| R33 Trampoline issue HELP! #69871 03/22/06 11:35 PM 03/22/06 11:35 PM |
Posts: 17 | I am an owner of a R33 and recently my boat was parked at a dock overnight. When I returned the next morning I discovered a small round whole in my tramp. It appears someone got on the boat while smoking and either accidentally had ash drop onto the tramp or deliberately put a whole through the tramp with their cigarette. The edge of the whole are burnt and does not appear it will fray but still I am trying to figure out how to put a patch on it or something to prevent future problems. So does anyone have any ideas how to put a patch on or something like this without removing the whole tramp for a repair? So far I have talked with professionals related to this type of work and I have received no suggestions how to fix it. Thanks, Miles Moore www.sail-s.com | | | Re: R33 Trampoline issue HELP!
[Re: SAIL]
#69872 03/23/06 04:29 AM 03/23/06 04:29 AM |
Posts: 1,382 Essex, UK | If it's a cigarette burn size, then how about putting a brass eyelet (available from most hardware stores) in it? It won't look very pretty (depending on where it is of course) but it will protect the severed material strands which are probably sealed anyway by the burn. You could treat it as a temporary repair and get a patch done properly when you next have the tramp off - or you could find a use for the hole!
John Alani ___________ Stealth F16s GBR527 and GBR538 | | | Re: R33 Trampoline issue HELP!
[Re: SAIL]
#69874 03/23/06 08:40 AM 03/23/06 08:40 AM |
Posts: 12,310 South Carolina | The hole will probably be OK if left as is because the heat melted the tiny ends of the fabric threads. Next time the trampoline is disconnected from the boat, you should take it to have a patched placed under the hole (most sail makers can perform this repair).
Jake Kohl | | | Re: R33 Trampoline issue HELP!
#69875 03/23/06 09:20 AM 03/23/06 09:20 AM |
Joined: Jul 2004 Posts: 176 Palm Beach Gardens. FL palmwolfe
Posts: 176 Palm Beach Gardens. FL | either accidentally or deliberately ? That sucks, I know because I had the same thing happen to mine when left on the beach between race days. It's been that way the last two summers with no problems, it seems it's melted around the edge. It's a nice way to thank us for a rest on our boats. | | | Re: R33 Trampoline issue HELP!
[Re: SAIL]
#69880 03/24/06 12:28 AM 03/24/06 12:28 AM |
Posts: 851 US Western Continental Shelf | I suggest making a sandwich patch of two 3" diameters of tramp material, or woven fiberglass cloth, and a "filling" of 3M 5200 sealant/glue.
Follow this up with two or three circles of circumferencial stitching around the burn hole, using a hand operated manual stiching needle and spool, available at W. Marine.
Allow 7 (seven) days for 5200 to cure. 4200 or fast cure 5200 is not as strong.
GARY
Santa Monica Bay Mystere 6.0 "Whisk" <--- R.I.P. | | | Re: R33 Trampoline issue HELP!
[Re: SAIL]
#69882 03/24/06 02:07 PM 03/24/06 02:07 PM |
Posts: 1,459 Annapolis,MD | I am an owner of a R33 and recently my boat was parked at a dock overnight. When I returned the next morning I discovered a small round whole in my tramp. It appears someone got on the boat while smoking and either accidentally had ash drop onto the tramp or deliberately put a whole through the tramp with their cigarette. The edge of the whole are burnt and does not appear it will fray but still I am trying to figure out how to put a patch on it or something to prevent future problems. So does anyone have any ideas how to put a patch on or something like this without removing the whole tramp for a repair? So far I have talked with professionals related to this type of work and I have received no suggestions how to fix it.
Thanks,
Miles Moore Miles - I am utterly surprised at the answers you have received here. Don't use the boat again, ever! This has ruined the whole thing, and it is now completely unsafe. As it is completely ruined, you won't even be able to sell it. But, being the good guy that I am, I'll take the boat off your hands. Let me know when I can pick it up. It's a sacrifice for sure, but this is an example of the lengths I'll go to to help my fellow sailors. No thanks are necessary... | | | Re: R33 Trampoline issue HELP!
[Re: Keith]
#69883 03/24/06 05:07 PM 03/24/06 05:07 PM |
Posts: 805 Gainesville, FL 32607 USA | Marine Goop will do a pretty good job of preventing ravelling, if the heat didn't. Goop seems to last for years, its flexible enough, you can thicken up the patch to suit. It can be removed with solvent if necessary.
[Re: MauganN20]
#69884 03/24/06 10:17 PM 03/24/06 10:17 PM |
Posts: 851 US Western Continental Shelf | You'll never get it off without destroying the tramp in the process. Exactly why I suggested it! You'll never get it off; it is tenacious. GARY
2,473
guests, and 301
