| Adjustment question. #67696 02/22/06 05:24 PM 02/22/06 05:24 PM |
Posts: 17 | I just purchased a 198? 16 for us to play with this summer  . I stepped the mast and the shrouds and forestay seem very loose. Without bringing the mast to far forward what would be the best way to take out the slack? How firm should I make the shroud and forestay? Also, can I get replacement bushings for some of the bolts and what should I use to close up around the shroud anchors in the hull? tks, | | | Re: Adjustment question.
[Re: Dlennard]
#67701 02/22/06 07:28 PM 02/22/06 07:28 PM |
Posts: 35 Portland, ME | Dlennard, You are exactly right. When you hoist the jib, the wire luff on it becomes the new forestay and it pulls the mast forward considerably and tensions up the whole rig. You'll notice a fiddle type block at the bitter end of the jib halyard and a cheek block mounted to the mast. Rig these two up with about 20' of 1/4 inch line and hoisting the jib/tensioning the rig will be a snap. If you want to sail jibless, you'll have to add some sort of other line or wire stay to tension up the rig with. jrg
Hobie 16
[Re: jrg]
#67702 02/22/06 08:47 PM 02/22/06 08:47 PM |
Posts: 12,310 South Carolina | But wouldn't you want the rig at least 'snug' if you were going to leave it rigged on the beach for extended periods? The wind might knock the mast back and forth resulting in some extra wear on the rigging and hulls.
Jake Kohl | | | Re: Adjustment question.
#67703 02/22/06 09:00 PM 02/22/06 09:00 PM |
Posts: 35 Portland, ME | Yup... I just use an old piece of 1/4 line. I tie one end to the bridle and the other end to the jib halyard shackle and haul it up to tighten the rig. I wouldn't recommend sailing with this though, only a stationary, temporary setup, obviously. jrg
Hobie 16
[Re: WidDunesDavid]
#67705 02/22/06 10:11 PM 02/22/06 10:11 PM |
Posts: 35 Portland, ME | WidDunesDavid, I'll try my best to help. I've only been sailng a 16 for a couple of summers, but I may be able to help with some things. The best place to start for replacement parts is here... http://www.hobiecat.com/support/tech/h16parts.htmlIt is a parts diagram for your boat. You'll also want to order the free catalog here... It's filled with TONS of great stuff. http://www.hobiecat.com/sailing/accessories.html#catalogAs far as the shrouds go, you'll want everything pretty tight. When you're sailing the leeward shroud will be a little slack, but when the boat's on the beach all three should be pretty tight. I don't really understand what you mean by "close up the shroud anchors in the hull." And what bushings are you talking about? Let us know and we'll do our best to answer. jrg
Hobie 16
[Re: WidDunesDavid]
#67707 02/23/06 10:07 AM 02/23/06 10:07 AM |
Posts: 35 Portland, ME | I see. On my 16 the holes through which the shroud anchors go are only through the top lip of the hull, meaning that there is no place for the water to actually get into the hull through that hole. I wonder if yours have worn through the inside edge and have made a small hole clear through the fiberglass. If you back out the shroud anchors, can you see into the hull? If so, it may be time for some fiberglass and epoxy repairs... As far as the bridle anchors in the bows of the boat, mine have swiveled around and worn out a bit of the gelcoat. If it bothers you I suppose you could put some washers between the clip and the fiberglass, or maybe silicone them into place so the holes don't get any bigger. If you order the Hobie Catalog the last 15 or so pages contain the exploded diagrams and part numbers for all their boats.
jrg
Hobie 16
[Re: jrg]
#67710 02/23/06 12:59 PM 02/23/06 12:59 PM |
Joined: Aug 2003 Posts: 351 Santiago, Chile Andinista
Posts: 351 Santiago, Chile | Dlennard, You are exactly right. When you hoist the jib, the wire luff on it becomes the new forestay and it pulls the mast forward considerably and tensions up the whole rig. You'll notice a fiddle type block at the bitter end of the jib halyard and a cheek block mounted to the mast. Rig these two up with about 20' of 1/4 inch line and hoisting the jib/tensioning the rig will be a snap. If you want to sail jibless, you'll have to add some sort of other line or wire stay to tension up the rig with. jrg Doesn´t the forestay get tensioned anyway when going upwind, because of the elasticity of the halyard? (or is it a wire too?) | | | Re: Adjustment question.
[Re: Andinista]
#67711 02/23/06 01:28 PM 02/23/06 01:28 PM |
Posts: 306 St. Louis, MO | The H16 jib has a wire line in the luff so there is not much streach there. As for the halyard streaching, I never had a problem with that. I just use low streach line and the 2:1 purchase as described earlier in the post.
Nick
Current Boat Looking for one
[Re: WidDunesDavid]
#67712 02/23/06 03:37 PM 02/23/06 03:37 PM |
Posts: 5,582 “an island in the Pacifi... | Set the shrouds in the lowest hole in the chain plates. Step the mast. The forestay will be loose. Raise the jib and, using the thimble in the end of the halyard, cheek block and cleat on the side of the mast to make a 3:1, tension it very tight. That'll take all of the slop out of your rig.
If you want to use a better 3:1 system, buy or assemble a Aussie halyard system. Add a small cheek block on the mast just above the top batten and run the halyard around it. That'll keep the halyard on the side of the mast so the battens won't hang. US Sail Level 2 Instructor US Sail Level 3 Coach | | |
2,822
guests, and 587
