| Re: 5.8 lowering main
[Re: pitchpoledave]
#65580 01/29/06 09:43 PM 01/29/06 09:43 PM | Anonymous
| Anonymous
Unregistered | That makes a BIG difference on my Hobie 17 !!!!  Doug Snell Hobie 17 www.tcdyc.com | | | Re: 5.8 lowering main
[Re: peterbro1]
#65581 01/29/06 10:06 PM 01/29/06 10:06 PM |
Posts: 12,310 South Carolina | The 5.8 system should be pretty reliable. The basics are to have someone heave on the halyard to raise the sail slightly above the hook. Then rotate the mast hard one direction (you really need to get it to 90 degrees of rotation). Then, with the mast still rotated, pull down on the sail and hopefully it's unhooked. If that didn't work, try again but rotate the opposite direction. If that still doesn't do it, take a close look at your knot and do as Dave suggested and reverse it so the bulk of the knot is on the other side of the ring.
Jake Kohl | | | Re: 5.8 lowering main
[Re: MauganN20]
#65583 01/30/06 09:34 AM 01/30/06 09:34 AM |
Posts: 778 Houston | or make an eye splice around the ring NO, Not unless you know what you are doing It works for some rings It does not work for others It really screws up some by jaming in the sheave at the mast top. Plus, sailmakers are starting to attach the ring to the sail. Carl | | | Re: 5.8 lowering main
[Re: peterbro1]
#65589 01/31/06 02:00 PM 01/31/06 02:00 PM |
Posts: 99 Chicago, IL | Make sure that your n5.8 is facing the wind – otherwise you can do all those tricks described above and still have problem lowering your main.
Just my 2 c
I20
[Re: Krisu13]
#65590 01/31/06 05:27 PM 01/31/06 05:27 PM |
Posts: 5,590 Naples, FL | Next time you're going out on that 5.8, give me a call (or e-mail). I'll help you rig it so that it won't get stuck up there.
[Re: waterbug_wpb]
#65591 08/02/06 09:08 AM 08/02/06 09:08 AM |
Joined: Jun 2006 Posts: 35 Charlottesville, VA sruffner
Posts: 35 Charlottesville, VA | First off, my apologies for dredging up a topic which seems to be well-hashed out. I know this is an 'old' thread, but I really need some advice. This is also for a Prindle, not a Nacra.
I am still having a lot of trouble with unhooking my P-18 mainsail - I haven't managed to do it successfully yet, and while I'm getting good at tipping the boat over on it's side, I'd prefer to actually 'do it right'. Can I get some clarification on a few of the items/ideas/descriptions mentioned here?
I read this thread before re-rigging my boat, and ordered the Aussie ring from Rick, and have omitted the twist shackle as well. I've tied the halyard with a bowline to the offset loop in the ring, and the welded shackle is attached to the head. This keeps the ring almost perfectly parallel to the hook, and I have no trouble getting the ring on the hook! Given how close the welded shackle is to the mast and the length of the hook on the mast, I don't see how there is enough room for the hook to clear the side of the ring when the mast is rotated. When I'm raising the main, the ring pops over the hook with a very distinct sound - I think the hook forces the edge of the ring out.
The Prindle manual clearly shows the twist shackle being used.
So, my questions:
1. Most folks have talked about 'being sure to tie the knot facing towards the rear'. I'm a little puzzled by this. Without a twist shackle, the option is to have the offset Aussie welded loop (lanyard?) to either port or starboard. Is the implication to have the bulk of the body of the knot towards the rear?
2. Maybe I do really need the twist shackle? Without it, the ring is aligned with the beam instead of fore and aft as David describes above. It also doesn't rotate easily, which I had expected would help, but seems to be hurting. I am not sure if there is enough room between the top sheave and the head of the sail to accomodate that much "stuff".
I have used some McLube SailKote very liberally on both the luff and the track, but the last foot or so of hoist is a real trial. Right now I'm using some cheap nylon for a halyard, which stretches way too much for me to be able to tell if the ring is moving at all once it's locked up there. I am going to replace it with some Stay-set this weekend, and try again.
Any extra tips or advice would be greatly appreciated.
Scott | | | Re: 5.8 lowering main
[Re: sruffner]
#65593 08/02/06 09:15 AM 08/02/06 09:15 AM |
Posts: 12,310 South Carolina | Watch your batten tension - apparently super tight battens can make hoisting tougher. Second, having the line exit the ring toward the mast will tend to tip it foward and away from the ring as it is hoisted for release. That said, when releasing, try to keep a little tension on the halyard while you rotate the mast AND pull down on the sail (this will take three hands). Be certain you are rotating the mast at least 90 degrees when trying to unhook and it might be helpful to have someone bend the clew of the main toward the center of the boat while everything is rotated (to twist the main away from the hook).
[Re: sruffner]
#65595 08/02/06 05:34 PM 08/02/06 05:34 PM |
Posts: 12,310 South Carolina | You SHOULD be able to pull the mast all the way up, keep a slight amount of tension on the halyard (enough to just keep the sail from sliding back down), rotate the mast, and with the mast rotated and someone maintaining that slight tension on the halyard, pull down on the sail - you shouldn't need downhaul to pull it down. Remember that when you pull down, the mast must still be rotated sharply and it will probably help to have someone keeping a little bit of tension on the halyard. Sometimes, however, these things defy all logic and maybe NOT putting tension on the halyard will let it come loose. Sometimes rotating the mast in the other direction will make it come off easier...point is, use these instructions as a guide but mix it up until you find the combination of sequences that will unhook it - you'll get it.
Jake Kohl | | |
2,545
guests, and 459
