| Nacra Mast Rotator Installation Question #6455 04/23/02 10:42 AM 04/23/02 10:42 AM |
Posts: 74 Maryland, USA | I have a Nacra 5.5SL that never had a mast rotator installed. I want to install a mast overrotator. The 5.5 is a boomless boat.
I am looking for information on how high up the mast to install the rotator. Plus any other tips or tricks or best ideas on where to install the cam cleats, etc. I have a standard spinnaker, used occasionally, launched from a bag at front of tramp which might get in the way, if that makes a difference.
Patrick Ragen Taipan 4.9 USA 274
| | | Re: Nacra Mast Rotator Installation Question
[Re: PRagen]
#6456 04/23/02 03:24 PM 04/23/02 03:24 PM |
Posts: 364 | I had a 5.5u with the over-rotator. As I recall, it was mounted as low as possible without the bolt actually going thru the mast base casting. There was a padeye on the front centreline of the mast about 8" above the rotator with a loop of 1/8" poly line running to both corners of the rotator to keep it from swinging down and hitting the crossbeam. The cleats were rotating bullseye cleats mounted about 18" out from the mast base on the main beam, using extended bases which put the the eyes about 4-5" aft of the centreline of the main beam. If you have the standard traveler cleating to the centre of the rear beam, it should be the same cleat on the same base.
As for the chute: It has to go out the sides, under the jib sheets, right? It doesn't launch over the front beam but over the juncture between the front beam and the hull? It shouldn't be a problem; the rotator gear is limited to the centre 2-3 feet of the main beam, and a line about 5" behind that. I ran a continuous line that only had a little slack, so I didn't have to be tending it all the time. I also did a distance race with the chute, and believe me, it's really nice not to have to mess with a jib! Of course, I then had to go and buy a Prindle 19...
Anyway, good luck. I'd shoot you a picture, but I don't have any, and the boat is sold now and a good 4 hours drive away
Andrew Tatton
Nacra 20 "Wiggle Stick" #266
Nacra 18 Square #12
[Re: Andrew]
#6457 04/23/02 04:27 PM 04/23/02 04:27 PM | Anonymous
| Anonymous
Unregistered | On my N5.8 I have a similar setup to what Andrew described. It work good. If I recall, the Murray's catalog has a picture of the setup.
I have seen some who have a bull's eye instead of the cam cleat 15" on the crossbar, and the rotator line was led a little farther out on the crossbar, such that it could be adjusted while out on the wire. I have never sailed with that setup, so I cannot say how well it works.
David Rogers
Nacra 5.8 w/spin | | | Re: Nacra Mast Rotator Installation Question
[Re: PRagen]
#6459 04/24/02 12:19 AM 04/24/02 12:19 AM |
Posts: 364 | I think the reason that I never felt like it cost me time, either upwind or down, not being able to adjust mast over-rotation from the wire, was that if I was trapped, by definition I was NOT looking for more power, and just let the rotation take care of itself. If it was minimal trap conditions, I'd be in and out anyway, and would just crank on the rotation one of the times I was in, or while tacking. I never tried locking out rotation completely to depower; I bet I would if I still had the boat! Rotation settings were: Upwind-as needed for a smooth entry if I was looking for power - usually this meant the luff track pointing at the shroud or so. Downwind: Same thing; usually meant cranked on hard, even to rotating by hand and then cleating the line to hold it there. Downwind with chute: Always cranked on hard to shift as much loading on the mast to the major axis.
hope this helps
Andrew Tatton
Nacra 18 Square #12
[Re: Andrew]
#6460 04/24/02 09:46 AM 04/24/02 09:46 AM |
Joined: Jul 2001 Posts: 397 Burlington, Vermont USA Kevin Rose
Posts: 397 Burlington, Vermont USA | Andrew,
To be honest, my crew (wife) has never used the rotator while on the wire. The fairlead at the end of the beam does, however, keep the rotator line tidy and out of way of other controls (of which the N6.0 has perhaps too many of).
Kevin Rose
N6.0na #215
Lake Champlain (New England's "west coast")
Burlington, Vermont
[Re: Kevin Rose]
#6461 04/24/02 09:05 PM 04/24/02 09:05 PM | Anonymous
| Anonymous
Unregistered | I though my N5.8 had a lot of spaghetti on the tramp, but looking at that pic I realize I could be worse. I guess with the spinnaker bag and rigging, it is worse.
David Rogers
Nacra 5.8 w/spin | | | Re: over-rotate with a spinnaker?
[Re: samevans]
#6463 04/25/02 04:28 PM 04/25/02 04:28 PM | Anonymous
| Anonymous
Unregistered | I don't use the over-rotator while flying the spin. Reasons to have the Over-rotator with spin:
a) I've not always had the spin
b) For when I am not using the spin (taking friend out for rides, on windy days when I am not comfortable flying the spin | | | Re: just making sure
[Re: samevans]
#6465 04/26/02 11:55 AM 04/26/02 11:55 AM |
Posts: 2,844 42.904444 N; 88.008586 W | Sam,
I agree totally with Andrew's last sentence of his post.
On the original forum, (even before this one), overotating the mast with the while flying the chute was discussed, and by many, including R. Smyth, via Paula Smyth, was concluded was a good idea. Even though the main is nearly centered due to apparent wind, and tight to provide backstay, overotating also puts the vector of load more along the masts stronger axis.
Now you're saying that it's not a good idea, especially since the main is basically going to weather. I don't agree. Depending on the conditions, mainly wind and angle of attack, I overotate my mast while flying my chute.
I also have the rotating hound for my chute, similar to many Tornado's, and the same effect of the 'bail whire' on the Inter masts, which also benefits the loads my masts experiences. My hound height is now about 50% from shroad hoand to the top.
I also drop the mainsheet block prtion of my line and run the traveler portion of my mainsheet line.(continuos line). This enables to power/depower the main, while keeping the backstay tension via the mainsheet on the mast head.
My 2 cents.
Todd Bouton
N6.0na +
#111
F-18 Infusion #626- SOLD it!
[Re: samevans]
#6467 04/29/02 09:41 PM 04/29/02 09:41 PM |
Joined: Jun 2001 Posts: 342 Lake Murray, SC,USA Cary Palmer
Posts: 342 Lake Murray, SC,USA | SAM: I have both on my 5.5SL, as you may remember. Both have their place on the boat just not to be used at the same time. The elastic system like you have on your Hobie 17 won't work on a Nacra rotator arm. Your 17 rotator arm faces aft, Nacra rotator faces forward. AND, the Nacra hardrware is a lot harder to rotate than your 17 mast. Elastic just won't do the job.
PS: The new boat SCREAMS, I know why all the 5.5's killed my 17 on the circuit last year, they probably weren't even working hard.
CARY
CARY ACAT XJ Special C&C 24
| | | Re: definition of "over-rotated"
[Re: samevans]
#6468 04/29/02 11:47 PM 04/29/02 11:47 PM |
Posts: 364 | I rotated the (early light) mast on my Uni significantly past 90 degrees under chute. Yes, the main is trying to pull it back. But with relatively loose diamonds on a non-prebent mast (like most Nacras) the rotation combined with mainsheet tension will put 3 or 4" of bend in the mast, with the added bonus that the spinn hound is now that much farther back - you have "free" mast rake aloft. I flew the chute on the Uni in winds up to about 12-15, but doused rather than trapping. I was trying to save the tender (and irreplaceable, as you know) mast, which came thru with flying colors.
sail fast
Andrew Tatton
Nacra 18 Square #12
| | | Re: rotation limiter & over-rotator
[Re: samevans]
#6470 04/30/02 06:45 PM 04/30/02 06:45 PM |
Posts: 342 Lake Murray, SC,USA | You're right about the Hobie setup, Sam,100%. I'm familiar with your 17 rotator. I copied the design for my 17, since I forgot how Mike Murphy had exactly rigged it when I first met you. However, The 5.5 over rotator faces forward, is pulled aft and lateral down to the crossbar and cleated. It takes more strength to keep the rotation arm pulled back to OVERrotate than most bungee is capable of. Glad you're gonna make the race. Looks like we're gonna have a BIG crowd(for us), expecting 40+ boats, and still getting interest and committments. Have a 5 boat G-CAT 5.0 class, and the Hobie 18 MAG fleet is gonna show up in force too. Good prizes, Live Band, and FREE BEER too. Gonna bring your 17 and take on the Murphy boys or bringing your 18sq and race me and the Supercats? www.seacats.orgCARY
1 registered members (FredL),
2,799
guests, and 283
