everything starts to go wrong is to RELAX AND THINK -- Panic kills.
Steve
Re: Safety and the Full Harness [Re: H17cat] #6001
04/05/02 09:28 AM
04/05/02 09:28 AM
Burlington, Vermont USA
K
Kevin Rose Offline
Kevin Rose  Offline
K
Prior to taking up sailing, the majority of my "on-water" time was in a kayak. A common piece of equipment carried by paddlers is the rescue knife. The blade is designed to quickly cut one's way out of an entanglement (including the boat itself). I always carry one in the front pocket of my PFD, attached by a tether (I'd hate to drop it in a time of need).
The other carry-over from kayaking is the PFD that I use. In recent years, paddlers' PFD's have evolved into models that keep the flotation high on the chest, unlike the older, longer waisted models. (A kayaker needs a PFD that rides well above the sprayskirt.)
The new designs also include much larger arm holes for superior arm mobility.
While I only wear a half harness, I find that the Lotus Designs Sherman vest that I wear does not interfere with the spreader, is very comfortable, and does not appear to pose any safety issues. (If one does rear its head, I've got the knife!)
Cheers,
Kevin Rose N6.0na #215 Lake Champlain (New England's "west coast") Burlington, Vermont
Re: Safety and the Full Harness [Re: Keith] #6002
04/05/02 09:42 AM
04/05/02 09:42 AM
Keith,
I have always understood that a majority of the trapeze hook getting lodged in something problem is related TO the bouyancy in the life vest making it difficult to unhook when under the water. No while I certainly wouldn't want to be out in the ocean with out a vest, I think that once I got unhooked and got some air, I could find a way to get the vest back on. Not sure the coast guard would feel the same way though!
Re: Safety and the Full Harness [Re: Jake] #6003
04/05/02 10:35 AM
04/05/02 10:35 AM
K
Kevin Rose Offline
Kevin Rose  Offline
K
Jake,
After countless hours if leading/observing groups of paddlers on the ocean, I've seen a few mishaps unfold (all with happy endings [Linked Image]). Experience has shown that once things begin to go wrong, it has a tendency to snowball. With the kayak, I've always taught, "NEVER let go of the boat" and "NEVER take off the PFD." The way that things seem to go wrong, I would not want to take the risk of having the boat and/or the PFD blow out of reach. (I never allow participants in my groups to even paddle with the PFD unzipped.)
Re: flotation in the right place [Re: Kevin Rose] #6004
04/05/02 11:17 AM
04/05/02 11:17 AM
samevans Offline
samevans  Offline
The other advantage to the kayak style of lifevests is that the flotation is lower down. It lifts your body higher in the water. Flotation above your chest does very little good. People have drowned IN lifevests. Many mfgs are making vests with strap or mesh shoulders.
Re: Safety and the Full Harness [Re: Tracie] #6005
04/05/02 03:45 PM
04/05/02 03:45 PM
Michigan, USA
sparky Offline
sparky  Offline
Michigan, USA
Tracie,
I wear my life vest (Lotus kayak vest) under my harness and then clip the harness shoulder straps into the strap that is the closure for the vest pocket. This pocket closure is a vertical strap with a plastic male clip on it that clips into the female end of the clip attached to the vest. The harness straps come straight up from the spreader, the right strap comes to left of the female clip and over the right shoulder. Then the left harness strap comes to the right of the female clip and over the left shoulder. I then slide the male clip into the female clip which closes the pocket and keeps the harness shoulder straps from sliding off the shoulders. That pocket is in the center of the vest. It is all very comfortable and when trapezing, I can lay completely back and have my shoulders supported, my weight evenly distributed over harness. I hope this is helpful.
Les Gallagher
Re: Safety and the Full Harness [Re: H17cat] #6006
04/05/02 11:23 PM
04/05/02 11:23 PM
hobie541 Offline
hobie541  Offline
Without a doubt, a river or diving knife should be standard equipment for any catamaran sailor. I never thought so until my harness hook caught on the hiking strap of my 20 as I was capsizing. The boat started to get pulled over on me, and luckily the mast stuck in the bottom before I could be trapped under water.
Very scary! I now have a Gerber River Guide knife strapped to my harness, and like knowing it's there!
Fair winds,
Tim J.
Tim D. Johnson Hobie 20 #690 Bald Eagle Yacht Club, Fleet 52 www.beyc.org
Re: Safety and the Full Harness [Re: hobie541] #6007
04/06/02 12:59 AM
04/06/02 12:59 AM
Will_R Offline
Will_R  Offline
I like as much of my gear to fit tightly as possible, so as not to get caught on lines or other stuff. I wear an Extrasport Excaliber (side zip) OVER my Magic Marine/Aquata Equipe' full harness. This harness has almost nothing for lines to hang on, but fits sooooooo tight, that no matter what I do, there is NO way that I'm comming out of it easily. (I have to do this little dance to get into it (with the straps loose) and a weird sort of reverse wiggle dance on the beach to get it off. There is no in or out of this harness with the straps tight. There are four straps to tighten/loosen to get it on/off. It really is the BEST harness that I've found (most comfortable/supportive).
I don't see any safety reason for wearing it anyother way. The hook is fairly low profile and not hard to clear. I like useing SS rings instead of any other sort of hooks (dogbones, can't hurt's, can't miss...etc) They take some getting used to, but once you get if figured out, it is so nice. Lines don't get caught or tangled on them, they stay out of the way and easy to clear off the hook.
I make a conscious effort to make sure that no lines are wrapped around ANY part of me (excluding hands) while sailing. Do a lot of "house cleaning"... very important for not getting tied up. I was trapped once under a sunfish once... yeah, I know... only has one line, but... I was tangled up there anyway. Now, I carry a big honk'n Merchin (spelling?) safety/dive knife. I've only had to use it once, but..... who knows when I will have to again. You know what they say, "be prepared"
Will
Try these on for size [Re: Will_R] #6008
04/06/02 12:47 PM
04/06/02 12:47 PM
Texas
majsteve Offline
majsteve  Offline
Texas
I just dug out my old extraction gear and found a pair of extraction "sheers" there are more like pliers but are spring loaded and in a few tests I have cut through everything that you could think of on a boat. Lines, stays, hiking straps (I have a bunch of old boat parts here) -- they cut them all like butter.
Since they are stainless (mostly) they should live forever. I'll try to find a link to the manufacturer. But memory tells me that they were about $40. Cheap compared to a good knife.
I'll keep ya posted.
Steve
Re: Try these on for size [Re: majsteve] #6009
04/06/02 12:48 PM
04/06/02 12:48 PM
Texas
majsteve Offline
majsteve  Offline
Texas
Yes they have a lanyard and a holster (nylon/velcro)
Steve
Reprecussions of Will's "Wiggle Dance" [Re: Will_R] #6010
04/07/02 11:21 AM
04/07/02 11:21 AM
I've seen Will's little "wiggle dance" on the beach before. The Department of Fish and Wildlife have contacted him directly to get him to dress in more privacy, as his "wiggle dance" has thrown the entire bee population into confusion.
Charles Harp, with the Florida DEP, had this to say:
"It's the damnedest thing - apparently, this movement closely emulates the dance executed by drones in the local bee poulation to communicate with the rest of the hive. As near as we can tell, Will's frenetic body movements when he's getting dressed for a race roughly translate to 'I am with Local 475 - there is a four-acre field of Black-eyed-Susans at 16 degrees to the current solar azimuth. Look for the hot dog vendor and turn left.' These directions are, of course, totally bogus. There hasn't been a hot dog vendor on the beach in years."
Alger Letson, a bee enthusiast and apiary owner in Milton, is considering legal action.
"Dammit - my bees is gone! They's last seen up in Flomaton headed northwest! I demands reparations! There's no honey in th' pot and that ain't funny!"
Will could not be reached for comment.
Re: Safety and the Full Harness [Re: Tracie] #6011
04/07/02 08:55 PM
04/07/02 08:55 PM
brobru Offline
brobru  Offline
Traci,
I just recieved a new harness from Layline,..it is a MUSTO full harness with velcro around the upper thighs,.....the crotchless design,....it is infinately adjustable to all dimensions,.....cost with bar is $129.00
Best in comfort and support on the line,...I was shocked
Drawback,...the 'butt'material does NOT grab the tramp,...it "slides' ,....gonna have to sew on some leather.
Bruce
St. Croix
Re: Safety and the Full Harness [Re: Keith] #6012
04/07/02 08:59 PM
04/07/02 08:59 PM
brobru Offline
brobru  Offline
Kieth,
On the beach resently, another cat sailor walked up and we started talking as I was putting away the boat,...he told me about the time a crew got her harness hook caught on the tramp webbing,...it scared him so bad he went to a 'ball and socket' harness syetem,....but I do not see these around anymore,......you are right,..it is a potential nightmare..
Bruce
St. Croix
( especially when you have a 1 man boat..)
0 registered members (), 288 guests, and 46 spiders.
