Infusion on Video #62365
12/05/05 03:39 PM
12/05/05 03:39 PM
uk
TEAMVMG Offline OP
TEAMVMG  Offline OP
uk
The video of the prototype INFUSION is at http://www.nacraeurope.com/news_details.php?id=5
Re: Infusion on Video [Re: TEAMVMG] #62366
12/05/05 04:01 PM
12/05/05 04:01 PM
Is anyone going to distribute a polar chart for this boat?
Also, when watching the spinnaker portion of the video, I noticed the bows were out of the water most of the time. Is this the proper boat trim for this model?
Re: Infusion on Video [Re: waterbug_wpb] #62367
12/05/05 05:13 PM
12/05/05 05:13 PM
Of course I have no first hand knowledge of the Infusion F18, but I can tell you that the other Flyer A-cat inspired boats like the Capricorn F18, Blade F18 and Blade F16 are all reported to be sailed best under spinnaker with the bow out of the water. This appears to make them faster. It was not expected, nor envisioned during the design stages, but in real life testing it proved to work well. Some people think it has something to do with the "reduced volume in the wvepiercer bows", but actually the bouyancy was never reduced here; if anything it was increased. The explanations are still various. Some say the wide keels allow planing others say that it reduces pitching even more because the wave contact the hulls rather away from the bows. There is no concensus apart from the fact that these new hulls like to be sailed out of the water with their bows when sailing at speed under their spinnaker.
Maybe it is just a way to reduce wetted surface area because the new hullshapes depress their sterns much less than the older shapes and thus suffer only a mild penalty in wave-making drag. More testing and theorizing is required
Re: Infusion on Video [Re: TEAMVMG] #62368
12/05/05 05:14 PM
12/05/05 05:14 PM
looks pretty seksy to me.
looks kinda wet too. I was looking for the "wave-piercing" effect that Jake referenced in the other thread, and you can see it in this video where they'd ride up one wave and just plow through the next.
Pretty cool.
Re: Infusion on Video [Re: MauganN20] #62369
12/05/05 06:09 PM
12/05/05 06:09 PM
Well, I guess it doesn't have "displacement" hulls in the traditional sense where waterline governs speed... But I'm far from being any sort of engineer...
Re: Infusion on Video [Re: TEAMVMG] #62370
12/05/05 09:13 PM
12/05/05 09:13 PM
Hey....I recognize that flowery red rash guard...nice form Dan!
I also really like what they've done with the fairing just before the main beam. It grates my nerves when I can feel water smashing into the front beam on most other catamarans including the I20.
Re: Infusion on Video [Re: Jake] #62371
12/05/05 11:47 PM
12/05/05 11:47 PM
Darryl_Barrett Offline
Having the bows out with spinnaker relieves the helm, makes it more responsive to steering (less likely to lee helm as well) and just seems to go faster with less likelyhood of "pitching" if the bows are driven through the water.
Re: Infusion on Video [Re: Jake] #62372
12/06/05 08:41 AM
12/06/05 08:41 AM
Yeha jake,
now instead of splashing up into the air, its redirected straight into your eyes!
Re: Infusion on Video [Re: Darryl_Barrett] #62373
12/06/05 09:23 AM
12/06/05 09:23 AM
Darryl.
The first part seems natural, as you effectively rake the rig more aft.
The "go faster" bit, wouldn't that be largely dependent on the type of hull you have? Would this be valid for eg. the Mosquitos and Tornados also?
I have a DVD, with among others, Mitch and Herbie sailing their T. I always tought they had their weight rather far aft, but perhaps you just pointed out why to me..
Re: Infusion on Video [Re: Rolf_Nilsen] #62374
12/07/05 10:02 PM
12/07/05 10:02 PM
2017 F18 Americas Site
Dan_Delave Offline
Dan_Delave  Offline
I was sailing the boat in the video. I was crewing for Pete Melvin. I am in the red rash guard.
Dan
Re: Infusion on Video [Re: Dan_Delave] #62375
12/08/05 12:42 PM
12/08/05 12:42 PM
uk
TEAMVMG Offline OP
TEAMVMG  Offline OP
uk
Dan, what were Petes thoughts on the boat? I know he is only going to be possitive, but as someone who has one on order, I am after all the info I can get.
How did it compare to the F18 that you were trialing with?
Are we to see pete on the European F18 circuit this season?
Re: Infusion on Video [Re: MauganN20] #62376
12/08/05 01:19 PM
12/08/05 01:19 PM
Not if your windward hull is skimming the water like it's supposed to.
Re: Infusion on Video [Re: TEAMVMG] #62377
12/08/05 02:23 PM
12/08/05 02:23 PM
US Western Continental Shelf
hobiegary Offline
hobiegary  Offline
I have not been able to access the video or the nacraeurope web site. Is there another location where I may access this video?
Thanks,
GARY
Santa Monica Bay
Re: Infusion on Video [Re: hobiegary] #62378
12/08/05 03:16 PM
12/08/05 03:16 PM
Dan_Delave Offline
Dan_Delave  Offline
Gary - I had a bit of trouble with the video as well. I updated my Quicktime on my PC and voila it was there. Did you already try this? I was going to bring it into my video editor and make an NTSC copy (it is in PAL) but the only conversion program I found that worked left a watermark in it. If someone has another suggestion I will take it.
Paul - Pete likes the boat. To tell you the truth he seems to like all the boats he sails and especially the ones he designs. My opinion, comparing it to the F18, is that it seems to be able to carry more weight on it. The position that you sail the boat to weather is a bit back from what I am used to. Pete kept asking be to get back bit. As a crew I was behind the shroud and Pete was as close as he could get next to me. This of course helps with the pitching of the boat. Normally as a skipper I am planted about where I was as a crew on this boat, so that is about shoulder-with back. Most of us sailing both boats thought that the newer one had a slight advantage to weather and a substantial advantage downwind. You will still have to go the right way on the course as you do not have the Ferrarri compared to the moped. The downwind advantage seems to be the way the boat handles more than anything. You will be able to take advantage of the wind and swell with more swiftness. This can be a disadvantage to those that do not keep the tiller still enough to let the boat can get up and go.
Pete mostly sails his A-Cat. I do not think he is likely to show up at too many events even here. I have tried to talk him into the Formula 18 Worlds in France. He did not say no. Maybe if Jay Glaser showed interested in crewing he would go.
Later,
Dan
Re: Infusion on Video [Re: Dan_Delave] #62379
12/09/05 01:07 AM
12/09/05 01:07 AM
hobiegary Offline
hobiegary  Offline
Damit Dan, I was really looking foreard to seeing you in your red skivies.
Dan
I can not get to any part of that nacraeurope site. I have tried different browsers. Forget about what codecs or viewers I have; I can't even get the home page at that site. And I do believe that my player is upgraded too.
Dan, are you the guy who came ashore at Belmont Shore's Claremont beach when we had a fun event known as Catapalooza last year? There was a guy and his father who had just taken delivery of a Nacra F18.
GARY
62949-Nacra Europe.jpg (37 downloads)
Santa Monica Bay
Re: Infusion on Video [Re: hobiegary] #62380
12/09/05 01:54 AM
12/09/05 01:54 AM
Palm Harbor, FL, USA
L
Lance Offline
Lance  Offline
L
Gary,
I just tried to get there and it loaded up right away and started playing the video. I can also ping the website from my pc and a tracert takes 19 hops to get to the site from here. If you can ping or traceroute to the site try and lower your web security settings - the site plays a quicktime video automatically and maybe your settings are blocking it. Not sure if that's it but it's worth a try.
Good Luck,
Lance
Taipan 5.7 USA 182
Palm Harbor, FL
Re: Infusion on Video [Re: Lance] #62381
12/09/05 03:09 AM
12/09/05 03:09 AM
Netherlands
Johnny Offline
Johnny  Offline
Netherlands
Hi there,
I'm the webmaster of nacraeurope.com and it seems a lot of you can't reach the website (from America). We are trying to fix the problem, and I hope you can help me with it.
Could anyone who can't reach the website do the following (using windows):
Start -> Run -> cmd
tracert nacraeurope.com
Could you send the result (right click -> mark) as a personal message to me? This info would be very helpful to tackle this problem!
If anyone has other problems with the movie, please let me know.
greetings, John
Sailing, the most expensive way of using free energy.
Re: Infusion on Video [Re: Johnny] #62382
12/09/05 03:28 AM
12/09/05 03:28 AM
L
Lance Offline
Lance  Offline
L
Here's a successful one from the Tampa (FL) area.
Tracing route to nacraeurope.com [212.203.14.37]
over a maximum of 30 hops:
1 7 ms 7 ms 7 ms 10.103.192.1
2 9 ms 10 ms 9 ms gig1-0.tampflerl-rtr2.tampabay.rr.com [65.32.15.
1]
3 9 ms 9 ms 10 ms pos6-0-OC-192.tampflerl-rtr4.tampabay.rr.com [65
.32.8.137]
4 11 ms 9 ms 10 ms pop2-tby-P0-1.atdn.net [66.185.136.185]
5 11 ms 11 ms 12 ms bb1-tby-P0-3.atdn.net [66.185.138.208]
6 28 ms 27 ms 27 ms bb2-atm-P7-0.atdn.net [66.185.152.245]
7 27 ms 27 ms 27 ms pop1-atm-P4-1.atdn.net [66.185.150.3]
8 60 ms 59 ms 59 ms so-5-2-0.mpr1.atl6.us.above.net [209.249.119.241
9 60 ms 59 ms 59 ms so-3-1-0.mpr2.iah1.us.above.net [64.125.29.62]
10 62 ms 61 ms 59 ms so-5-2-0.cr2.dfw2.us.above.net [64.125.29.18]
11 60 ms 59 ms 59 ms so-0-0-0.cr1.dfw2.us.above.net [64.125.28.209]
12 59 ms 59 ms 60 ms so-4-0-0.cr1.ord2.us.above.net [64.125.30.246]
13 60 ms 59 ms 59 ms so-0-0-0.cr2.ord2.us.above.net [64.125.29.186]
14 71 ms 70 ms 70 ms so-3-0-0.cr1.dca2.us.above.net [64.125.27.18]
15 141 ms 142 ms 141 ms so-6-0-0.cr1.lhr3.uk.above.net [64.125.31.185]
16 144 ms 141 ms 141 ms so-0-0-0.cr2.lhr3.uk.above.net [208.184.231.146]
17 153 ms 153 ms 156 ms so-7-0-0.mpr1.ams5.nl.above.net [64.125.27.178]
18 161 ms 168 ms 155 ms Essent.bb.amsix-tc1.ge-10-0.bgp.above.net [82.98
.250.186]
19 155 ms 153 ms 154 ms snoek.eatserver.nl [212.203.14.37]
Trace complete.
Lance
Taipan 5.7 USA 182
Palm Harbor, FL
Re: Infusion on Video [Re: Lance] #62383
12/09/05 03:46 AM
12/09/05 03:46 AM
I am ruuning XP Pro and Explorer 6.0.
Running Video
Crashed first time and locked up Explorer. Secound time it ran. Maybe there is a bug?
Doug
Re: Infusion on Video [Re: ] #62384
12/09/05 04:46 AM
12/09/05 04:46 AM
Netherlands
Johnny Offline
Johnny  Offline
Netherlands
Hi Doug,
mhh that's not good IE is crashing on the movie. It's programmed to show the movie if Quicktime player is installed on your computer and if not quicktime player is installed, you should get a message to download a plugin.
If you download the movie from Nacra F18 Infusion and watch it, do you get also an error?
John
1 registered members (JesperS), 340 guests, and 39 spiders.
