Page 3 of 3 1 2 3
Re: Speedo GPS and VMG [Re: Jake] #67941
02/27/06 11:26 AM
02/27/06 11:26 AM
St. Louis, MO,
Mike Hill Offline
Mike Hill  Offline
St. Louis, MO,
What's next stall warning horns for apparent like they have in airlines?
"Dweidle Dweidel Dweidle Fall Off Fall Off you going to slow - Dweidle Dweidel Dweidle"
That would be too cool. I could definitely use one of those. How do they work on airplanes? I think we have a new invention in the making.
Mike Hill
www.stlouiscats.com
I could use one of those!
Mike Hill
N20 #1005
Re: Speedo GPS and VMG [Re: Mike Hill] #67942
02/27/06 12:15 PM
02/27/06 12:15 PM
It's usually a little metal tab mounted on the leading edge of the wing (on a Cessna type, not a jet), just low of middle (top to bottom), normaly it is held down by airflow and gravity, which keeps the warning horn silent, but as you approach the "stall" angle of attack (usually around 17 degrees to relative wind) the flow over the wing begins to separate, the little metal tab moves up, which closes a switch and makes the alarm sound. We have the same thing on sails; Tell Tales, just no aural warning.
All you would need for an aural warning is to make the tell tales out of metal tape, with a metal conductor patch in the sail where they should normally flow, and then when they lift, the alarm would sound...of course you also need to run wires in the sails, bateries, (or solar panels) and a warning horn of some type. OR...just pay your crew to tell you not to pinch!
Hearing the velocity of the apparant wind [Re: Timbo] #67943
02/27/06 12:58 PM
02/27/06 12:58 PM
US Western Continental Shelf
hobiegary Offline
hobiegary  Offline
Personally, I think that the most usefull reading, upwind on a catmaran would be apparant wind speed; keep it as high as possible! I want a very faint audio pitch (in my ear from my sunglasses frame or helmet) in my ear that varies in pitch as the wind varies in speed. ("Electronic Shroud Whistle")
Maybe I'll try fastening a whistle to my forestay's bridle wire. Like one of those deer/elk warning gizmos.
GARY
Santa Monica Bay
Re: Speedo GPS and VMG [Re: Timbo] #67944
02/27/06 03:28 PM
02/27/06 03:28 PM
chesapeake bay
davidn Offline
davidn  Offline
chesapeake bay
Mine would be squawking at me all the time. I actually had the good fortune at the last race of the year (last year) to have an experienced crew who would just quietly say "pinching" as soon as he felt the speed drop off. It was a great help and in a short while kept me more attentive to that situation.
DavidN
H20 781
Page 3 of 3 1 2 3
0 registered members (), 266 guests, and 73 spiders.
