| Re: Trailer box
[Re: gary145]
#64208 03/16/06 07:04 PM 03/16/06 07:04 PM | Anonymous
| Anonymous
Unregistered | Nice. Englsih boat? I want a Narca A2 bad  Just have to save up the $19,000.  Oh well rebuilt Hobie 17 with reacher will have to do for now.  Doug Snell Hobie 17 www.tcdyc.com | | | Re: Trailer box
[Re: ]
#64209 03/31/06 05:42 AM 03/31/06 05:42 AM |
Joined: Mar 2006 Posts: 66 Fort Lauderdale, FL, USA ReefedOne
Posts: 66 Fort Lauderdale, FL, USA | I'm not sure I understand why the trailer box has to get wet, unless there's heavy wave/wake action at the ramp? The box is ABOVE the trailer frame, and the rollers and cradles are only 2-3" above that. Is there any beach cat that will be damaged by a 3" drop to the water?
A 4,000 lb. motorboat HAS to be floated off the trailer, but a 300-400 lb. beach cat? As you roll it off BY HAND, the cantilever provided by the portion of the cat still on the trailer means you (and your back) will only experience maybe 30-40 lbs. of load... you need more muscle than that to tug on the mainsheet.
I had a Dilly Cat-hauler w/ a 4' x 8' plywood box on it. IIRC, the rear rollers were on top of the trailer's rearmost crossbar, the taillights were on the backside of that rearmost crossbar, and the rear of the wooden box was also even with the backside of that rearmost x-bar, pretty standard setup... (it had rollers up front too... lack of cradles didn't seem to bother the P-16's tough keels one bit.)
(FRESH WATER LAKE): I'd back down the concrete ramp until that rear crossbar and lights were just about to get wet. Do not remember it being a very steep ramp. The Prindle's keels curve up and so were maybe 8-10" off the water. Unstrap boat, grab BOAT'S rear x-bar and roll back until balance/tilt point reached. Since nearly balanced, only a few pounds of weight supported by my arms. Gently lower stern into water, step around to the side, and continue sliding off trailer. Never got wet very far above the knees. Keels in no danger of scraping bottom... (rudders UP, nach)... box and lights: DRY.
The only part of the trailer that gets wet are wheels (and leaf springs), but that's why Bearing Buddies were invented, i.e. the spring-loaded piston keeps the grease packed tight, leaving NO ROOM FOR WATER.
| | | Re: Trailer box
[Re: PTP]
#64212 03/31/06 10:34 AM 03/31/06 10:34 AM |
Posts: 306 St. Louis, MO | I sometimes launch in waves that are 6-12 inches. My trailer gets wet and so do I. It is never a bad idea to assume anyting having to do with your boat will get wet. This is an especially good assumption when sailing in salt water as it is very corrosive and you should be ready for this.
Nick
Current Boat Looking for one
| | | Re: Trailer box
[Re: bvining]
#64213 03/31/06 10:50 AM 03/31/06 10:50 AM |
Posts: 807 Hillsborough, NC USA | Why not get some beach wheels and keep your trailor out of the water altogether. One of the skippers in my fleet built a custom trailer with an integral beach-wheel-dolly. When he pulls up to the lake, he just unlocks the dolly and rolls it (boat and all) down the beach to the water. He launches and retrieves directly off/onto the dolly so his hulls never even touch the sand. When he's done for the day, he simply wheels the dolly back up onto the trailer and locks it down. It's an ingenious system that works very well. So well, in fact, that IFG blueprinted his design and now offers it as an option on new Isotope trailers. | | | Re: Trailer box
[Re: PTP]
#64215 03/31/06 11:04 AM 03/31/06 11:04 AM |
Posts: 306 St. Louis, MO | It's hard. Where I put in most last season the only option was to use beach wheels. I have to tell you that a 400lb cat is hard to drag up the beach. Especially after being on the water for 8-10 hours. The worst part is getting the boat up onto the trailer, even with the rear rollers. Unless the height of the trailer rollers or cradles is the same as the beach wheel axel, then you do have to work pretty hard at pushing or pulling the boat up that incline.
I have started to use the boat winch to get is on the trailer from the beach wheels. This can still be tricky as the wheels like to shift on you at inopportune times.
Nick
| | | Re: Trailer box
[Re: PTP]
#64216 03/31/06 11:13 AM 03/31/06 11:13 AM |
Posts: 807 Hillsborough, NC USA | Well, in dolly system above, the trailer frame has rollers but they never come in contact with the hulls. Instead, the dolly frame (which is lightweight square aluminum tubing) rides on the rollers when loading and unloading. When actually on the trailer, the dolly rests on rubber pads and the dolly frame pins securely onto the trailer frame. The dolly itself has 4 molded cradles (fore and aft for each hull) that the boat rests on. Beach wheels are attached at the aft of the dolly, and a crossbar at the front provides a place to lift and grip. It is well enough balanced that I doubt it takes more than 20lbs of force to lift a 285lb boat. To unload, he lifts the front handle. The rear of the dolly pivots down onto rollers and he rolls if off the trailer onto the beach wheels. To load, he lifts the front of the dolly onto the rollers and pulls the dolly back up onto the trailer frame. It's surprisingly easy.
Regards, Eric | | | Re: Trailer box
[Re: Mary]
#64218 03/31/06 12:14 PM 03/31/06 12:14 PM |
Joined: Mar 2002 Posts: 984 2017 F18 Americas Site Dan_Delave
Posts: 984 2017 F18 Americas Site | How do you get a 400 pound boat onto a trailer even from beach wheels? I do it alone a lot. I have cradles on the trailer, not rollers. They have carpet which I sometimes spray with a silicone lube, it seems to help some. I untie the wheels from the shrouds, roll the boat tilted as close as I can to the trailer. Take the tiller crossbar off so I can get my forearms under the back crossbar. Lift the boat while walking forward. You are lifting less than 100lbs if you cradle it pretty well. It is not A-Cat easy but not that difficult. Later, Dan | | | Re: Trailer box
[Re: PTP]
#64225 03/31/06 11:40 PM 03/31/06 11:40 PM |
Posts: 1,121 Eastern NC, USA | How do you get a 400 pound boat onto a trailer even from beach wheels? Dynamite? Must be a big boat to be 400#. BTW, fantastic AC coverage.
Tom | | | Re: Trailer box
[Re: tshan]
#64226 03/31/06 11:50 PM 03/31/06 11:50 PM | Anonymous
| Anonymous
Unregistered | Guys: ReededOne gave me an idea in one of the other threads. Take 4-6 of these: http://www.stores.yahoo.com/baytec/30galfoodgra.htmlCut the ends of and use plastic to band them together. Make ends out of glassed over plywood. Throw some clamps on the lids and put a shelf in one end for rudders, blocks etc. I think it would make a good box. Just my opinion. Doug Snell Hobie 17 Soon to be Mystere 4.3 Formula 14 www.tcdyc.com | | |
2,627
guests, and 638
