| Re: Hull life
[Re: newsteve]
#65498 01/26/06 11:57 PM 01/26/06 11:57 PM |
Joined: Mar 2003 Posts: 943 East Gippsland, Australia Tim_Mozzie
Posts: 943 East Gippsland, Australia | It does depend on the type of hulls. The foam/kevlar boats keep going really well - the only problem being that the earliest foam/kevlar boats (up to 18yo now) were built with finer hulls that are not as buoyant and do not manoevre as well as the more recent designs (90s).
My foam/kevlar Fay hulls are approaching 10 years old and are as stiff and competitive as new ones except that they are now around 2kg over weight. The day I make so few mistakes on the course that 2kg would make a difference I'll trade it in for some new Boyer hulls.
As for timber hulls. I have no experience there so I couldn't tell you. I would guess it depends a lot more on how well the hulls have been looked after.
Tim Shepperd Mosquito 1775 Karma Cat
| | | Re: Hull life
[Re: Tim_Mozzie]
#65499 01/27/06 06:40 PM 01/27/06 06:40 PM |
Joined: Jun 2004 Posts: 502 Port Noarlunga, SA, Australia Darryn
Posts: 502 Port Noarlunga, SA, Australia | It does depend on the type of hulls. The foam/kevlar boats keep going really well - the only problem being that the earliest foam/kevlar boats (up to 18yo now) were built with finer hulls that are not as buoyant and do not manoevre as well as the more recent designs (90s).
My Hulls are 18 year old kevlar/foam built by Boyer, still in good condition and not overweight (55.5kg). The boat is more competitive then I am  Darryn 1704 | | | Re: Hull life
[Re: newsteve]
#65500 01/30/06 06:23 AM 01/30/06 06:23 AM |
Joined: Jan 2006 Posts: 556 Somers, Westernport Bay, Victo... Peter_Foulsum
Posts: 556 Somers, Westernport Bay, Victo... | Steve, I have an older Mozzie with timber hulls and timber foils and while it is best to go for the low maintenance option the timber hulls can still be competitive. If you do choose to go the timber option look out for cracks below the inboard side of the front beam. If this is found it's not too hard to fix with epoxy sealer, fibreglass cloth and epoxy filler.
It is also important to go for hulls that are as light as possible (foam frames and minimal use of internal stringers)so that you can keep up with the other minimum weight Mozzies and have as much buoyancy as possible. This is where the newest Mozzies have even greater advantage with maximum buoyancy already designed into the mould.
If you go for timber I would also recommend that you go for hulls that were built by a professional boatbuilder rather than a backyard builder. They usually had the right strength to weight ratio but were probably raced and stressed allot more. What a dilema !!
As you say it's easy to buy a new sail and rig to get best possible forward thrust. I'll let you know what difference a new powerplant makes in a couple weeks when I get my new sail.
Good luck with your search.
Mosquito 1814 Macka Mozzie
2,883
guests, and 311
Mod | | Forums35 Topics22,989 Posts268,931 Members8,150 | Most Online23,979 Sep 24th, 2025 | | | |
