R33 Trampoline issue HELP! #69871
03/22/06 11:35 PM
03/22/06 11:35 PM
SAIL Offline OP
SAIL  Offline OP
I am an owner of a R33 and recently my boat was parked at a dock overnight. When I returned the next morning I discovered a small round whole in my tramp. It appears someone got on the boat while smoking and either accidentally had ash drop onto the tramp or deliberately put a whole through the tramp with their cigarette. The edge of the whole are burnt and does not appear it will fray but still I am trying to figure out how to put a patch on it or something to prevent future problems. So does anyone have any ideas how to put a patch on or something like this without removing the whole tramp for a repair? So far I have talked with professionals related to this type of work and I have received no suggestions how to fix it.
Thanks,
Miles Moore
www.sail-s.com
Re: R33 Trampoline issue HELP! [Re: SAIL] #69872
03/23/06 04:29 AM
03/23/06 04:29 AM
If it's a cigarette burn size, then how about putting a brass eyelet (available from most hardware stores) in it? It won't look very pretty (depending on where it is of course) but it will protect the severed material strands which are probably sealed anyway by the burn.
You could treat it as a temporary repair and get a patch done properly when you next have the tramp off - or you could find a use for the hole!
Re: R33 Trampoline issue HELP! [Re: SAIL] #69873
03/23/06 07:15 AM
03/23/06 07:15 AM
you could put a grommett there, although doing that without removing the tramp would be difficult.
Re: R33 Trampoline issue HELP! [Re: SAIL] #69874
03/23/06 08:40 AM
03/23/06 08:40 AM
The hole will probably be OK if left as is because the heat melted the tiny ends of the fabric threads. Next time the trampoline is disconnected from the boat, you should take it to have a patched placed under the hole (most sail makers can perform this repair).
Re: R33 Trampoline issue HELP! [Re: Jake] #69875
03/23/06 09:20 AM
03/23/06 09:20 AM
Palm Beach Gardens. FL
palmwolfe Offline
palmwolfe  Offline
either accidentally or deliberately ?
That sucks, I know because I had the same thing happen to mine when left on the beach between race days.
It's been that way the last two summers with no problems, it seems it's melted around the edge.
It's a nice way to thank us for a rest on our boats.
Re: R33 Trampoline issue HELP! [Re: palmwolfe] #69876
03/23/06 10:11 AM
03/23/06 10:11 AM
St. Louis, MO,
Mike Hill Offline
Mike Hill  Offline
St. Louis, MO,
Is it a heat sealed tramp? Or is it standard stitched?
Mike Hill
N20 #1005
Re: R33 Trampoline issue HELP! [Re: Mike Hill] #69877
03/23/06 05:03 PM
03/23/06 05:03 PM
Atlanta
bvining Offline
bvining  Offline
Atlanta
In a moment of extreme stupidity while hungover, I put my small torch down on my tramp without turning it off and it melted a nice 1.5 inch hole in my tramp.
The good thing about a hole like this, and your cigarette hole, is the edges are welded together and shouldnt fray. You have at least the rest of the season before you should have it patched. A sailmaker should be able to fix it easily once its off the boat.
I wouldnt worry about it.
Bill
Re: R33 Trampoline issue HELP! [Re: bvining] #69878
03/23/06 07:23 PM
03/23/06 07:23 PM
Bless you Bill! I thought I was the only one who. . .
Re: R33 Trampoline issue HELP! [Re: SAIL] #69879
03/23/06 11:47 PM
03/23/06 11:47 PM
Mike Fahle Offline
Mike Fahle  Offline
I recommend hand sewing a repair by stitching from side to side across and around the burn hole. Just run the needle through the tramp weave openings until they are all filled in around the hole (alternate every other stitch one weave opening farther in from the hole than the closest one)and it will probably end up stronger than the original and not take long to fix. You can probably find some thread close in color and material to the existing tramp locally (yellow pages) or via Google. It probably will be fine if left alone and certainly would not be worth having it fixed professionally.
Are you sure it did not happen on the last scorching sail?! ;-)
Re: R33 Trampoline issue HELP! [Re: SAIL] #69880
03/24/06 12:28 AM
03/24/06 12:28 AM
US Western Continental Shelf
hobiegary Offline
hobiegary  Offline
I suggest making a sandwich patch of two 3" diameters of tramp material, or woven fiberglass cloth, and a "filling" of 3M 5200 sealant/glue.
Follow this up with two or three circles of circumferencial stitching around the burn hole, using a hand operated manual stiching needle and spool, available at W. Marine.
Allow 7 (seven) days for 5200 to cure. 4200 or fast cure 5200 is not as strong.
GARY
Santa Monica Bay
Re: R33 Trampoline issue HELP! [Re: hobiegary] #69881
03/24/06 08:43 AM
03/24/06 08:43 AM
the last thing I'd do is use 5200 on your trampoline.
You'll never get it off without destroying the tramp in the process.
It'll be fine until you can take it off to be professionally repaired.
Re: R33 Trampoline issue HELP! [Re: SAIL] #69882
03/24/06 02:07 PM
03/24/06 02:07 PM
Annapolis,MD
Keith Offline
Keith  Offline
Annapolis,MD
Thanks,
Miles Moore
Miles - I am utterly surprised at the answers you have received here. Don't use the boat again, ever! This has ruined the whole thing, and it is now completely unsafe. As it is completely ruined, you won't even be able to sell it. But, being the good guy that I am, I'll take the boat off your hands. Let me know when I can pick it up. It's a sacrifice for sure, but this is an example of the lengths I'll go to to help my fellow sailors. No thanks are necessary...
Re: R33 Trampoline issue HELP! [Re: Keith] #69883
03/24/06 05:07 PM
03/24/06 05:07 PM
Gainesville, FL 32607 USA
dacarls Offline
dacarls  Offline
Marine Goop will do a pretty good job of preventing ravelling, if the heat didn't. Goop seems to last for years, its flexible enough, you can thicken up the patch to suit. It can be removed with solvent if necessary.
Dacarls:
Re: R33 Trampoline issue HELP! [Re: MauganN20] #69884
03/24/06 10:17 PM
03/24/06 10:17 PM
hobiegary Offline
hobiegary  Offline
Exactly why I suggested it! You'll never get it off; it is tenacious.
GARY
Santa Monica Bay
Re: R33 Trampoline issue HELP! [Re: SAIL] #69885
03/25/06 04:06 AM
03/25/06 04:06 AM
SAIL Offline OP
SAIL  Offline OP
Thanks for all the greaat info its very appreciated. And Keith thanks for the offer but my family would kill me if I gave it away:) The R33 is totally awesome....
Re: R33 Trampoline issue HELP! [Re: SAIL] #69886
03/25/06 11:16 AM
03/25/06 11:16 AM
California!
Inter_Michael Offline
California!
On a formula 40 I was on...the owner replaced the stock tramp with a commercial grade spectra fishing net.
The advantage was: Strong, light, less windage, easy to repair. As it was a 'net' you could not rip it....HOWEVER....if you dropped something small...say goodbye....a couple of cell phones...and a shoe were victim once....other than that...it was great. Another advantage is that you can weave the bitter ends of the sheets thru the net...always keeps the 'deck' clear...
maybe an idea for you?
0 registered members (), 2,742 guests, and 394 spiders.
