Cattrax #69504
03/17/06 01:59 PM
03/17/06 01:59 PM
Northern Virginia
SoggyCheetoh Offline OP
Northern Virginia
I've got a slow persitent leak in one of the rubber tires on my Cattrax. I noticed that I can either buy just a replacement tire or a whole new tire/rim assembly. If I just order the tire, would I take it to an auto tire shop to have it replaced?
Alec
Alec D.
Pirates of the Chesapeake www.teampiratesofthechesapeake.com
Nacra20 1057 - Crew
F16 Viper 152 - Uni
Re: Cattrax [Re: SoggyCheetoh] #69505
03/17/06 02:07 PM
03/17/06 02:07 PM
Annapolis,MD
Keith Offline
Keith  Offline
Annapolis,MD
Alec - first make sure it's the tire. I had the same problem and it turned out that the valve stem had a crack.
Re: Cattrax [Re: Keith] #69506
03/17/06 02:11 PM
03/17/06 02:11 PM
Northern Virginia
Northern Virginia
Yeah, I thought it might be the valve stem as well considering that the metal part pulled right out of the valve stem the last time I tried to blow up the tire. However, when I was trying to break the tire seal around the rim, I noticed quite a lot of cracks in the rubber down near the rim. I ended up reglueing the metal guts of the valve stem back into the valve stem and reinflated the tire. Unfortunatley, the rate of deflation was unaffected by my valve stem repair job.
Alec D.
Nacra20 1057 - Crew
F16 Viper 152 - Uni
Re: Cattrax [Re: SoggyCheetoh] #69507
03/17/06 02:34 PM
03/17/06 02:34 PM
Small diameter tires are a booger to get on and off rims. I'd take it to a tire shop and ask them to leak test it. If it is leaking somewhere other than at the bead, they should be able to patch it for a reasonable price.
Re: Cattrax [Re: _flatlander_] #69508
03/17/06 02:39 PM
03/17/06 02:39 PM
St. Louis, MO,
Mike Hill Offline
Mike Hill  Offline
St. Louis, MO,
I'd take it to a tire shop and have them put a tube in it. Cost me like $25 to have this done.
Mike Hill
N20 #1005
Re: Cattrax [Re: SoggyCheetoh] #69509
03/17/06 02:39 PM
03/17/06 02:39 PM
Santa Barbara CA
sbflyer Offline
sbflyer  Offline
Santa Barbara CA
Maybe try some of the goop they make for fixing flats on mountain bike tires first, before coughing up the big bucks....
Re: Cattrax [Re: SoggyCheetoh] #69510
03/17/06 03:27 PM
03/17/06 03:27 PM
Sheesh...spray some soapy water on it to first fine the leak. A tire shop can put in a new valve stem for cheap. You can probably change the tire with a set of tire spoons for about the same as it would cost to pay someone to mount it....then you have the spoons for next time you need them.
Re: Cattrax [Re: Jake] #69511
03/17/06 04:54 PM
03/17/06 04:54 PM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
There's always Slime.
http://slime.com/tiresealant/
US Sail Level 2 Instructor
US Sail Level 3 Coach
Re: Cattrax [Re: hobie1616] #69512
03/18/06 09:12 AM
03/18/06 09:12 AM
South Florida & the Keys
arbo06 Offline
arbo06  Offline
While you are at it, refill with nitrofill for higher performance.
Eric Arbogast
ARC 2101
Miami Yacht Club
0 registered members (), 2,362 guests, and 286 spiders.
