| Re: Trailer box
[Re: tami]
#64172 01/09/06 09:42 AM 01/09/06 09:42 AM |
Posts: 12,310 South Carolina | If you guys are interested, I've got a line on some 10' aluminum boxes and have a few being made this spring. PM me if you want more detail.
Jake Kohl | | | Re: Trailer box
[Re: PTP]
#64174 01/09/06 12:55 PM 01/09/06 12:55 PM |
Posts: 12,310 South Carolina | I assume you're talking about easing the cardboard out of a fiberglass shell? That's probably going to be difficult even with a plastic barrier. I did, however, see a Discovery special on rocket building where some guys used a cardboard tube as a mold for a carbon tube. After the carbon cured, they put the whole thing in a pool and left if for quite some time, then came back and peeled out the cardboard.
[Re: PTP]
#64176 01/09/06 01:40 PM 01/09/06 01:40 PM | Anonymous
| Anonymous
Unregistered | | | | Re: Trailer box
[Re: PTP]
#64177 01/09/06 01:43 PM 01/09/06 01:43 PM |
Posts: 1,449 | Consider this as an option. You could run a cut down the mould. Just one side top to bottom. Insert a narrow piece of timber say 1/2 inch wide and full length of the cardboard mould. Put props in from the 1/2 timber it to the other side of the mould to hold the 1/2 timber in place. Cover the outside of the join with packing tape. (Now you have a collapsable mandrel.) Do your glassing. Once cured pull out the props and then the 1/2 inch timber. Now your moud is 1/2 inch smaller than the layup and comes out easy.
Hope this helps. Regards, Phill
| | | Re: Trailer box
[Re: phill]
#64178 01/09/06 01:45 PM 01/09/06 01:45 PM |
Posts: 12,310 South Carolina | Consider this as an option. You could run a cut down the mould. Just one side top to bottom. Insert a narrow piece of timber say 1/2 inch wide and full length of the cardboard mould. Put props in from the 1/2 timber it to the other side of the mould to hold the 1/2 timber in place. Cover the outside of the join with packing tape. (Now you have a collapsable mandrel.) Do your glassing. Once cured pull out the props and then the 1/2 inch timber. Now your moud is 1/2 inch smaller than the layup and comes out easy. Beautiful.
#64179 01/09/06 02:44 PM 01/09/06 02:44 PM |
Posts: 1,449 | Jake,
I intend to experiment making a snuffer tube this way over plastic pipe but using 1/8 inch aluminium instead of the 1/2 timber. I have some very thin closed cell foam that will bend around the tube. So It could be made very light without going to carbon. Just sandwich layup using glass. That way it would still be F18 legal. I'll pull the sandwich layup down with a vacuum to ensure the structure does not delaminate with time.
| | | Re: Trailer box
[Re: phill]
#64180 01/09/06 02:52 PM 01/09/06 02:52 PM |
Posts: 3,528 Looking for a Job, I got credi... | Another couple of options (assuming you are not going to get it wet).
1, Use circular tube Aircon ducting (can be bought in a number of sizes up to about 2 foot Dia I think) - I'm planning to investigate this for my next "box" as it is light and fairly strong (being round) and you can buy standard end caps.
2, Use large scale Aircon ducting (rectangle) - hiever than the circular, but will fit the trailer better.
F16 - GBR 553 - SOLD I also talk sport here | | | Re: Trailer box
[Re: tigerboy]
#64183 01/10/06 10:38 AM 01/10/06 10:38 AM |
Posts: 807 Hillsborough, NC USA | NEVER immerse your cat trailer in the water, NEVER. You are asking for trouble. Sure powerboats do, but how many times have you seen them broken down on the side of the road missing wheels, broken supports or non-functioning lights? A good trailer should be able to handle immersion as long as you take reasonable care of it. All the failures I've seen stem from neglect, not immersion. Before launching, you should: 1) Disconnect the trailer lights. Boat trailers are made with submersible lights, but they are not meant to be illuminated underwater. If a hot bulb contacts cold water, it will crack and burn out. You also don't want the water to short out your vehicle lighting and blow a fuse. 2) Always let your trailer sit for at least 15 minutes after towing before launching. It is critically important to let your hubs cool. As you drive down the road, they get warm, and if you dunk them in cold water, the warm air and molten grease inside the hub will contract. That in turn will draw water through the seal into the hub. Once inside, the water will never come out (short of repacking). The bearings will then corrode and fail prematurely. If you launch in salt water, you need to thoroughly rinse (or better dunk) your trailer in fresh water at the first opportunity. Dried on salt attracts moisture from the air and greatly accelerates corrosion. Your trailer should also have sufficient drainage so as not to trap water. And, of course, don't neglect basic trailer maintenance, such as regular inspection, checking lights and tire pressure, and annually repacking the bearings. Regards, Eric | | | Re: Trailer box
[Re: Isotope235]
#64184 01/10/06 10:56 AM 01/10/06 10:56 AM |
Posts: 45 Commerce Twp, MI | Eric, IMHO there is NO good reason to put a beach cat trailer in the water...none, nada, zilch. Even if you go through the proper steps and maintainence. I learned the hard way when I was a newbie back in the day (1975). I had a bearing seize on the 405 freeway in Los Angeles at 10:00 PM on the way to a regatta. Not fun. It was a brand new trailer that I put in the water to launch and retrieve. Never again and I haven't had any problems since (knock on wood) for a quarter of a million miles. Take good care of your equipment and it will take good care of you. Lesson learned.
Tiger Sailor
| | | Re: Trailer box
[Re: MauganN20]
#64186 01/10/06 03:11 PM 01/10/06 03:11 PM |
Joined: Mar 2003 Posts: 736 Westport, Ma. U.S.A. Brian_Mc
Posts: 736 Westport, Ma. U.S.A. | Patrick, If you are not already commited to a design, do a search at www.thebeachcats.com There is a lot of info on the subject, and some great boxes/tubes. I purchased the large glass box from Hobie, and found it more time consuming, and way more expensive than building a plywood box from scratch. The boat I have now came with a nicely built wooden box. Only troubles were it was on the trailer backwards, and too high to get the boat on and off without lifting! I hacked it up a lot modifying it,but now it works great. Tad, after rebuilding the trailer for my first 17, it seems like more work to dunk than not to dunk. I'm with John on that one. Love my Cat Trax! | | |
20,217
guests, and 543
