| Re-surfacing Carbon Fiber Spin Pole #66166 02/05/06 03:03 PM 02/05/06 03:03 PM |
Posts: 54 PA, Bucks | With the temperatures in the 40-50s here in the Northeast, it’s hard to push aside thoughts of sailing and my spring projects. One of the projects I know I have to tackle is my spin pole. The carbon fiber material on the pole is beginning to show through. In addition to the rash I get every time any skin comes into contact with it  , I'm concerned that the UV will continue to damage it this summer. I know it needs to be covered. But with what? One windsurfer dealer suggested I repaint it with Rustolium, which appeals to me due to its simplicity  . Someone else suggested the WEST System, which sounds good, but when I visit there website, I couldn’t find any paints I was planning to lightly wet/dry sand the entire pole and repaint it with Awlgrip - but if there is a better way, I'd like to hear it. Has anyone else encountered this problem? Thanks! Bill Nieuwkerk N6.0na H17 | | | Re: Re-surfacing Carbon Fiber Spin Pole
[Re: Nieuwkerk]
#66167 02/05/06 03:44 PM 02/05/06 03:44 PM |
Posts: 12,310 South Carolina | When someone suggests "West System" they're usually advising to put a coat of their epoxy on it. While this is a great water proof barrier, it doesn't stand up to UV too well and tends to yellow and eventually crack.
Krylon/Rustolium would probably hold up OK for a quick and easy finish and be really easy to touch up later (you will probably need to).
Awlgrip is probably the best ... a good paint like Dupont Imron would do well too. I believe both of these paints are two part paints that you mix with a catalyst - they do not air dry, rather they cure like epoxy or polyester resin.
Jake Kohl | | | Re: Re-surfacing Carbon Fiber Spin Pole
[Re: Nieuwkerk]
#66172 02/06/06 12:44 PM 02/06/06 12:44 PM |
Posts: 1,226 Atlanta | I would also recommend paint, not uncoated epoxy. Epoxy will suffer from UV exposure. The 2 part paints are best. However, Imron and Alwgrip are nasty, chemical, smelly. You wouldnt want to breath it, plus you are limited to areas with good ventilation and heat. That makes it tough to use those kind of products. Check out System Three, its water based, doesnt smell and you can work with it inside, I use it on parts in my basement. No smell, no fuss, drys quick. Its a very strong 2 part water based poly marine paint. Sand with 100 grit, and apply to your pole, go with more/thin coats as opposed to fewer/heavy coats. I use a foam brush, so I just toss it when I'm done. You can spray it, but the paint doesnt go as far. One quart will do a doz spin poles. $25 bucks a quart. http://www.systemthree.com/p_wr_lpu.asp | | | Re: Re-surfacing Carbon Fiber Spin Pole
[Re: bvining]
#66173 02/06/06 06:43 PM 02/06/06 06:43 PM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | One other idea would be to wet sand it with #400, then find a local body shop that uses quality auto paint. No Earl Schieb's. Take the pole down and have them spray it with urethane clear with the flex additive. The modern clears are very durable with the flex added.
[Re: catman]
#66174 02/07/06 10:14 AM 02/07/06 10:14 AM |
Posts: 1,187 38.912, -95.37 | I was planning to lightly wet/dry sand the entire pole and repaint it with Awlgrip - but if there is a better way, I'd like to hear it. Had the same problem, I was tired of wearing leather gloves when handling my mast. So...I did some research on this last Winter and found that most OEM's use Awlgrip. I don't know if there's a "better" way, but Alwgrip comes in a satin finish as well as gloss.
[Re: bvining]
#66175 02/07/06 10:42 AM 02/07/06 10:42 AM |
Posts: 778 Houston | Changing the subject Check out System Three, ...Its a very strong 2 part water based poly marine paint.
Is the crosslinker required to cure or just there to make the paint harder? | | | Re: Re-surfacing Carbon Fiber Spin Pole
[Re: carlbohannon]
#66176 02/07/06 01:46 PM 02/07/06 01:46 PM |
Posts: 12,310 South Carolina | I saw that too and dove deeper...somewhere on the System Three website they said that the paint would cure without the cross linker but that it would not be as durable.
[Re: bvining]
#66178 02/08/06 01:52 PM 02/08/06 01:52 PM |
Posts: 169 Santa Barbara CA | Hey Bill, as the guy that suggested WEST System, I thought I'd clarify so people don't think you were talking to an idiot, they have a UV inhibitor additive that keeps it from yellowing, but if you are not worried about clear coating so as to see the carbon, any of the above would work...I would be careful about sanding though, you don't want to srcatch the fibers and create stress risers...
P.s. Whats up with moving out to Santa Barbara?
Matt the S.B. Cats guy
[Re: bvining]
#66180 02/08/06 07:37 PM 02/08/06 07:37 PM |
Posts: 12,310 South Carolina | While I've not had any direct experience, I got the impression from the West System website that even the 207 hardner does not make the epoxy REALLY stable with UV. However, for the limited exposure a spin pole probably gets, it would probably be fine.
#66181 02/08/06 09:30 PM 02/08/06 09:30 PM |
Posts: 169 Santa Barbara CA | No, I meant Bill Nieuwkirk, the guy who started the post. He came out from back East, and we got a sail in on his business trip...
[Re: Nieuwkerk]
#66183 02/10/06 12:46 AM 02/10/06 12:46 AM |
Posts: 54 PA, Bucks | Matt,
Thanks for all your help. To answer your question, better than even odds that we'll be moving out towards your direction.
Also, for anyone traveling out to LA,there's a place to rent cats (Santa Barbara Catamarans) right on the beach. They have a great selection which includes a Hobie Wave, H16, two Nacra 5.2, Nacra 6.0 and a Prindle 19. They're all in great shape. I took out the Prindle with Matt, and learned a thing or two (or three).
Santa Barabra is a slice of paradise and the sailing is spectacular. I'd highly recomend it.
Also Matt, I bought Bethwaite's book on High Performace Sailing and its a real eye-opener. Great reading for anyone on this forum.
Thanks again Matt!!!
Bill | | |
2,517
guests, and 112
