H16 question #67178
02/19/06 09:39 PM
02/19/06 09:39 PM
Ventura, CA
jes58 Offline OP
jes58  Offline OP
Ventura, CA
I think I should have posted this here, and not on the open forum - hey I am new at this!!!!!!!
Anyhoot what is the best method for breaking down a Hobie 16? I am helping a friend replace his H16 front cross beam and we are having a dickens of a time tearing the boat apart. Are there any tricks? We have taken out all of the bolts, popped out all the rivets, saturated where the castings and extrusion meet with PB Blaster and started tapping on it – and no luck. I didn’t want to break out the ole 10 pound made in USA sledge before asking, and am somewhat cautious about the post that comes out of the hulls; we don’t want to do any damage there. Have been thinking about using a scissor jack with some 2 X 4’s in between, any ideas.
Re: H16 question [Re: jes58] #67179
02/21/06 05:07 PM
02/21/06 05:07 PM
Minnesota
Jeff Peterson Offline
Minnesota
First Question: Is it possible that it has been epoxied together?
Jeff Peterson
H-16 Sail #23721
Big Marine Lake, MN
Re: H16 question [Re: Jeff Peterson] #67180
02/21/06 07:25 PM
02/21/06 07:25 PM
California
mmiller Offline
mmiller  Offline
California
A Hobie 16 requires heavy blows from a sledge on a wood block or, I prefer, a dead blow (Sand filled mallet... a big one.) You have to wack the heck out of them. I sometimes have to swing a sledge pretty hard to get them apart.
The post is very solid in the hull.
Hobie Cat Forums
Matt Miller
Hobie Cat Company
Re: H16 question [Re: Jeff Peterson] #67181
02/25/06 11:05 AM
02/25/06 11:05 AM
Ventura, CA
jes58 Offline OP
jes58  Offline OP
Ventura, CA
We hope not, that would not be legal would it?
Re: H16 question [Re: mmiller] #67182
02/25/06 11:06 AM
02/25/06 11:06 AM
Ventura, CA
jes58 Offline OP
jes58  Offline OP
Ventura, CA
Thanks Matt - will do
Re: H16 question [Re: jes58] #67183
02/25/06 08:02 PM
02/25/06 08:02 PM
It is class legal to glue the boat together. It is possible to get them apart after, but it takes a lot of work - and gentle use of a torch.
Re: H16 question [Re: mbounds] #67184
02/26/06 12:59 PM
02/26/06 12:59 PM
Ventura, CA
jes58 Offline OP
jes58  Offline OP
Ventura, CA
yesterday we were successful in getting th boat apart with out having to have break out the ole sledge hammer.
Using a bottle jack, a few 4X4's with some earthquake straps and some 2X4 braces (to keep the lateral tourqu in place) we had no issue in getting the boat apart.
After riging everything and a few pumps on the jack - presto, the boat came apart.
As for the epoxy part, I read that it is OK to do this, and that may be consodered. If we don't, we are going to emry all of the corrosioin on the castings and extrusion amd use some anti size when reassembling.
Thanks, and if you want a pick of the rig let me know.
Re: H16 question [Re: jes58] #67185
03/01/06 02:36 PM
03/01/06 02:36 PM
Syracuse,N.Y
pbisesi Offline
pbisesi  Offline
Syracuse,N.Y
I give the post and corner casting a painted on coat of epoxy when glueing.Assemble,then turn over the boat,square it up, and drip epoxy into the voids. It takes some time but they fill up nice and the boat stays tight. My theory is that the coating helps prevent the metal to metal corrosion. The casting then can be heated and the boat will come apart with a dead blow hammer as Matt M. said. I have more trouble taking apart old unglued boats then the ones I've glued.
Take a kid out sailing. I hope all you 16 guys are coming to the Madcatter.
Pat Bisesi Fleet 204
Re: H16 question [Re: jes58] #67186
03/10/06 05:43 PM
03/10/06 05:43 PM
I have had good luck using a rubber mallet and wood 2X4 to separate.
0 registered members (), 3,115 guests, and 352 spiders.
