What masthook is this...? #62735
12/11/05 08:02 AM
12/11/05 08:02 AM
Lando Offline OP
Lando  Offline OP
Hi folks,
I am in the final rigging fase of my boat and I was wondering what to do with this masthook. Has anyone seen one like this and how is this supposed to work because it looks like it is installed upside down to me. I have searched with Google and can't find any masthook that looks like it. I assume there is some sort of metal ring that slides onto/over the hook, but how is this going to hold halyard if it's pointing up?
Here is a picture of my boat for people that are interested:
http://img236.imageshack.us/img236/5948/quattro166nx.jpg
Re: What masthook is this...? [Re: Lando] #62736
12/11/05 08:16 AM
12/11/05 08:16 AM
Pretty standard halyard lock. Shackle is welded to a ring about 2" diam. - use halyard to pull ring up above hook. Now release halyard slightly and pull down on sail. Ring will pop over the hook.
To release the lock, pull the sail up until ring is clear of hook. Now rotate mast hard to starboard. Pull down on sail while holding mast rotated. Sail will come down (usually ).
Re: What masthook is this...? [Re: Jalani] #62737
12/11/05 10:43 AM
12/11/05 10:43 AM
Lando Offline OP
Lando  Offline OP
thanks for replying Jalani, what does the ring look like is it one of these? http://store.catsailor.com/tek9.asp?pg=products&grp=327
sounds like I will be having fun learning how to use this hook
Re: What masthook is this...? [Re: Lando] #62738
12/11/05 11:14 AM
12/11/05 11:14 AM
No, none of those.
Here's a diagram of how it works:
You can see the type of shackle quite clearly. In the UK you can get these shackles from Sailspar, but I don't know who would supply them wherever you are. A good starting point would be your local chandler who might be able to order one in for you.
BTW. VERY important that knot is on the back of the shackle (away from the hook)
Re: What masthook is this...? [Re: Jalani] #62739
12/11/05 11:58 AM
12/11/05 11:58 AM
catman Offline
catman  Offline
One other tip to make sure this works easily is make sure the boat is pointed straight into the wind.
Re: What masthook is this...? [Re: catman] #62740
12/11/05 08:00 PM
12/11/05 08:00 PM
Lando Offline OP
Lando  Offline OP
thanks for the picture...this will certainly help when I go ask for it in the sailing hardware store. My mast is indeed from Sailspar so 10 points to Jalani for getting that right
Thanks for your help guys
Re: What masthook is this...? [Re: Lando] #62741
12/11/05 10:56 PM
12/11/05 10:56 PM
Might save a little if you can get it cheap enough?
http://cgi.ebay.com/ebaymotors/HOBI...mQQcategoryZ31281QQitemZ4596951080QQrdZ1
Doug
0 registered members (), 2,537 guests, and 222 spiders.
