Length side stay's at taipan 4.9? #6274
04/14/02 03:45 PM
04/14/02 03:45 PM
Netherlands
geert Offline OP
geert  Offline OP
Netherlands
Hello,
Does anyone know the length of the sidestay's for a Taipan 4.9, and how it this measured?
It appeared the stay's were gone where I left them in the winter, so I can't check the length by myself.
Btw, I use the regular pin/hole adjustment at the hull/side stay.
Thanks in advance,
Geert
Re: Length side stay's at taipan 4.9? [Re: geert] #6275
04/16/02 06:33 AM
04/16/02 06:33 AM
Geert,
When measuring stays the only reliable measurement is between bearing surfaces of thimble or holes of fitting at each end of stay.
According to my plans the side stays are 6120mm and the forestay is 5570mm.
Hope this gets you on the water.
Re: Length side stay's at taipan 4.9? [Re: phill] #6276
04/16/02 03:46 PM
04/16/02 03:46 PM
Netherlands
geert Offline OP
geert  Offline OP
Netherlands
Phil,
Thanks for your answer, sure it will help
Geert
btw, I finished may trailer, according your setup, works nice!
0 registered members (), 4,549 guests, and 485 spiders.
