snail snuffer system #61357
11/21/05 10:55 AM
11/21/05 10:55 AM
ms/fl
fuzzy Offline OP
fuzzy  Offline OP
ms/fl
Anybody have any experience with the snail snuffer system.....where can I see one, how much, etc.....Im in the US..........thanks
A-class #19
Re: snail snuffer system [Re: fuzzy] #61358
11/21/05 11:51 AM
11/21/05 11:51 AM
http://www.marstrom.com/item_show.asp?code_no=M750
http://www.sailmaker.info/tornado.html
If you read the above, you should also know that what Martin and Kristian brought to Athens was a Graham Eeles tube.
Re: snail snuffer system [Re: fuzzy] #61359
11/21/05 12:52 PM
11/21/05 12:52 PM
Andrew Offline
Andrew  Offline
Some guys in Houston yesterday (sorry, no names, but maybe the tcdyc.com guys will know) said Goran had come over and set up 5 Marstroms with snails, maybe in Fl and the East coast. Sorry I can't be more helpful...try 1design.net as well, they're specific to the FL area.
Re: snail snuffer system [Re: fuzzy] #61360
11/21/05 01:58 PM
11/21/05 01:58 PM
Carla at Coconut Grove Sailing has one on her M20.
My experience using the snail snuffer [Re: fuzzy] #61361
11/21/05 03:03 PM
11/21/05 03:03 PM
North Europe, Sweden, Uppsala
Hakan Frojdh Offline
I've been using a snail snuffer system on my A-class during one season. I've used it during roughly 30 sailing days. I logged an average of 30 Nm each day and I hoisted the spi roughly 5-10 times each trip.
I've heard rumours about wear and tear on the spi. The only fact about wear and tear is from the Tornado homepage that was refered to earlier in this thread. My own experience on wear and tear is that I had no problem at all. As long as the spi doesn't get squeezed against the inside of the snail this system is much kinder to the spi than a normal snuffer.
If you have an uni rigged boat the snail is a good choice, you an mount the snail close to the mast which gives you low drag and good weight distribution. If you have a jib I would recommend a standard snuffer, bag or tube.
You can check this homepage for more details on the snail.
http://www.webbo.dyndns.org/a-cat_sailing/spi/
/hakan
Re: snail snuffer system [Re: MauganN20] #61362
11/21/05 03:28 PM
11/21/05 03:28 PM
League City, TX
flumpmaster Offline
flumpmaster  Offline
League City, TX
I spoke with Carla's husband at the Tornado Nationals this weekend and asked him about the Snail - he said it was working very well for them and they loved the reduction in windage vs. a hoop and bag.
My only other data point was a comment from a leading F18 sailor who had raced in a portsmouth class against an A-Cat with the snail - he said the only reason he caught the A-Cat was that about half the sets or take downs seemed to screw up.
Perhaps it takes some learning but once mastered is a viable alternative to more conventional snuffer systems.
Chris.
Re: My experience using the snail snuffer [Re: Hakan Frojdh] #61363
11/21/05 03:35 PM
11/21/05 03:35 PM
Atlanta
bvining Offline
bvining  Offline
Atlanta
Hakan,
Can you post a or two picture of the inside of the snail without the spin in it?
Thanks
Bill
Re: My experience using the snail snuffer [Re: bvining] #61364
11/21/05 03:49 PM
11/21/05 03:49 PM
Kristian and Martin had the snail in front of the jib, that might have added to the wear on the spi..
Re: My experience using the snail snuffer [Re: Hakan Frojdh] #61365
11/22/05 01:52 PM
11/22/05 01:52 PM
ms/fl
fuzzy Offline OP
fuzzy  Offline OP
ms/fl
Id like to see some detail pictures of the inside of the snail..
A-class #19
Re: My experience using the snail snuffer [Re: fuzzy] #61366
11/30/05 11:33 AM
11/30/05 11:33 AM
Atlanta
bvining Offline
bvining  Offline
Atlanta
inside the snail
0 registered members (), 321 guests, and 55 spiders.
