| Re: Pop riveting Hardware to the Deck
[Re: PTP]
#64553 01/13/06 02:22 PM 01/13/06 02:22 PM |
Posts: 1,121 Eastern NC, USA | Would it be possible to run a small shackle off the chainplate with your block attached to the new shackle?Basically, put a longer "pin" in where the chainplate and shroud adjuster connect, add a shackle there and add the block.
This may not be the most elegant solution, but may be the simplest and no new holes in the deck.
Tom | | | Re: Pop riveting Hardware to the Deck
[Re: pkilkenny]
#64560 02/07/06 01:12 AM 02/07/06 01:12 AM |
Posts: 1,200 Vancouver, BC | Phil,
The techniques described above are essentially the West System (Gougeon Bros.) recommended ways to secure fittings to foam core surfaces. Never use pop-rivets in such surfaces if you want to hold any kind of loading. A rivet requires very high compression against the rivet head and pulled section. This kind of compression cannot be achieved against cored composites and even just the laminate skin.
One tip I will add to the techniques described above...place the screws into the un-cured epoxy. Just spray them with WD-40 or cooking oil/PAM to allow them to release later on. This makes a very nice threaded section in the epoxy for maximum strength.
Mike.
22,487
guests, and 373
