| 18 Sq curved traveller #62792 12/12/05 03:13 PM 12/12/05 03:13 PM |
Posts: 364 | I'm putting together a 10' beam Nacra 18 Sq Meter, and the traveller track is missing from my rear beam. This seemed a great opportunity to explore a curved track - so, what do I need, and can I buy it, or do I have to make it? Should it be to the radius of the boom length, or a bit tighter to induce twisting (or is it to continue to force rotation?) Or should I just get another straight track? I have a new Ogletree-drawn Ullman-cut squaretop with a 30' luff coming in a month or three, if that makes any difference. Anyway, any information is greatly appreciated.
Andrew Tatton
Nacra 20 "Wiggle Stick" #266
Nacra 18 Square #12
| | | Re: 18 Sq curved traveller
[Re: Andrew]
#62793 12/12/05 03:36 PM 12/12/05 03:36 PM | Anonymous
| Anonymous
Unregistered | I have seen the curved tracks on both harken’s site and on ronstan’s site. They both sell the cars that go on tracks as well as the end stops.
Matt | | | Re: 18 Sq curved traveller
[Re: Andrew]
#62794 12/12/05 03:44 PM 12/12/05 03:44 PM |
Posts: 12,310 South Carolina | I know Harken will take your specs and create the track for you...but I recommend that you be sitting down when you get the quote!
Jake Kohl | | | Re: 18 Sq curved traveller
[Re: Andrew]
#62798 12/13/05 10:20 AM 12/13/05 10:20 AM |
Posts: 371 Michigan, USA | Andrew,
I saw a number of 18 Squares in the late 80's that had curved travellers. These had a center of radius behind the mast, so the clew of the sail would be pulled toward the mast as you let out the traveller. This makes the sail fuller and more powerful. The ends of these travellers were higher than the center, inducing twist as the traveller is let out. These tracks were mounted to the top of the rear beam in the center and then a molded track support attached the ends of the track to the hulls. When properly designed, the mainsheet would be set at the start and then the traveller was the only adjustment made as the boat went upwind or downwind or anywhere inbetween. Nice for single-handed boats, however, the traveller is a bit of an obstacle when moving around the boat.
All the systems I saw were purchased from Harken.
P.S. - All the Nacra 18 Squares started as 11' beam. Why reduce it to 10'? I would have made mine 12' beam if I had to change it.
Les Gallagher
[Re: Andrew]
#62799 12/13/05 11:15 AM 12/13/05 11:15 AM |
Posts: 623 Gulf Coast | Hi Andrew, why dincha write to either us or to Palin? Huh? Merry merry, incidentally... I have a curved traveller, but I ain't givin' it up. Harken will make 'em for you. If you like, I can get measurements of the arc for ya, or other info about the track I've got. For the drop lever boom, go to http://www.geocities.com/mec_coleman/18square.htm This is Mike Coleman's site. Great resource for 18sq cats. Bookmark it, it's useful. I met a fella at Birmingham recently. He had a Cat II sq rigged up with some interesting stuff, including a boom vang arrangement which is simpler than either the curved trav or the droplever boom. Why aincha going to 31' mast while you at gettin' a new sail? Not that hard to add the foot to the head of the mast, and mine and Jay's are working out well. Fact, we prolly got some extra extrusion. And, like the guy said, why 10' beam? sea ya tami | | | Re: 18 Sq curved traveller
[Re: tami]
#62805 12/14/05 12:48 AM 12/14/05 12:48 AM |
Posts: 364 | Hi Andrew,
sea ya tami The mast is a Marstrom Tornado tapered extrusion, probably 1970s vintage, and measures right at 32'; the finished luff of the sail will be 30'. Why 10'? I have the beams, and at just over 1/8 of a ton (260 lbs) dry weight, I've NEVER "needed" to trap upwind on my 11' Square. The 10' boat will lift a hull sooner, yet the squaretop will allow depowering (if/when it's needed). The drop lever traveler remains a viable option, tho the pics I've seen show it with a beam-mounted boom which angles up sharply. My boom is intended to be nearly horizontal, so I don't know how well it would work. More thoughts tomorrow, thanks y'all.
Andrew Tatton
Nacra 18 Square #12
| | | Re: ps.
[Re: tami]
#62806 12/14/05 12:50 AM 12/14/05 12:50 AM |
Posts: 364 | I used to think that too, till I started using leach telltales.
Andrew Tatton
Nacra 18 Square #12
| | | Re: Conversation
[Re: tami]
#62808 12/14/05 10:34 PM 12/14/05 10:34 PM |
Posts: 364 | I'll wrack Charlie's brain as best I can, and probably interview Palin as well. Speaking of Palin, last I heard there was a very good chance that Jon Lindahl's personal LCD Square, pretty much identical to Palin's (or should that be vice versa?), was coming to Texas to stay.
Andrew Tatton
Nacra 18 Square #12
[Re: GeeLin]
#62811 12/16/05 01:25 AM 12/16/05 01:25 AM |
Posts: 364 | New shrouds, Nacra-style (loooong) forestay bridle. I don't think the eggshell hulls would be happy with the stress of a short forestay bridle!
I don't know if it's original, but the half-socket on the mast base fits over the ball fine. It's not captive, but I'm tying off the mast base to the dolphin striker (JUST loosely enough) and haven't had a problem yet.
What's your hull number, out of curiosity? I have two sets; #189 and #12. The new sail and tall rig are going to go with #12. Where are you located, too?
Andrew Tatton
Nacra 18 Square #12
3,034
guests, and 366
