| Re: Tradewinds Story and Pix
[Re: wildtsail]
#64934 01/22/06 09:55 AM 01/22/06 09:55 AM |
Joined: Mar 2002 Posts: 3,355 Key Largo, FL and Put-in-Bay, ... RickWhite OP
Posts: 3,355 Key Largo, FL and Put-in-Bay, ... | It always amazes me how few people read the SIs. Just before the start one of the F16 sailors asked about the course, "What does 4X mean." Of course, we didn't answer except that it was in the SIs.
And the fact that someone tried to finish in the Starting Line was anaother example of not reading the SIs.
The reason there are SIs is so the RC can utilize a system to get in more races and better races for all fleets.
Example: there were two courses: 4 and 4X 4 was a triangle, Windward-Leeward, and upwind finish on the starboard side of the RC boat. 4X simply added another Windward-Leeward. Reason: The first three fleets were faster boats and this gave them a longer course. The slower boats were given a course 4 and they started later. This allowed all the boats to finish within about 10 minutes of each other in order to get off more races.
The reason for the finish line on the starboard side of the RC boat is that we can have a short line making it easier to score the finishers. On the other hand the start line needed to be much longer to accomodate the larger fleets. Doing it that way we could get off another start as soon as the last boat finished without having to take the time to reset the starting line.
I know when I attend a regatta I really read over the SIs thoroughly. Main things to watch for: *Start procedures (Most use the ISAF which takes 5 minutes for each class.., Tradewinds uses 3 minutes and get lots of fleets off faster) *Start and finish lines *Courses and how they will be displayed *How they will handle boats over early, both individual and general recalls *How will be the barging buoy be treated *How they will handle wind shifts and the moving of marks
Those are just some of the basics you need to look for at every event.
Rick | | | Re: Tradewinds Story and Pix
[Re: Rolf_Nilsen]
#64936 01/22/06 04:18 PM 01/22/06 04:18 PM |
Posts: 1,203 uk | Does Ricks summary of the SIs maen that you race F18s around triangles? that must get a bit expensive on spinny wear and tear! one of the best bits of sailing with a kite is that we get away from the 'triangle procession'and open up the race to a bit of free thinking [tackticks]
[Re: TEAMVMG]
#64937 01/22/06 05:33 PM 01/22/06 05:33 PM |
Posts: 1,884 Detroit, MI | I felt like I was in a time warp at Tradewinds - many of the procedures, courses and the like have not been used in North American Hobie Class events for several years.
The ISAF starting sequence is much more flexible than the fixed starting sequence used at Tradewinds - even if it would have added 10 minutes to the total starting sequence. For example, the F-18's could have been started on time the first race (we were mostly all there at 9:00 AM) without having to start the other classes. Instead, we sat around and froze our a$$es off for 40 minutes waiting for the other classes to get out to the course. Same thing for waiting between races - the F-18's could have been started on their second race instead of waiting for the last boat in all the other classes to finish. That's when my crew got hypothermic - from sitting around for 20 minutes between races.
The ABCAC course (Course 4) was dropped from the Hobie Class standard course chart two years ago, because it's a race to the first weather mark, then a drag race. It spreads out the fleet and doesn't provide the passing opportunities that a W/L race has. The 4x course helped, but still, that was the first F-18 course I've ever sailed around the cans that had a true reaching leg.
Downwind gates and finishes are used almost exclusively at HCA events instead of the single downwind mark and upwind finishes that were used at Tradewinds. Gates help prevent congestion at the leeward mark and provide passing opportunities. Downwind finishes are tactically challenging, especially in spinnaker boats.
Separate start/finish lines work particularly well with the ISAF starting sequence, but Rick's argument about moving the marks doesn't hold water for the type of start sequence he was using. The start and finish pin positions can be marked with small buoys (fenders) on the same side of the signal boat and a larger bouy clipped on to the appropriate one as necessary. You don't need to move the ground tackle to reset.
Want to emphasize that I truly appreciate the time and effort that Rick, Mary and everybody else put into giving us a good time and I am writing this to be constructive, and not just critical.
The Hobie Class has been spoiled with the top-shelf race management we've gotten from the likes of Paul Ulibarri (running the Tornados at the Miami OCR this week), Mark Santorelli, Mike Walker and Irene McNeill at our major events. That's why Mike and Karen Grisco got confused with the separate start/finish lines. They're not likely to make that same mistake twice. | | | Re: Tradewinds Story and Pix
[Re: mbounds]
#64938 01/23/06 09:04 AM 01/23/06 09:04 AM |
Posts: 12,310 South Carolina | Matt, It's pretty hard to not hear a rather unappreciative tone to that post. First - this wasn't an HCA event so I don't see how that's even an issue. Second, the course is hardly substandard or outdated...it's the OLYMPIC sailing course that can be found HERE. Third, what exactly is your complaint about the Race Committee besides waiting for the boats to get out there to get started? I was pinned, beyond our control, in the lot behind several boats that there skippers weren’t ready and we were late to the course – I was pretty appreciative that the RC was sensative to the launching conditions. As far as you being cold – is that really the race committee’s fault? Fifth, regarding the finish direction (upwind or downwind) you make a pretty selfish proposal to finish downwind when at least half of the fleet was either uni rigged or main / jib only. Certainly you're not suggesting that they finish upwind while spin boats finish downwind. Sixth, by listing all the great HCA PROs, are you trying to infer that Rick White isn't qualified?
Jake Kohl | | | Re: Tradewinds Story and Pix
#64939 01/23/06 09:49 AM 01/23/06 09:49 AM |
Posts: 3,355 Key Largo, FL and Put-in-Bay, ... | Thanks for coming to my defense, Jake.
Just some food for thought: The reason for the Course 4 is to get the early starting boats (usually faster) off to the side of the course the first time around while all the other classes are starting. We try to keep the reaching legs deep enough so the brave can still carry their spinnakers. Hobie really ought to start using Course 4 again.
On the 3-minute start sequence, we were able to get off 6 classes in 18 minutes, instead of 30 minutes with the 5-minute sequence.., and still allow each class clean air for their starts. When the 5-minute, class flag start came into being the theory was that when one class finished and were hanging around, you could go ahead and start them while others were still sailing. Sounds great! But, rarely works. I have been to many, many regattas since the onset of the new start sequence and have only seen it work successfully once. You can't start a class that has finished if the course is not square. Any windshift and you must await all the classes to finish anyway.
Just a bit on my exprerience: *I was on the Olympic RC for Savannah *I am a US Sailing Senior RC *I was PRO for the MOR (Olympics) for 9 years in Miami and ran the Tornado and 49er course.
But, I guess I really didn't have to tell you all that! Must be my vanity! <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" />
We hope to get some pretty good advertising money for next year's event and either have a better venue or improve on what we have. So, we hope to have a great race next year. Hope we can see ya'll there. Thanks Rick | | | Re: Tradewinds Story and Pix
[Re: RickWhite]
#64940 01/23/06 10:52 AM 01/23/06 10:52 AM |
Posts: 1,187 38.912, -95.37 | Not much to do with Tradewinds, but... Hobie really ought to start using Course 4 again. AMEN! Downwind finishes are tactically challenging, especially in spinnaker boats. True, but what percentage of total boats are Tigers racing HCA events? The "excuse" I hear in our area (for the unpopularity of the Tiger) is that they are too much work for our small lakes. I'm sure this will change as folks get the taste of spi boats, we really do lag behind the coasts. That said, the most popular boat here is the H20. So, why does HCA feel the need to eliminate B for the "rest of us"? It doesn't have to be used in every race. The opinionated view of a sloop rig sailor.
[Re: RickWhite]
#64941 01/23/06 11:41 AM 01/23/06 11:41 AM |
Posts: 1,884 Detroit, MI | Oh, fer crissakes! I wasn't trying to be whiney - I just was trying to be constructive. I went out of my way to point that out. I knew this wasn't an HCA event - that's why I read the SA's and knew about the separate S/F lines. I was just pointing out the differences because I think(personal opinion) the HCA's been spoiled with high-quality event management - and I want Rick's regatta to be better for everybody next time. I wasn't demeaning Rick's experience or abilities - I just felt like the courses and starting sequence was from an earlier era - which they were!
I race in upwards of 15 events a year - and this was the first ABCAC course I've sailed in over 3 years! The point is not about having a B mark - it's about having a reach immediately after the first weather leg. All it does is stretch out the fleet and force everybody to one side of the course. Eliminating this pracitice was not done for spinnaker boats - it's been the practice at all major Hobie events for years.
Personally, I was annoyed that I made the effort to get out to the course on time and had yet had to wait on the water for the stragglers to get out. There might have been a fourth race possible (and a throwout) if it had. I can see your point, Jake (being trapped), but ultimately it's every competitor's responsibility to get to the line on time. You were lucky that Rick waited.
Starting 6 classes using the old sequence uses 21 minutes, not 18. Using the ISAF sequence would have only used 9 more minutes - less than a third of the time that was wasted in the postponement of the first race. If you say you're going to start at 9:00 AM, then start at 9!
I think if you ask anybody who was sailing that morning, they'll tell you they were cold. My crew became hypothermic - she was shivering violently, then stopped. That's a bad sign, so I took her in. If we had not been sitting around so much, that might not have been necessary.
BTW - 90% of the races in the Hobie 16 NA's and the Hobie 17 NA's had downwind finishes. It's not just for spinnaker boats.
Rick - you're not listed on the US Sailing web site as being a Certified Race Officer. Every person I mentioned in my previous post is, except for Mike Walker, who is a Senior Canadian Race Officer (listed on the CYA website). | | | Re: Tradewinds Story and Pix
[Re: mbounds]
#64942 01/23/06 11:56 AM 01/23/06 11:56 AM |
Posts: 3,293 Long Beach, California | Alright - let's head this off now. C'mon guys - it was a good event. Matt, of your 15/year, I'll bet that they're pretty much all HCA events, and therefore understandably consistent in their approach. But you surely know that it is sometimes done differently. You may not always agree with the RC - lord knows Rick and I have gone 'round and 'round on the Wave course philosophy. But you deal with what you get.
Also - Rick is a Recognized Senior Race Officer - a lifetime appointment by US Sailing. Check his certification by doing a search of his name in the member section. Conversely, PU let his membership lapse some time ago and his certification is not currently valid, though he is certainly qualified.
Different strokes - Matt's comments should be taken as constructive critisism - nothing more.
[Re: mbounds]
#64943 01/23/06 12:03 PM 01/23/06 12:03 PM |
Posts: 829 Charleston, SC | Hey man, if it was that bad of a time for you, don't come again. Rick did a great job, and you have no right to fault anything at a race that you did nothing to help plan or run. Yeah, racing was scheduled to start at 9:00 am, but with the launch areas (all 2 of them), it is hard to get 40+ boats on the water, especially when the boats first up are often behind the boats last up. Since I got there early, it must be my fault that a few Hobie 16's and and an F16 were parked in front of me and that I had to wait for them to get in the water. Regardless of your "constructive criticism" clause, it seems to me that you're just tearing this race down because it wasn't run as you would run it, or done in the "happy hobie way."
Trey
[Re: mbounds]
#64944 01/23/06 12:06 PM 01/23/06 12:06 PM |
Posts: 3,114 BANNED | I think if you ask anybody who was sailing that morning, they'll tell you they were cold. My crew became hypothermic - she was shivering violently, then stopped. That's a bad sign, so I took her in. If we had not been sitting around so much, that might not have been necessary. As one of the first ones to complain about being cold, I have to say that if you were cold Sunday morning then you were not adequately dressed for the weather. While the temperature of both the water and the air was relatively warm, when the wind hit your wet body, it made it feel 20 degrees colder. As for the postponement, Trey and I were sailing all over Blackwater sound tuning the boat (as if it made any difference) and you were sitting around waiting for the start? No wonder you were cold. Don't rag on the over-qualified PRO for your lack of preparedness. You're from Detroit and you're cold?!?!?! | | | Re: Tradewinds Story and Pix
[Re: MauganN20]
#64945 01/23/06 12:22 PM 01/23/06 12:22 PM |
Posts: 503 | If you dont like the way a regatta is run, pull the organizers aside during or after the event and talk to them about it. Call them. Explain your reasons why, offer examples, or better yet, offer to help the next year.
To come out on a public forum and bitch, and in my opinion your bitching, and to publicly question the integrity of someone who has devoted so much to catamaran sailing demonstrates a complete lack of class to me.
Our regatta, the JPOR has used the old starting sequence for years. I hate it, but our PRO has been the PRO for like 20 something years. EVERY year he is dependable and shows up. I hope someday he tries the new system, but as long as he is willing to VOLUNTEER his time year after year, Im good with whatever he wants to do.
And to complain about the cold and your lack of preperation for the elements at an event is completely shameful.
Im sorry Matt, I enjoyed talking to you in the Keys, but it drives me nuts when people complain publicly about others that volunteer their time. | | | Re: Tradewinds Story and Pix
[Re: BrianK]
#64946 01/23/06 12:28 PM 01/23/06 12:28 PM |
Posts: 3,293 Long Beach, California | C'mon guys - really. Matt had his say, Rick had his say. This doesn't need to be a bash-fest.
[Re: John Williams]
#64947 01/23/06 12:35 PM 01/23/06 12:35 PM |
Posts: 12,310 South Carolina | But he started it!!! Matt, I've since had my coffee and I apologize for the 'whiney' thing.
[Re: mbounds]
#64950 01/23/06 06:35 PM 01/23/06 06:35 PM |
Joined: Sep 2003 Posts: 97 Williamston, sc h18catsailor
Posts: 97 Williamston, sc | The Hobie Class has been spoiled with the top-shelf race management we've gotten from the likes of Paul Ulibarri (running the Tornados at the Miami OCR this week), Mark Santorelli, Mike Walker and Irene McNeill at our major events. That's why Mike and Karen Grisco got confused with the separate start/finish lines. They're not likely to make that same mistake twice. I guess I am a little late on this but one of the indviduals above did an event a few years ago and they were the worst PRO I have ever seen. The point is everything will not always be perfect for everyone. If you have a problem: tell the PRO, If you had fun: tell everyone.
David Strickland Hobie 18 HEAVY air crew on a J22
[Re: h18catsailor]
#64951 01/23/06 07:45 PM 01/23/06 07:45 PM |
Posts: 138 | The Hobie Class has been spoiled with the top-shelf race management we've gotten from the likes of Paul Ulibarri (running the Tornados at the Miami OCR this week), Mark Santorelli, Mike Walker and Irene McNeill at our major events. That's why Mike and Karen Grisco got confused with the separate start/finish lines. They're not likely to make that same mistake twice. I guess I am a little late on this but one of the indviduals above did an event a few years ago and they were the worst PRO I have ever seen. The point is everything will not always be perfect for everyone. If you have a problem: tell the PRO, If you had fun: tell everyone. I'll bet it rhymes with Cherry  and you had a "Fever" ??? | | | Re: Tradewinds Story and Pix
#64952 01/23/06 09:42 PM 01/23/06 09:42 PM |
Posts: 81 | Second, the course is hardly substandard or outdated...it's the OLYMPIC sailing course that can be found HERE. Jake, just one correction. The Tornados have not raced around reaching marks for a long time (like since early 90s) (including the Olympics). Personally, I'm not a huge fan of the reaching legs. But that's mostly because I suck at them. Haven't practiced them enough. I don't thinks they are a big deal when we are doing three laps around the course. Plenty of time for tactics after the first lap. | | | Here: Let me steal this thread!
[Re: F18OxJ]
#64953 01/23/06 10:50 PM 01/23/06 10:50 PM |
Posts: 744 | Y'Al, RICK WHITE ROCKS!!  Bob
2,478
guests, and 337
