Page 1 of 5 1 2 3 4 5
Painting a timber Mossie #69371
03/16/06 07:09 PM
03/16/06 07:09 PM
Melb. Aust
Trevor Offline OP
Trevor  Offline OP
Melb. Aust
Hi all,
I am currently in the process of painting my old Mossie. Question is - What to paint it with? It appears to have 2 pack sides and it had sunburnt varnished decks.
The decks will be painted instead of varnished this time. Should I use 2 pack all over it? and if so do any of you spray the stuff. The paint website (International) says it can't be sprayed, but the stuff that is on the boat now is definately sprayed on.
Any tips gratefully accepted!
Mozzie 1828
Sugarloaf Sailing Club
Melbourne
Re: Painting a timber Mossie [Re: Trevor] #69372
03/16/06 10:42 PM
03/16/06 10:42 PM
soggy Offline
soggy  Offline
Hi Trevor,
I have just about finished painting a Mossie. Its been a long slow haul. I have lots of advice, probably to much to put in here, feel free to give me a call on [h] 02 6258 9481 or [w] 02 6275 4950.
Paul Wiggins
Canberra
Re: Painting a timber Mossie [Re: Trevor] #69373
03/19/06 07:14 AM
03/19/06 07:14 AM
Peter_Foulsum Offline
Trevor,
2 pack epoxy is definitely the way to go and yes you can spray it once it is thinned down properly. I sprayed my hulls with International paints last time around with no problems or issues.
It is important to get the hulls back to bare timber so that the new coating system can bond properly. You may have to give the decks some additional care since they were varnished. Any good yacht chandler should be able to advise you on any special treatment.
Once you get the hulls back to bare timber give them a couple of brushed coats of International 2 pack Everdure Primer and sealer. It will sink straight into the timber and provide a hard surface that is resistant to cracking particularly in the areas of most traffic. It is absorbed so well you won't even see any brush marks.
I had a whole stack of info on the Mozzie website regarding painting hulls. If someone still has access to it and can put the info on this website that would help you greatly.
Peter
Mosquito 1814
Macka Mozzie
Re: Painting a timber Mossie [Re: Peter_Foulsum] #69374
03/19/06 08:18 PM
03/19/06 08:18 PM
East Gippsland, Australia
Tim_Mozzie Offline
Tim_Mozzie  Offline
Here is that thread about painting from the old forum:
Wayne Wildenburg
12/5/05
G'day all,
I am in the process of stripping back 2 glass hulls for repainting and was wondering if any of you gurus had any thoughts on which primer and paint was a good combination.
The Decks are ply.
I was hoping to use a filler primer combination to fill any sanding marks or wood grain that are left over after orbital sanding, as I would like to give the hulls that nice gelcoat smoothness, without any real increase in weight (the hulls alone are min weight). Any feedback would be appreciated.
Thanks
Wayne
Peter Cobden
18/5/05
Wayne,
Getting information about repainting a fiberglass boat you would be best talking to Jim Boyer at Boyer Fibrecraft in Bendigo his number is 03 54477700. You may find that Jim built the boat in the first place. It would also be a good idea to weigh each hull as you work on them. If you can keep the maximum weight for one bare hull under 20.5kgs you should make the minimum 55kgs platform weight.
Good luck
Peter Cobden
Peter Foulsum
18/5/05
Wayne,
STOP !!! Don't take to it with an orbital sander !! It's too destructive and your Mossie deserves better. I have a timber Mossie so I can't help with the fibreglass areas but for the timber decks purchase an industrial strength paint stripper and apply in short sections and strip back. When the applied section has bubbled up and soft strip the paint off. Don't wait for it to go hard. It won't come off easily once dry. Go over areas that haven't lifted again. When complete use a medium grade sanding paper and cork block and clean up the decks by hand. Your Mossie deserves care and patience. Don't sand too hard or you may go through to the next level of ply. You don't know how many repaint jobs it's had already.
When you are happy with the surface wipe off all sanding dust and apply a good 2 pack surface primer by brush. I use International Everdure available from most yacht fitting suppliers. This is a thin epoxy and sinks into the bare timber filling all micro cracks and provides a very strong base to paint over the top of. So far it has prevented any re-cracking of high wear areas that were previously an issue. I was able to apply a second coat immediately after finishing the 1st coat. The primer is so thin it soaks into the timber like a sponge.
When you have applied enough coats (see the manufacturers instructions) then fill any dents or grooves with 2 pack filler and sand back smooth (I assume you are going to paint the decks rather than varnish).
Apply undercoats then top coats all from the same manufacturer with a spray gun. I use a hand held electric gun with a professional paint spraying tip with good results.
Don't forget to mask off areas you don't want overspray on. Don't be stingy with the masking tape either. Use a top product for a proper job. It's really disappointing to spoil the paint job because you used any old masking tape and the paint seeped underneath it. For a great paint finish remember it 90% preparation and 10% application.
Good luck and happy sailing.
Stephen
27/7/05
A quick question, if I used paint stripper on my wooden paper tiger, would the paint stripper affect the resin and glass tape on the seams?
Cheers, Stephen
Peter Foulsum
27/7/05
Stephen,
I have stripped my wooden Mozzie without any problems. The stripper is only on the surface for only a very short time. Just wait long enough for it to lift the paint adequately then scrape it off. If the resin was of good quality and set properly there shouldn't be any issues. Apart from that why are you sailing a Paper Tiger ??
Paul Wiggins
3/10/05
Hi Guys, I need to strip back the forward tops of the hulls due to cracks in the paint. From what I read above it may be best to to go back to bare timber and start from there. I would appreciate advice on the process to follow, [starting with a 2 pack surface primer.]
Thanks.... Paul
Peter Foulsum
6/10/05
Paul, Please see my note above posted on 18/05/05. That pretty much describes the process and yes you do need to strip the deck back to get the best result. The 2 pack primer I used was the key to a deck that is strong and has great resistance to further cracking. Data sheets from the yacht chandler who sells the paint is also required reading prior to starting. A 2 pack paint (undercoat and top coat) is better than a single pack also because it's harder and stronger. Don't scrimp on the cost of the paint either; you don't want to repeat the process for the next season.
p.s. Don't get a deck colour that's too dark because it will expand and shrink in the sun too much and you may end up with cracking again.
Wayne Wildenburg
7/10/05
I just realised that I did not say thank you the responses that I got to my original question...so.....thanks.
Wayne
Paul Wiggins
10/10/05
Guys some more help please???? How difficult is it to detach the hulls from the beams... What are the sealing requirements when putting it back together?
Thanks....Paul
Peter Foulsum
10/10/05
Paul, the difficulty in getting the beams off depends on how much sealant has been applied previously. If the sealant is up to the deck on the fore and aft sides you may find it difficult. Remove the trampoline to remove any lateral tension then undo the nuts on the inside of the hulls and unscrew the bolts through the beams and set aside. There should also be load bearing packers on the underside if it's a timber boat. They may be recessed into the timber bearers.
See if you can lift the beam from the hull. If you can't then try to separate the sealant from the fore and aft sides of the beam with a sharp knife or scraper. If that doesn't work then pry a flat scraper between the beam and the hull on the flat inboard and outboard surfaces. Use the bottom face of the beam as a guide rather than the hull to try and prevent damage to the hulls. Keep persevering until you get separation.
I used to have a hell of a time trying to separate the beams from the hulls but always used way too much sealant.
Last time I decided that you really only need the sealant (waterproof silicone in tube/gun form from the hardware store) at the bolt holes so only applied a small amount around each hole and a small line between the holes. The clamping load from the bolts, load bearing packers, washers and nyloc nuts should be enough to keep the beams from moving although you will need to check it after the first couple of outings. So far the results have been excellent with minimal leaking from the beam areas.
If the Mozzie is timber check the holes through the deck for slop or damage. If they are in poor condition you will need to fill them with 2 part epoxy filler and re-drill to suit the beam hole spacings. This will provide a stronger and more rigid locking mechanism which further helps to prevent leaking. If you do this be careful that you set up the yacht square by using a measuring tape diagonally from bow to stern.
Good luck with the project.
Paul Wiggins
31/10/05
Well, removal of the hulls was a bit difficult, but the info supplied above made the job much easier. Thanks.
After a few long days both hulls are now stripped of paint and back to bare timber. From the look of the ply there was never a clear sealer applied as after the removal of the undercoat I seem to be back to 'natural' ply.
Some faint smudges of undercoat remain on the ply but I am hesitant to sand these for fear of damage to the ply. There are also some patches on the glass tape on the bow and stern.
My question: Is it OK to apply the Everdure [2 pack epoxy] over this?
Thanks for any incoming advice....
Peter Foulsum
2/11/05
Paul,
Well done ! It looks like you've done all the hard work.
I remember asking myself the same question with the smudges. The only way you'll know is if you apply a small amount of sealer over the existing patches and see what happens. Just use a couple of plastic bottle caps as measuring meters to mix a small quantity. Apply to the affected area and wait and see. The primer sinks into the timber very quickly and should be touch dry in about 30 minutes on a cool day. You should see very quickly whether you will have a problem with the residue undercoat.
I didn't have any problems with my Mozzie but it your previous paint system may have been quite different.
Tim Shepperd
Mosquito 1775
Karma Cat
Re: Painting a timber Mossie [Re: Trevor] #69375
03/20/06 08:52 PM
03/20/06 08:52 PM
Melb. Aust
Trevor Offline OP
Trevor  Offline OP
Melb. Aust
Thanks for your replies, particularly the orbital sander - I was going to attack the decks with that very beast!
I have decided to go with the NorGlass system (Aussie company and a helpful rep in Melbourne). I can spray on both the undercoat and top coat for a nice finish. Paint stripper will sort out the small patches of original varnish that remain on the decks and epoxy filler for the nasty bits.
If any one is interested I might put up some progress pics.
I have printed the entry form for the Sauna Sale in June and stuck it on the fridge as a 'dangled carrot' to get the boat finished...
Thanks all and see you on the water.
Mozzie 1828
Melbourne
Re: Painting a timber Mossie [Re: Trevor] #69376
03/21/06 05:59 AM
03/21/06 05:59 AM
soggy Offline
soggy  Offline
Hi Trevor,
some hints that may be helpful.
To strip the paint from the boat use a good quality stripper and most importantly a good quality scraper. The standard scraper [flexible stainless steel with a wooden handle is OK but has to be pushed and can easily dig in to the timber. Each of these blemished then need attention at some later stage.
The scraper I ended up using has a long stiff handle with a small right angle at the end holding a tungsten blade which was pulled along the surface and also easy to control the downward pressure. About $40.00 but worth every cent.
If the boat has good lines avoid removing the epoxy filler used for fairing as you will have to 'replace' it later on and this adds lots of work. It is only the paint [undercoat and topcoat and primer] that needs to be removed.
You will then need to sand the hull smooth, avoid removing to much [any] timber. If you are going to use an electric sander get a good quality random orbital sander but take it easy. I would not use it to remove the paint though.
As a previous post has indicated the next step is the sealer, I used multiple coats of the 2 pack Everdure, keep applying till you get a smooth glossy finish.
Then fill and fair any dints, scratches with epoxy putty. Spend some time on this as any imperfections will show thru on the final job.
A spray on primer filler can now be applied [I wish I had done this step] and sanded for smooth lines on the boat. Then its a couple of undercoats then about three topcoats.
As for the final coat, even with my non-existent spraying skills the sprayed finish of reaction lacquer was streets ahead of the brush finish of the new 'Perfection' brush on.
I contacted the manufacturer on this for advice.
They do not recommend spraying as the paint is slower drying than the reaction lacquer [now discontinued] and will not 'flash' dry [which allows multiple coats on the fly]. They indicated if sprayed it would result in runs and sags. I would not consider using 'Perfection' again.
All in all a fairly big job, but if done properly will result in a great looking boat.
I guess the main points are:
1. Use a quality scrapper
2. Don't remove to much of the epoxy filler
3. Spend time on carefully filling all scrathes and dents.
4. Spray the paints wherever possible.
5. Enjoy the experience!!
Paul Wiggins
Canberra
Re: Painting a timber Mossie [Re: Trevor] #69377
03/21/06 07:12 AM
03/21/06 07:12 AM
Trevor,
Would love to see some pics of the project before, during and after. May all your sandpaper be dry and clean.
Peter
Mosquito 1814
Macka Mozzie
Re: Painting a timber Mossie [Re: Trevor] #69378
03/22/06 06:56 AM
03/22/06 06:56 AM
Hi Trevor,
I can highly reccomend Norglass that is what was used on "Altered", it was recommended to me by Tim Heaney ex mossie sailor pro wooden boatbuilder who sprayed it for me, a truly beautiful finish, your not allowed to use Botany Blue though . In fact Tim H is about to use Norglass on the Sabre dinghy he is building, it was also used on his timber Mossie "Merlin" I think.
I have used Epoxy resin brushed on to ply to seal it in the past, takes some sanding afterwards though to get it ready for sprayed epoxy undercoat. Everdure sounds like it could be better.
Regards Gary.
Re: Painting a timber Mossie [Re: ] #69379
03/22/06 06:56 PM
03/22/06 06:56 PM
Melb. Aust
Trevor Offline OP
Trevor  Offline OP
Melb. Aust
Hi Gary,
Unfortunately, one of the Queens royal duties while she was here, was to allow me to use that very colour! At the time, I was not aware (and I don't think She was either) that there was another Botany Blue Mossie out there... MI 6 will be looking into this me thinks.
When I finally get my finger from where it appears to be and onto the digicam button, I will post some pics of my oxidised botany blue and once Varnished Mozzie!
I ripped out and got me a TCT blade pull scraper last night($18 @ Bunnings) and does that bad boy get the job done! It is a definate must have for the workshop. [color:"blue"] [/color]
And by the way - my boat was Botany Blue before yours, sail no. 321 - I might call it 'Methuselah'!
Cheers All
Mozzie 1828
Melbourne
Re: Painting a timber Mossie [Re: Trevor] #69380
03/27/06 06:54 AM
03/27/06 06:54 AM
Melb. Aust
Trevor Offline OP
Trevor  Offline OP
Melb. Aust
OK All,
So here are some pictures of the as yet un-named mozzie. I have mainly shown the deck as it is the worst of it. Varnish coverage is down around 20% - The rest is bare timber. The hull colour is good with barely a mark on it, apart from a dirty great chunk out of the Starboard bow (Laser gunwhales are mighty tough things ) that I did at the Yarrawonga Regatta a few years back.
More soon...
Mozzie 1828
Melbourne
Re: Painting a timber Mossie [Re: Trevor] #69381
03/27/06 06:56 AM
03/27/06 06:56 AM
Melb. Aust
Trevor Offline OP
Trevor  Offline OP
Melb. Aust
And another...
Mozzie 1828
Melbourne
Re: Painting a timber Mossie [Re: Trevor] #69382
03/27/06 07:42 AM
03/27/06 07:42 AM
Lake Bonney Yacht Club, Barmer...
Andrew_d Offline
Andrew_d  Offline
Hi Trevor
Those photos are a familiar site, having just gone through the same process on my boat. As a suggestion, since the decks are going back to bare timber give consideration to using a layer of light 2 oz fibreglass cloth between the epoxy coats. I was advised to do this on my decks, and the result is a very stiff frame with minimal extra weight (2oz/sq metre). The timber is more resistant to damage, and the finish very uniform. Attached photo shows cloth being laid over wet epoxy. Happy to provide more detail if you wish.
Andrew
Andrew DeLaine Mosquito 1734 Go-Nads II
Re: Painting a timber Mossie [Re: Andrew_d] #69383
03/29/06 05:21 PM
03/29/06 05:21 PM
Melb. Aust
Trevor Offline OP
Trevor  Offline OP
Melb. Aust
Probably a very worthwhile idea and I thought about doing it to the fore decks as they are reasonably light and flexible given the elbows and bums that are put on them. However - given the trouble I had re doing the glass on my foils a few years back, I am very reluctant. Getting the epoxy on smoothly was a nightmare, and it took about 10 sanding/epoxy attempts before the surface was flat enough and with no fibres poking through to be able to fill and paint. Timber I can do - Epoxy frustrates the hell out of me
Anyways - What was left of the varnish is all but gone and the hulls are looking ready to prime then fill. What I need now of course, is a nice fine Melbourne day with zero wind to start the spraying. I havent yet warned the GF that the grass will be white and blue for a while
Mozzie 1828
Melbourne
Re: Painting a timber Mossie [Re: Trevor] #69384
04/26/06 11:30 PM
04/26/06 11:30 PM
Melb. Aust
Trevor Offline OP
Trevor  Offline OP
Melb. Aust
Finally... Melbourne has given me a still day ! ANZAC day was deemed to be still enough to spray paint onto the ever-waiting Mozz. My GF decided that it would be funny to dress me in some paper overalls and take some pics while I got the job done. As soon as I get over the embarassment I will post one or two!
The primer/undercoat sure highlights imperfections, so its over to the filler, and then a wait again for another 'spray day'.
Mozzie 1828
Melbourne
Re: Painting a timber Mossie [Re: Trevor] #69385
04/27/06 04:51 AM
04/27/06 04:51 AM
Trevor,
You've now had enough time to get over the embrassemment. Where are the happy snaps ??
p.s. Your GF is certainly well trained to let you spend a whole public holiday dedicated to the Mozzie.
Mosquito 1814
Macka Mozzie
Re: Painting a timber Mossie [Re: Peter_Foulsum] #69386
04/27/06 07:34 AM
04/27/06 07:34 AM
Melb. Aust
Trevor Offline OP
Trevor  Offline OP
Melb. Aust
OK, laugh it up - Take particular note of the pink gloves!
Mozzie 1828
Melbourne
Re: Painting a timber Mossie [Re: Trevor] #69387
04/27/06 08:07 AM
04/27/06 08:07 AM
Trevor,
Looks completely normal to me . Must be a real pain keeping the bugs away . Not many warm/sunny/still days left to complete the task. Don't you have someone who can lend you a garage ?
Peter Foulsum
Mosquito 1814
Macka Mozzie
Re: Painting a timber Mossie [Re: Peter_Foulsum] #69388
04/27/06 11:52 PM
04/27/06 11:52 PM
Melb. Aust
Trevor Offline OP
Trevor  Offline OP
Melb. Aust
I actually have both a 3 side enclosed carport and a garage! Unfortunately, the Garage is so full of 'stuff' that it is a big job just protecting everything from overspray. The carport is where my ever-loving parks her car ('don't get paint on anything!')
Having said this - If it gets down to it - I will be using one of them just to get the job done!
Mozzie 1828
Melbourne
Re: Painting a timber Mossie [Re: Trevor] #69389
05/16/06 06:52 AM
05/16/06 06:52 AM
Trevor,
Any more progress with the painting ? It's been a bit quiet since your last posting.
Mosquito 1814
Macka Mozzie
Re: Painting a timber Mossie [Re: Peter_Foulsum] #69390
05/18/06 07:33 AM
05/18/06 07:33 AM
Melb. Aust
Trevor Offline OP
Trevor  Offline OP
Melb. Aust
It has been rather quiet, I have again been stopped by the weather. This time it has been too cold to lay the filler down! each night I have come home from work and it is either dark and raining or dark and too cold!
The filler wont set properly under 10 degrees. Having said that I have finished 1 hull to a standard that I am happy with (as a start) and it is ready for another undercoat. If it looks OK I will then topcoat it and its done. In the mean time when I cant paint I will be filling the other hull.
I suppose I wouldnt be the first guy to be screwing fittings on just prior to a race!
I still need to get the VYC insurance and club membership... Time is running out.......
Mozzie 1828
Melbourne
Re: Painting a timber Mossie [Re: Trevor] #69391
09/11/06 06:33 AM
09/11/06 06:33 AM
Melb. Aust
Trevor Offline OP
Trevor  Offline OP
Melb. Aust
Well, well, It has finally been warm enough to do stuff, the hulls were given an undercoat/seal ages ago, and it has been a slow battle to get it all faired and smooth...Well, at least I thought it was! I gave it the last undercoat on the weekend and it wasnt as smooth as it looked.
The Pictures don't really tell the story, it would have been easier just to replace the decks! - isn't hindsight great? They are actually quite smooth, but the photos faintly show that they have marks where the top ply layer was stuffed. It makes it look like the poor thing has stretch marks!
Anyway, top coat is ordered, and going on this weekend. If the decks come up pretty bad - I will, maybe, redo them next year.
My theory is its on the top, waterproof, and therefore sailable - Get it on the water!
Mozzie 1828
Melbourne
Re: Painting a timber Mossie [Re: Trevor] #69392
09/11/06 06:34 AM
09/11/06 06:34 AM
Melb. Aust
Trevor Offline OP
Trevor  Offline OP
Melb. Aust
And another Pic of both hulls...
Mozzie 1828
Melbourne
Re: Painting a timber Mossie [Re: Trevor] #69393
09/12/06 08:03 AM
09/12/06 08:03 AM
Trevor,
Great job. Love the Botany blue ! <img src="http://www.catsailor.com/forums/images/graemlins/smirk.gif" alt="" /> Are you going to have it completed for the start of the season ?
Peter
Mosquito 1814
Macka Mozzie
Re: Painting a timber Mossie [Re: Peter_Foulsum] #69394
09/12/06 06:07 PM
09/12/06 06:07 PM
Melb. Aust
Trevor Offline OP
Trevor  Offline OP
Melb. Aust
Hey Peter,
I certainly hope so - Depending when that actually is! It seems that my 'to be' local club sails throughout winter, so in theory they have already started without me
Oh, local club should be Sugarloaf SC when I get around to sending off the application...
Mozzie 1828
Melbourne
Re: Painting a timber Mossie [Re: Trevor] #69395
09/16/06 05:55 AM
09/16/06 05:55 AM
Melb. Aust
Trevor Offline OP
Trevor  Offline OP
Melb. Aust
OK, so one hull is now botany blue, the spray went on to the hulls well enough - and on everything else! I am going to have to get a better breathing mask tomorrow for the other side, I was nearly choking to death in there!. Looks great though!
Mozzie 1828
Melbourne
Re: Painting a timber Mossie [Re: Trevor] #69396
09/17/06 07:52 AM
09/17/06 07:52 AM
Trevor,
Is it totally Botany blue ? Any more pics so that we can show Guru Gary <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />?
Peter
Mosquito 1814
Macka Mozzie
Re: Painting a timber Mossie [Re: Peter_Foulsum] #69397
09/18/06 06:13 AM
09/18/06 06:13 AM
Melb. Aust
Trevor Offline OP
Trevor  Offline OP
Melb. Aust
Hi All,
The boat will be all botany Blue with, I think, white foils. I was going to leave the Transoms and rudder boxes white as well, but I had a bit of paint left in the gun, and, well...
Anyway, the decks will have non slip tape in either white or black and there will be the name (if I can decide on one) to break up the blue a bit.
I have attached a picture only got the decks left to do now! then pet her together!
Mozzie 1828
Melbourne
Re: Painting a timber Mossie [Re: Trevor] #69398
09/18/06 07:44 AM
09/18/06 07:44 AM
......together with who? <img src="http://www.catsailor.com/forums/images/graemlins/blush.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Re: Painting a timber Mossie [Re: Trevor] #69399
09/18/06 07:52 AM
09/18/06 07:52 AM
Trevor,
The name is obvious; "GO !!". It goes with the sail No. and with all the hard work you've put it it just has to be fast. <img src="http://www.catsailor.com/forums/images/graemlins/smirk.gif" alt="" />
Peter
Mosquito 1814
Macka Mozzie
Re: Painting a timber Mossie [Re: Peter_Foulsum] #69400
09/18/06 09:05 PM
09/18/06 09:05 PM
Melb. Aust
Trevor Offline OP
Trevor  Offline OP
Melb. Aust
OK so I put in an E ! It certainly changes the meaning doesnt it!?!
I never thought of 'GO', but it has given me a new line of thinking - Blast Off, or even countdown!
Mozzie 1828
Melbourne
Re: Painting a timber Mossie [Re: Trevor] #69401
09/19/06 07:10 AM
09/19/06 07:10 AM
Trevor,
You have to put the sail No. on the transom/rear beam to comply with regulations so why not "321 Blast Off" <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Peter
Mosquito 1814
Macka Mozzie
Re: Painting a timber Mossie [Re: Peter_Foulsum] #69402
09/26/06 03:52 AM
09/26/06 03:52 AM
Melb. Aust
Trevor Offline OP
Trevor  Offline OP
Melb. Aust
Hi All,
It is done! - Well it has a coat of paint on it, I have attached phots and it certainly looks shiny enough. There are quite a few dodgy bits, and will probably find a few more when I get it out into the sunlight. Learnt a few things though:
Bake the paint in the sun for a few days before you rest its weight on it - carpet isnt good for a new gloss finish.
Heat the both the hulls and the air around it to about 25-30deg C before painting.
With a direct drive compressor, run about 10 litres of air through it prior to painting as the compressor heats the air - the gradual heating evaporates the thinners unevenly giving an 'orange peel' effect.
On a windy day, air will bring dust into a closed shed - dont paint the decks with them facing upwards, lay the hulls on their side so dust etc cant settle straight on them.
Anyways, once the paint is hard, its on with the fittings and on to the water!!!
Mozzie 1828
Melbourne
Re: Painting a timber Mossie [Re: Trevor] #69403
09/26/06 03:53 AM
09/26/06 03:53 AM
Melb. Aust
Trevor Offline OP
Trevor  Offline OP
Melb. Aust
... I can see a reflection!!!
Mozzie 1828
Melbourne
Re: Painting a timber Mossie [Re: Trevor] #69404
09/26/06 04:45 AM
09/26/06 04:45 AM
Bendigo, Victoria, Australia
colmc Offline
colmc  Offline
Wow, what a great transition. It has been great to watch your progress.
Look forward to seeing the finished platform. <img src="http://www.catsailor.com/forums/images/graemlins/smirk.gif" alt="" />
Then the fully rigged boat. <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
Then that fully rigged boat on the water. <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
Hope to see you on the water.
Col
"Now What?"
Mosquito 1810
Re: Painting a timber Mossie [Re: colmc] #69405
10/23/06 05:46 PM
10/23/06 05:46 PM
Melb. Aust
Trevor Offline OP
Trevor  Offline OP
Melb. Aust
Time for another update:
The hulls are painted, have had the fittings put back on (some of them were left off) and are back out on the deck with the beams bolted on.
Tramp is to go on, trailer is being registered on Wednesday, and it would be ready to go. I need to get some vinyl lettering for the back beam and a name, but it will be sailable.
Sugarloaf has a new Mosquito!
Mozzie 1828
Melbourne
Re: Painting a timber Mossie [Re: Trevor] #69406
10/24/06 07:31 AM
10/24/06 07:31 AM
colmc Offline
colmc  Offline
Photo Please.
Col
"Now What?"
Mosquito 1810
Re: Painting a timber Mossie [Re: Jalani] #69407
10/24/06 08:08 AM
10/24/06 08:08 AM
Cape Town, South Africa
Steve_Kwiksilver Offline
Trust Mr. Alani to keep the spelling on the forums honest !
Love the L-O-C-O-M-O-T-I-V-E thread, John - just remember, yanks spell things the way they say them, based on his spelling I have a fair idea on his southern accent..
Don`t even ask him how to spell aluminium..
Steve
Re: Painting a timber Mossie [Re: Steve_Kwiksilver] #69408
10/25/06 07:25 AM
10/25/06 07:25 AM
Melb. Aust
Trevor Offline OP
Trevor  Offline OP
Melb. Aust
Nice one Col,
Ok, the platform is finished, the sail and mast needs inspection and we are done - the trailer has even been rebuilt and registered now. It was modified a bit from a Cobra that I had (now rotting away in my parents paddock after a main bulkhead breakage).
First sail day should be 11 November! (Damn, family things!).
Mozzie 1828
Melbourne
Re: Painting a timber Mossie [Re: Trevor] #69409
10/30/06 04:47 PM
10/30/06 04:47 PM
Melb. Aust
Trevor Offline OP
Trevor  Offline OP
Melb. Aust
You all may have noticed that I have settled on a name, one that gives scope for getting a newer boat and one that says 'He who dies with the most toys, wins!'
So given that, I thought an update in the boat saga was needed:
All new sheets,Halyards, (hell - call them ropes)apart from main and jib.
Signage ordered including a couple of very nifty Mossie logos for the transoms.
Trailer finished (widened) from Cobra 1750mm to Mossie 1790mm
And still on track for 11/11!
Mozzie 1828
Melbourne
Re: Painting a timber Mossie [Re: Trevor] #69410
10/30/06 10:23 PM
10/30/06 10:23 PM
colmc Offline
colmc  Offline
Hey Trevor, looking at your photo you appear to have lost some weight. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
I may be able to get to sugarloaf on 11/11. Diplomatic talks are under way. Do you know if they have enough water to race on? <img src="http://www.catsailor.com/forums/images/graemlins/confused.gif" alt="" />
If negotiations go well, I'll see you there.
Col
"Now What?"
Mosquito 1810
Re: Painting a timber Mossie [Re: colmc] #69411
10/31/06 06:31 AM
10/31/06 06:31 AM
Melb. Aust
Trevor Offline OP
Trevor  Offline OP
Melb. Aust
Yeah, I'm on a diet 'cause I dont have a spi for downwind!
Sugarloaf is at about 60% and still sailing - just gotta dodge the islands coming up out of the water!
I saw the pics of BeYC on the VYC site - there's not enough water to float a rubber duck...
Mozzie 1828
Melbourne
Re: Painting a timber Mossie [Re: Trevor] #69412
11/11/06 09:02 PM
11/11/06 09:02 PM
Melb. Aust
Trevor Offline OP
Trevor  Offline OP
Melb. Aust
Hooray!!!!
Its been in the water... and it didnt break, sink, or otherwise get damaged.
20 last minute checks before leaving home saw me only forget some mats to put on the ground (stones) and leaving late due to the crew's tennis, saw us late for the start and no lunch!
No wind saw us struggling to get over the start line and 3 hours of drifting saw us come last! But we were out there finally.
Mozzie 1828
Melbourne
Re: Painting a timber Mossie [Re: Trevor] #69413
11/11/06 09:03 PM
11/11/06 09:03 PM
Melb. Aust
Trevor Offline OP
Trevor  Offline OP
Melb. Aust
leaving shore..
Mozzie 1828
Melbourne
Re: Painting a timber Mossie [Re: Trevor] #69414
11/11/06 09:07 PM
11/11/06 09:07 PM
Melb. Aust
Trevor Offline OP
Trevor  Offline OP
Melb. Aust
Late for the start - Thats us off to the right. everyone else has started. At the end we were only about 50 metres behind 'Lemon Peel' another sloop Mossie, and about an hour behind the Taipans and Mossie with Spi.
Mozzie 1828
Melbourne
Re: Painting a timber Mossie [Re: Trevor] #69415
11/12/06 02:16 AM
11/12/06 02:16 AM
Sydney AUST
becjm Offline
becjm  Offline
Sydney AUST
That looks REALLY GOOD!!! great job.
It sure is hard sailing with no wind but thats prob typical. Spend forever painting a boat first chance to sail no wind.
---Ben Cutmore---
--MOSQUITO 1704--
Re: Painting a timber Mossie [Re: Trevor] #69416
11/12/06 06:59 PM
11/12/06 06:59 PM
Tim_Mozzie Offline
Tim_Mozzie  Offline
Where is this lake?
Tim Shepperd
Mosquito 1775
Karma Cat
Re: Painting a timber Mossie [Re: Tim_Mozzie] #69417
11/12/06 11:47 PM
11/12/06 11:47 PM
G
greyarea Offline
greyarea  Offline
G
Sugarloaf is up in the Christmas Hills, Eltham erea. Look at their website through the VMCA website Clubs that sail Mossies.
Re: Painting a timber Mossie [Re: becjm] #69418
11/13/06 03:28 AM
11/13/06 03:28 AM
Yeh, Paint job looks fantastic. Looking on the bright side you didn't break anything on the maiden voyage and had plenty of time to survey the setup and deck layout. <img src="http://www.catsailor.com/forums/images/graemlins/smirk.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/laugh.gif" alt="" />
Peter
Mosquito 1814
Macka Mozzie
Re: Painting a timber Mossie [Re: Peter_Foulsum] #69419
11/13/06 06:26 AM
11/13/06 06:26 AM
Melb. Aust
Trevor Offline OP
Trevor  Offline OP
Melb. Aust
The paint looks good... at a distance ! <img src="http://www.catsailor.com/forums/images/graemlins/crazy.gif" alt="" />
In a hurry, I had already left the shore before I realised there was no mast rotation control <img src="http://www.catsailor.com/forums/images/graemlins/blush.gif" alt="" />- had to make do with a shock cord, also a 2 to 1 downhaul isnt good enough. All things to fine tune in the next outing or 2.
It was a buzz out on the water all the same as I havent sailed in about 5 or 6 years. Cant wait for next weekend!
Mozzie 1828
Melbourne
Re: Painting a timber Mossie [Re: Trevor] #69420
02/19/07 06:40 AM
02/19/07 06:40 AM
Sydney AUST
becjm Offline
becjm  Offline
Sydney AUST
Hi There, IT's Ben in Sydney.
Just purchased a new mozzie, needs some TLC and Painting.
The boat is sail nbr 1547, thought I'd keep you in the loop with what I'm doing to it - photos attached... For those who live vicariously through this forum like I do.
By the way, people say fixing up a boat is a joy - I"M REALLY FEELING JOYFUL - NOT!
Regards, Ben.
---Ben Cutmore---
--MOSQUITO 1704--
Re: Painting a timber Mossie [Re: becjm] #69421
02/19/07 06:43 AM
02/19/07 06:43 AM
Sydney AUST
becjm Offline
becjm  Offline
Sydney AUST
But wait - there's more... I'm not too good at computer stuff so bear with me they may be jumbled.
---Ben Cutmore---
--MOSQUITO 1704--
Re: Painting a timber Mossie [Re: becjm] #69422
02/19/07 06:52 AM
02/19/07 06:52 AM
Sydney AUST
becjm Offline
becjm  Offline
Sydney AUST
What color? <img src="http://www.catsailor.com/forums/images/graemlins/confused.gif" alt="" />
I have a freind at dulux so I got some LUXATHANE 2pac for free just had to buy the hardner. <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
Problem is only had the choice of grey or BA blue <img src="http://www.catsailor.com/forums/images/graemlins/confused.gif" alt="" />they had been mixed incorectly so he said I could have both so ive got 8ltrs of both.
I thaught I would put it out there BLUE..... OR GREY.....
Just think of it as Reality tv program of sorts. <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
CHEERS BEN
---Ben Cutmore---
--MOSQUITO 1704--
Re: Painting a timber Mossie [Re: becjm] #69423
02/20/07 01:45 AM
02/20/07 01:45 AM
Sydney/Northern Beaches
Bandit Offline
Bandit  Offline
Go the Gray with blue poka dots.. or flowers.. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Re: Painting a timber Mossie [Re: Bandit] #69424
02/20/07 01:46 AM
02/20/07 01:46 AM
Bandit Offline
Bandit  Offline
What about rear end blue front end grey?
Sail 1635 Blue Tongue
Re: Painting a timber Mossie [Re: Bandit] #69425
02/20/07 02:06 AM
02/20/07 02:06 AM
ncik Offline
ncik  Offline
How about grey with blue graphics (pin stripe or something)
Re: Painting a timber Mossie [Re: ncik] #69426
02/20/07 02:52 AM
02/20/07 02:52 AM
Victoria, Oztralia
mattaipan Offline
mattaipan  Offline
Victoria, Oztralia
Ben
What shade of grey would you say, dark, light or somewhere in between?
The lighter the better, my personal view would be grey base with blue signage, but signage starting back at least at the main beam (no signage at bows, small pinstripe OK)
Regards
Re: Painting a timber Mossie [Re: mattaipan] #69427
02/20/07 04:41 AM
02/20/07 04:41 AM
Bandit Offline
Bandit  Offline
1cm checkers of blue and grey all over would be original and awsome !!
Just dont ask me to help mask it up. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Or how about a grey millitary look with 02 in big font on the bow. You could even wear the uniform with a white cap... <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Re: Painting a timber Mossie [Re: Bandit] #69428
02/24/07 04:12 AM
02/24/07 04:12 AM
Sydney AUST
becjm Offline
becjm  Offline
Sydney AUST
Thats just silly cam <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
So it is going to be grey.And im going to call it! THE AUZZIE MOZZIE <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
Has any one used that before?
Also some photos of the hulls ready to paint.
I made legs so it can be all sprayed at once. <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
---Ben Cutmore---
--MOSQUITO 1704--
Re: Painting a timber Mossie [Re: becjm] #69429
02/24/07 04:14 AM
02/24/07 04:14 AM
Sydney AUST
becjm Offline
becjm  Offline
Sydney AUST
Another angle
---Ben Cutmore---
--MOSQUITO 1704--
Re: Painting a timber Mossie [Re: becjm] #69430
02/24/07 04:52 AM
02/24/07 04:52 AM
Victoria, Oztralia
mattaipan Offline
mattaipan  Offline
Victoria, Oztralia
Hi Ben
Looks good, you must going flat out, your making me look lazy <img src="http://www.catsailor.com/forums/images/graemlins/smirk.gif" alt="" />
How did it come up after the long board? Pretty good by the looks of it! How much time on the wet n dry did you spend do you think? Just preparing myself for the same.
The stands look good, very good idea, might be another job for tomorrow <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" />
Anyway looks like your on target for the vic states, look forward to seeing the top coats on.
Regards
Re: Painting a timber Mossie [Re: mattaipan] #69431
02/24/07 10:44 PM
02/24/07 10:44 PM
Sydney AUST
becjm Offline
becjm  Offline
Sydney AUST
Hi Matt
Yeah been putting in the hard yards 2 nights up untill 2 30 in the morning <img src="http://www.catsailor.com/forums/images/graemlins/blush.gif" alt="" />
I dont think it will turn out that well. It needed allot of time whitch I dont really have.
Saying that it should look ok just not perfect.
It is definatly something you want no deadline on.
If the hulls were min weight I would put in the time.
It's getting sprayed today <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
I should have some photos later in the week <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" />
---Ben Cutmore---
--MOSQUITO 1704--
Re: Painting a timber Mossie [Re: mattaipan] #69432
02/26/07 05:31 AM
02/26/07 05:31 AM
Sydney AUST
becjm Offline
becjm  Offline
Sydney AUST
Hey guys
There painted <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
They turned out ok but it is best not to get closer than 3 meters then it looks really good <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Now just fit all the fittings <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
---Ben Cutmore---
--MOSQUITO 1704--
Re: Painting a timber Mossie [Re: becjm] #69433
02/26/07 06:05 AM
02/26/07 06:05 AM
Ben,
The paint job looks fantastic from the image. <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
I thought you said it was grey ! Looks more like white to me.
Peter
Mosquito 1814
Macka Mozzie
Re: Painting a timber Mossie [Re: Peter_Foulsum] #69434
02/26/07 06:11 AM
02/26/07 06:11 AM
Sydney AUST
becjm Offline
becjm  Offline
Sydney AUST
Thanks Peter
In real life they look grey.
It looks like we wont get to somers untill fri night Will is trying to get time off thanks anyway.
Still got heaps to sort out with the boat.
---Ben Cutmore---
--MOSQUITO 1704--
Re: Painting a timber Mossie [Re: becjm] #69435
02/27/07 01:44 AM
02/27/07 01:44 AM
Victoria, Oztralia
mattaipan Offline
mattaipan  Offline
Victoria, Oztralia
Hi Ben
Don't suppose you know the colour name of the paint, that looks really good, when you said grey, I pictured something darker, sort of looks like a colour boyer used to use, called dove grey, but I think thats a gelcoat colour name.
I see theres the holes in the bow for the kite, I assume you've done that yourself? or were they already there?
Again thats looks really good, even if you think its not perfect, it certainly likes the camera.
Regards
Re: Painting a timber Mossie [Re: mattaipan] #69436
03/04/07 05:27 AM
03/04/07 05:27 AM
Sydney AUST
becjm Offline
becjm  Offline
Sydney AUST
Hey guys
Got the mozzie out today. <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
Pics finished.
Matt I put the holes in for the spi <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />But thats for a later date. <img src="http://www.catsailor.com/forums/images/graemlins/frown.gif" alt="" />
---Ben Cutmore---
--MOSQUITO 1704--
Re: Painting a timber Mossie [Re: becjm] #69437
03/04/07 05:33 AM
03/04/07 05:33 AM
Sydney AUST
becjm Offline
becjm  Offline
Sydney AUST
Sorry about the sore necks <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
This ones around the right way <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" />
---Ben Cutmore---
--MOSQUITO 1704--
Re: Painting a timber Mossie [Re: becjm] #69438
03/04/07 05:45 AM
03/04/07 05:45 AM
Camden NSW
wildtoy Offline
wildtoy  Offline
Camden NSW
Ben
the boat looks nice in the water as well Ill post up some pics that were taken of us today tomorrow after I unpack my car(couldnt see out the back window <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />)
Re: Painting a timber Mossie [Re: becjm] #69439
03/04/07 05:46 AM
03/04/07 05:46 AM
Victoria, Oztralia
mattaipan Offline
mattaipan  Offline
Victoria, Oztralia
Hi Ben
Still looks pretty good. Looks like you've got the sail sorted out?
Regards
Re: Painting a timber Mossie [Re: mattaipan] #69440
03/05/07 03:27 AM
03/05/07 03:27 AM
Camden NSW
wildtoy Offline
wildtoy  Offline
Camden NSW
Hey Ben your boat sailing by itself <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
Re: Painting a timber Mossie [Re: wildtoy] #69441
03/05/07 03:33 AM
03/05/07 03:33 AM
Camden NSW
wildtoy Offline
wildtoy  Offline
Camden NSW
and another
Re: Painting a timber Mossie [Re: wildtoy] #69442
03/05/07 03:39 AM
03/05/07 03:39 AM
Camden NSW
wildtoy Offline
wildtoy  Offline
Camden NSW
The two mossies at kurnell, Im the one sailing away
Re: Painting a timber Mossie [Re: wildtoy] #69443
03/19/07 02:49 AM
03/19/07 02:49 AM
Adelaide South Australia
ratherbsailing Offline
Hi i have a question and that is how much paint was used to cover the hulls? thanks
Re: Painting a timber Mossie [Re: ratherbsailing] #69444
03/19/07 03:55 AM
03/19/07 03:55 AM
Victoria, Oztralia
mattaipan Offline
mattaipan  Offline
Victoria, Oztralia
Hi There
I am in the process of wet sanding the undercoat on my hulls, as long as the hulls are built reasonably fair (checking with batten along hull sides while fitting of the frames) you'll be able to do it with 4 litres of epoxy primer (Dulux Luxepoxy White) and you'll easily do it with 4 litres of top coat (I'm using Dulux Luxethane 2 Pac).
I spent probably 4 hours wet sanding one hull yesterday and I'm not finished yet, due to my sub standard spray painting skills, or more lack of knowledge regarding spray painting.
Regards
Re: Painting a timber Mossie [Re: mattaipan] #69445
03/19/07 04:54 PM
03/19/07 04:54 PM
Melb. Aust
Trevor Offline OP
Trevor  Offline OP
Melb. Aust
Hi There,
I used a litre of Northane epoxy Primer/undercoat on the decks and a big ding on one bow. Then used 2 litres of Northane epoxy (2 pack) plus thinners etc for 2 topcoats over the whole boat.
The top coat could probably have done with 3 coats but it was probably also my substandard spray skills that made it necessary.
Trevor
Mozzie 1828
Melbourne
Re: Painting a timber Mossie [Re: Trevor] #69446
03/22/07 04:09 AM
03/22/07 04:09 AM
anglesea,Victoria
C
corsair2 Offline
corsair2  Offline
C
anglesea,Victoria
hi there ,
I used wattyl sigma dur poly u 400, Used the old coat as primer filled and spot primed where required, Always when spraypainting be sure your first coat (mist) is a dry-ish coat,and that you give it 1/2 hr to tack off,then proceed with a more liberal coat . Remember to look closely after prime coat that ALL filler is coated and that there is no filler colour still showing ,if so re prime that area,or (mist coat) the blemished area's. Dark pigmented paints will cover better than light or off white colours. good luck, atomization is also a critical factor in good spray finishes.
corsair 2
Re: Painting a timber Mossie [Re: corsair2] #69447
03/22/07 05:32 AM
03/22/07 05:32 AM
Victoria, Oztralia
mattaipan Offline
mattaipan  Offline
Victoria, Oztralia
Hey Brett
Did you get my email? Give me a call tomorrow if you can, I can't find your number anywhere.
Regards
Re: Painting a timber Mossie [Re: Trevor] #69448
03/27/07 06:24 AM
03/27/07 06:24 AM
Camden NSW
wildtoy Offline
wildtoy  Offline
Camden NSW
What are peoples comments on spraying everdure on the timber hulls. Im not that far off hitting them with everdure so I just wanna know how people would apply it. Im after lightness to try and keep the weight down. I weighed the boat after fiberglassing the decks and they weigh 22 and 23.5kgs so I want to try to keep the hulls light.
Any comments?
Re: Painting a timber Mossie [Re: wildtoy] #69449
03/27/07 07:02 AM
03/27/07 07:02 AM
Victoria, Oztralia
mattaipan Offline
mattaipan  Offline
Victoria, Oztralia
Hi Will
I diluted my first coat 50/50 with the mix and thinners and used a roller, I started with one of those small foam rollers with the plastic centre, and I didn't put much thought into that idea, because the mix started melting the centre out, so then went to a metal cage type roller.
You use very little of this stuff all up, so weight isn't a huge issue with it. I went 50/50, then a little stronger and the final coat was full strength.
I bought 2 x 2 litre packs, because I had other things to use it on, and only used probably 2/3 of a 2 litre pack, plus thinners.
Can't comment on spraying it on, I never really considered it, I suppose with a roller it might penetrate into the veneer more??
Regards
Re: Painting a timber Mossie [Re: mattaipan] #69450
04/04/07 11:10 PM
04/04/07 11:10 PM
anglesea,Victoria
C
corsair2 Offline
corsair2  Offline
C
anglesea,Victoria
Hi Will, first coat should be ,like matt said ,but more 25% thinner in the mix. If using a spraygun open the fan right up to just below full width of sray capacity. Mist coat the hulls, so it is not a good cover. wait 30 mins or until just touch dry and then spray a wetter coat ,When spraying don't stop with the material still coming out. set your self up if possible to walk the entire length of the hull without stopping, start material feed (trigger) past where you want to begin and keep a steady arm as you walk down the hull,finishing past the end of the hull. Sand down when dry with 180 aluminium oxide sand paper,(white roll) repeat spraying proceedure again a little wetter coat this time .Full strength coat (no thinners) you may have to go a little slower this time. But not to slow(runs) This shuold leave a orange peel type finish to the paint work. wait 7 days for curing and a good buff with some water rubbing compound to take out orange peel and you can comb your hair in the finished product. Using less paint only means thinner coats . Less protection , the trade off is individual. just remember how much work you have already done .Even 5 litres of A&B polyurethane once dry does not weigh up to much at all. regards Brett.
Re: Painting a timber Mossie [Re: corsair2] #69451
04/26/07 08:01 AM
04/26/07 08:01 AM
Melb. Aust
Trevor Offline OP
Trevor  Offline OP
Melb. Aust
Hi All,
I thought I might post a near end of season update on how the "Toy" managed its first season back on the water.
It was presenting pretty well in its first couple of outings up at Sugarloaf, still trying to get the family into the missing Saturday afternoons, we got in only about 6 or 7 sails before the States loomed up.
The Starboard hull signage showed some signs of lifting. I have a graphic artist mate who printed it up for me on the vinyl that is used on cars. The states prompted a trip to Altona for a bit of sea and wave training for the crew. That trip did the signage in a bit more, showed a weakness in the rudders against jellyfish, and collapsed the beach rollers I had knocked up. Oh well.
For the titles I modified some old kick up rudders to fit the Toy and changed some rigging.
By the time we arrived at Somers I was missing some of the signage and sailed well (at least I thought so!!!)on the first day, the second day I had to pull out of the first race as both of the rudders had stripped their glass outers and split the timbers, so it was back to the originals which kicked out backwards at the wrong moment (I never worked out if there was a 'right' moment). <img src="http://www.catsailor.com/forums/images/graemlins/blush.gif" alt="" />
The last day showed up some tuning issues with the rig in heavy weather with a massive weather helm and the luff of the main being back winded. (cause and effect).
Final result - 7th... which sounds better than last <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Inspection of the platform the following week has shown the decks have gone soft in the ply with some cracks in the starboard hull running abeam near the front beam. The 'Toy' has stretch marks again!
All else is in good nick - boards, rudders and sails are on the soon shopping list, with another set of hulls in a few years.
The International 2 pack certainly has done the job with the only weakness coming from underneath the paint. The keel line is standing up to a bit of treatment on sand, mud etc and still looks good - Definately a recommender.
Hope everyone enjoys the winter fixing time, I know there are a few clubs with races over the coming months (Sugarloaf for instance), And I hope to see you all at the Sauna Sail!!! <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
I know there is a certain "Lemon" yellow mossie that is under repair at the moment - How about a story and some pictures please Peter...? <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" />
Mozzie 1828
Melbourne
Re: Painting a timber Mossie [Re: Trevor] #69452
05/11/07 12:42 AM
05/11/07 12:42 AM
Lake Bonney, SA
dkd Offline
dkd  Offline
Lake Bonney, SA
Guys, have read this post regularly with interest and wondered if maybe a pic of my mossie would add to the conversation.
Basically sealed with Everdue (originally) and has been treated with an equivalent product when the new decks were done. It was given to a friend of mine (who does car restorations and hotrods predominatly) to paint as it was/is far too cold to paint here.
It is painted in a 2 pack polyurethane and we won't go into brands but a high quality car paint.
I have been happy with it, looks sharp and has been durable, now she again has another lease of life, now to learn how to sail her again, especially after the A class.
DD
Re: Painting a timber Mossie [Re: dkd] #69453
05/11/07 04:38 AM
05/11/07 04:38 AM
Camden NSW
wildtoy Offline
wildtoy  Offline
Camden NSW
Hi Trevor,
saw your boat at the state titles and I must say you did a pretty good job on it(noticed the peeling sticker as well).
Im hoping my boat turns out as good as yours did when Im finished.
Pulled it apart after the vic states and still rubbing the boat back. I found out that the boat had a layer of primer followed with a layer of paint followed by a thick layer of primer and paint, thats why its taking for ever stripping the hulls.
When Im finished Im hoping the hulls will be alot lighter as well.
Hopefully be able to get a few pics up soon.
regards
william
nswmossie.com 1635
PS
Organising nsw state titles which is going to have a seperate sloop/cat class for the timber boats so all timber boat owners please consider.
Re: Painting a timber Mossie [Re: dkd] #69454
05/13/07 06:21 AM
05/13/07 06:21 AM
DD,
What was the price difference between painting with marine paint and automotive paint ? Are they similar in price and is the automotive paint equivalent in performance against things like beach (sand/abrasion)damage or stretching/breathing to avoid cracks appearing with deck flex or overall general abuse ?
Peter
Mosquito 1814
Macka Mozzie
Re: Painting a timber Mossie [Re: Peter_Foulsum] #69455
05/13/07 09:23 PM
05/13/07 09:23 PM
Lake Bonney, SA
dkd Offline
dkd  Offline
Lake Bonney, SA
Peter,
I have found that the dollar difference is marginal, depending of course on which paint you use, but generally just a tad cheaper to use Auto paint.
The big difference I find is in quality of finish, higher shine etc and is far more durable at least for our boats, and I have now either done or had done several boats, from Moths, thro' A's and our mossies(plural).
After all, auto finishes are designed to get wet, be left in the sun, range in temps from freezing to our Aussie sun (40+ C) etc etc.
Youngest's boat which took out "best presented" at last nationals was painted in auto finish but my mate....and after a hard season racing still looks the part.
Happy to give you paint details if you ever want them.
Ciao, David
Re: Painting a timber Mossie [Re: dkd] #69456
05/22/07 10:57 PM
05/22/07 10:57 PM
Rye, Melb, Vic, Australia
Peter_Lyons Offline
Peter_Lyons  Offline
The repair work to Lemon Peel is well underway and as always taking longer than I had hoped. The main tasks were to fix the fibreglass tape along the bottoms and to repaint large sections of the bows which had been repainted whith what appeared to be single pak over the existing epoxy. While stripping the paint from these areas I noticed quite a few hairline cracks in the rest of the paint and decided to do the whole mossie. I figured there was not a lot of point repainting half of the boat if the rest would need doing soon. The hardest area to strip was the deck which had a coarse mesh for grip. I think this had been applied after the first undercoat with following coats over the top. While it was hard to remove it did have good grip. I would like to replace it but am struggling to find what it is made of. I have tried fibreglass suppliers but it is not a glass product and I have tried spotlight but they have no material similar. I am keen if anyone knows what it may be?
I have almost finished stripping the hulls and will be on to filling and undercoats soon. I will try to add more reports as they happen.
Mossie 1822
The Unsent Letter
Put one foot after the other, cos that's how we roll.
Re: Painting a timber Mossie [Re: Peter_Lyons] #69457
05/23/07 05:39 AM
05/23/07 05:39 AM
Hi Peter,
my first Mossie had that Mesh on the decks no idea what it was, maybe Fibreglass Fly wire Mesh <img src="http://www.catsailor.com/forums/images/graemlins/confused.gif" alt="" />. Personaly I have found either sprinkling house hold Salt, through a seive on to uncured paint (cheap), or K&H Non Skid Latex paint commonly used on pooldecks etc. to be very good grip. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> Both of these do need occasional re coating though, as they are soft and wear away. But don't wear your gear or rear out <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />.
Re: Painting a timber Mossie [Re: ] #69458
05/25/07 06:50 AM
05/25/07 06:50 AM
Melb. Aust
Trevor Offline OP
Trevor  Offline OP
Melb. Aust
Hi Peter,
Lemon Peel is certainly looking 'peeled' now...
Its always a good sign when your back to the timber - It means that half the hard work is done - Filling and fairing up next, eh? That is what took the most time with the Toy due to the temperature being low enough the epoxy products werent curing properly. <img src="http://www.catsailor.com/forums/images/graemlins/frown.gif" alt="" />
As for the mesh - We had some rolled turf put in here a few years back, and the backing was a green plastic mesh that doesnt seem to break down in the sun. It was made up of squares about 3 or 4 mm per side. If you can find some it might work well. - There is plenty in my yard - just under the surface!!! <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Mozzie 1828
Melbourne
Re: Painting a timber Mossie [Re: Trevor] #69459
05/25/07 08:43 PM
05/25/07 08:43 PM
K
kats Offline
kats  Offline
K
The tape your are looking for is called skrim backing and is no longer avalible it hasent been for about 8 years it was great as deck grip
Re: Painting a timber Mossie [Re: kats] #69460
06/16/07 04:18 AM
06/16/07 04:18 AM
Simon C Offline
Simon C  Offline
Hi All,
I'm in the process of repainting my foils and rudders for the first time. (Timber)
The rope on the dagger boards appears to be held in place with epoxy filler or some such.
What's the easiest way to get it out?
Simon
Taipan AUS341
Re: Painting a timber Mossie [Re: Simon C] #69461
06/16/07 07:02 AM
06/16/07 07:02 AM
Victoria, Oztralia
mattaipan Offline
mattaipan  Offline
Victoria, Oztralia
If holes have been drilled in the boards and rope glued in, I'd just cut the rope off close to the board and re-drill the hole.
Regards
Re: Painting a timber Mossie [Re: mattaipan] #69462
06/16/07 06:44 PM
06/16/07 06:44 PM
Simon C Offline
Simon C  Offline
Thanks Matt,
I think that's the case so that's what I'll do.
Eveytime I get a coat of something off, there's something else underneath. It took 3 goes with paint remover and a lot of elbow grease to get back to the glass and from what I read here, now the real work begins. <img src="http://www.catsailor.com/forums/images/graemlins/tongue.gif" alt="" />
I'm glad I followed your referral and got Matt Kelly to do the hulls.
I have ever increasing admiration for the blokes that do it themselves. Where do you find the time? <img src="http://www.catsailor.com/forums/images/graemlins/confused.gif" alt="" />
Simon
Taipan AUS341
Re: Painting a timber Mossie [Re: Simon C] #69463
06/16/07 09:35 PM
06/16/07 09:35 PM
Victoria, Oztralia
mattaipan Offline
mattaipan  Offline
Victoria, Oztralia
Thats half the trouble nowadays, I've had take a job off the farm and now found I have very little time. But I've promised some mates I would have my boat on the water for start of 07/08 season, so I will have to make the time to finish off.
Best thing about being on the land is that we usually have a bigger than average tool box, and we are a bit isolated, so we tend to just do things ourselves anyway, which I enjoy.
And without actually seeing the repair job, I know that Matt Kelly would have done a great job. Good Bloke. I think he should be a Dad by now, will have to call him later and find out.
Regards
Re: Painting a timber Mossie [Re: mattaipan] #69464
06/17/07 05:57 AM
06/17/07 05:57 AM
Simon C Offline
Simon C  Offline
Right on both counts.
Nice fella and the repair is invisible. I'd happily use him again.(touch wood I won't have to for a while). As the saying goes, "you get what you pay for". It hurt the hip pocket a bit but "well worth" the pain.
Simon
Taipan AUS341
Page 1 of 5 1 2 3 4 5
Most Online3,694
2 hours ago
