| Stays #66011 02/01/06 03:58 PM 02/01/06 03:58 PM |
Posts: 2,921 Michigan | I was out yesterday and noted that one of my shrouds has a little rust at the bottom where the wire is swaged into the buckle. I know this is bad and am going to replace all the standing rigging. After having a mast on a 31ft mono come down in almost wind- I am not taking any chances on my boat. Aside from that, barring any problems, people say to do this every 1.5-2yr? You have to be kidding- how many people actually do this?. Anyone have any suggestions as to where I could order these? I know they are likely custom- but who would you recommend?
| | | Re: Stays
[Re: PTP]
#66013 02/01/06 04:30 PM 02/01/06 04:30 PM |
Posts: 3,293 Long Beach, California | My friendly catamaran dealer helped me make up my first replacement set - talk to Sawyer at Key Sailing. Much cheaper than going to West Marine. If you want to buy pre-made or custom stuff, Rick's shop (on this site) can fix you up quick.  I had a factory set of wires fail after two years. I think you can go longer if you do the fresh water rinse and keep an eye on it, espesh now that you know what to look for.
| | | Re: Stays
[Re: PTP]
#66014 02/01/06 04:32 PM 02/01/06 04:32 PM |
Posts: 606 Maryland | Murrays, Salty Dog, and your local Performance Cat dealer have the specs for Nacra 6.0NA stays. Trying to recall if the Express had the same mast but with double diamonds. New England Catamaran is also a good bet.
Kris Nacra F-18
Kris Hathaway | | | Re: Stays
[Re: Tony_F18]
#66015 02/02/06 05:55 AM 02/02/06 05:55 AM |
That process is called metal fatigue and we don't load our rig up with that much most of the time. Sidestays are typically loaded between 30 % and 50 % this increases the number of cycles before breakin enormously. Besides the magnitude of the change of loading is also important. You are talking about full release after each 75 % load. On cats the amplitude is much smaller.
I've been sailing with my Prindle 16 stays for 7 years and I bought the boat secondhand. Never had a problem and I sailed that baby alot.
Replacing every 2 years is too often for recreational sailing.
| | | Re: Stays
[Re: PTP]
#66024 02/02/06 05:47 PM 02/02/06 05:47 PM |
Posts: 1,203 uk | I've seen a fair few shrouds break, but all that I can remember are on boats that are sat in the boat-park for long periods with the rigging left slack and the mast jerking about in the wind. Saying that, I am a believer that shrouds should be changed ever 2 seasons. I have a workshop full of old ones. It always amazes me when someone spots a shroud or trap wire fraying at the swage, they then go and just replace that one alone! Surely if one has come the the end of its lifespan, they all need changing. I am also surprised when people only replace one broken J+H handle too! I like to relax a bit on the wire!
| | | Re: Stays
[Re: TEAMVMG]
#66025 02/03/06 11:30 AM 02/03/06 11:30 AM |
Posts: 49 Israel, Sdot Yam | We just replaced all our shrouds (2 -3 years old) and diamond wires on our Nacra 6.o NA after finding several broken strands on the timble of the side shroud. Also replaced the diamond spreaders with new stainless steel spreaders, as the old ones were corroded. Went out today in 20 knots and 3=5 ft waves, confident in our new gear.... and down came the mast  . The rod tensioning the bow foil broke at the edge, where it is welded into a T shape. Lesson learned - it's what you don't replace periodically that gets you Opher Nacra 6.0 NA Israel
Opher Nacra F20C ISR1 F18 Cirrus ISR2 Sdot Yam, ISRAEL
| | | Re: Stays
[Re: Opher]
#66026 02/03/06 11:35 AM 02/03/06 11:35 AM |
Posts: 2,921 Michigan | Opher- Thats too bad about the mast. I need to really give my boat a complete check. I ordered 2 new shrouds from murray's and am going to get a new forestay (can only get vinyl coated forestays from murrays, and it seems like there is already too little room to get the halyard line through the luff of the jib so I am going to get a non-coated wire for the forestay). I will inspect the diamond wires more closely the next time I have the mast down. When your mast came down, did it damage anything badly (i.e. is your mast bent now? Damage to the hulls.. etc?)
| | | Re: Stays
[Re: MauganN20]
#66028 02/03/06 05:17 PM 02/03/06 05:17 PM |
Posts: 49 Israel, Sdot Yam | Ouch! Which way does the mast fall when the hound gives way? Luckily for us no damage other than the bridle foil rod. We were double trapped when we heard a lound bang and the mast slowly dropped to leeward, leaving us trailing in the water.... The fun part was beaching through the surf - luckily it was an onshore wind and we weren't too far off. Ended up getting the beach wheels and rolling her the mile home With any luck we'll be out racing tommorrow
285
guests, and 47
