Best line for Spin Halyard? #70426
03/28/06 01:42 AM
03/28/06 01:42 AM
Central California
ejpoulsen Offline OP
Central California
What is the best line (type and size) for my spin halyard/tack/retrieval lines? I'm looking for low friction on the sails, snuffer, etc yet easy to grab. Also, my small spinlock needs to hold it well.
Please advise.
Eric Poulsen
A-class USA 203
Ultimate 20
Central California
Re: Best line for Spin Halyard? [Re: ejpoulsen] #70427
03/28/06 08:48 AM
03/28/06 08:48 AM
Atlanta
bvining Offline
bvining  Offline
Atlanta
I like the Marlow Racing 4 mil. Strip the cover when it has to go thru a snuffer or where it will contact the spin, it will wear a spin or a carbon snuffer, the cover is abrasive, but the core is nice a smooth.
It is easy to stip and bury the cover. If you dont know how, check out this link http://www.samsonrope.com/home/pdf/ClassII_Core_Dep_Strip_Inst.pdf
I've got this stuff on my spin halyard and the retreival line, and the halyard (same line, on a loop) and the tack line, works great, hold well in cleats.
Re: Best line for Spin Halyard? [Re: bvining] #70428
03/28/06 11:43 AM
03/28/06 11:43 AM
2017 F18 Americas Site
Dan_Delave Offline
Dan_Delave  Offline
Eric:
I use a Vectron 1/8 inch spliced into a Conception 1/4 inch (for the hands). You can buy it spliced from APS. Make sure the cleat is gripping down on the Conception. Vectron for windage and weight attaches to the Spinnaker Head.
Later,
Dan
Re: Best line for Spin Halyard? [Re: Dan_Delave] #70429
03/28/06 12:00 PM
03/28/06 12:00 PM
Charleston, SC
NCSUtrey Offline
NCSUtrey  Offline
Charleston, SC
Just get some New England V-100, either 3/16" or 1/4" depending on what size you like, and have it tapered (I can do it, and I have several hundred feet in stock). Rick sells it on this site. This is a great line! See attachment.
Trey
Re: Best line for Spin Halyard? [Re: Dan_Delave] #70430
03/28/06 08:09 PM
03/28/06 08:09 PM
Vancouver, BC
Tornado Offline
Tornado  Offline
Vancouver, BC
I've tried Flightline with the cover stripped off the section from above the mast cleat to the sail head. Stuff is very light and grippy, and more importantly loose part on tramp does not like to hockle up during hoists/douses. Have not been able to find it is 3/16 yet, which would be ideal.
Probably should not be letting this tip out to this site as Dan D. here surely doesn't need any help beating me more than he does already, but we've been using some super-duper glove technology that grips like nothing else. I'm seriously thinking of using only 1/8 dyneema core for the entire halyard/douse line because of these gloves. To find these gloves, just stop by your HomeDepot or similar on the drive home from work and find the large box of cotton gardening gloves with the palms dipped in (usually) blue latex. They smell like rubber bands and this will stay on your hands for a day after using. They are pretty much shot after a 3-4 races, but at $8 for a pack of 3 pairs, why not buy a whole mega box load! Can be worn over standard Ronstan gloves for even better performance/comfort.
P.S., they are also available in pink for the ladies (Dan's crewmate ;-)
Mike.
Mike Dobbs
Tornado CAN 99 "Full Tilt"
Re: Best line for Spin Halyard? [Re: Tornado] #70431
03/28/06 09:28 PM
03/28/06 09:28 PM
Dan_Delave Offline
Dan_Delave  Offline
Mike:
Thanks for the compliments.
Later,
Dan
Re: Best line for Spin Halyard? [Re: Dan_Delave] #70432
03/28/06 10:24 PM
03/28/06 10:24 PM
League City, TX
flumpmaster Offline
flumpmaster  Offline
League City, TX
Dan,
How does the skinny line work out on the douse?
Chris.
Re: Best line for Spin Halyard? [Re: Tornado] #70433
03/29/06 10:36 AM
03/29/06 10:36 AM
Hillsborough, NC USA
I
Isotope235 Offline
Isotope235  Offline
I
I've tried Flightline with the cover stripped off ... cotton gardening gloves with the palms dipped in (usually) blue latex.
Yes, Flightline looks like a really nice line. I haven't tried it personally, but it has a thin SK75(dyneema) core and a nice grippy polypropolene cover. It seems to have been designed with spinnakers in mind and I expect we'll see a lot of it around.
A while back, I bought a box of knitted kevlar gloves with nitrile coating on the palms & fingers (for handling cut glass). Maybe I should try those instead of my Harken gloves sometime...
Re: Best line for Spin Halyard? [Re: Isotope235] #70434
03/29/06 03:14 PM
03/29/06 03:14 PM
Dan_Delave Offline
Dan_Delave  Offline
Chris:
The crew never feels the 1/8 inch Vectron. The 1/4 inch Conception goes to the dousing holes in the spinnaker. The other reason, besides grip, I picked the Conception is the weight issue. While flying the chute the Conception is hanging on the spinnaker. If you think about it the bottom hole in the spinnaker for take down should be right at the place that you are grabbing the line to pull it down.
I tie an additional knot about 18 inches from the top hole, that stops at the bottom hole, so the dousing points do not enter the snuffer at the same time. This makes for a really nice entry, and subsequent exit, to the sock. I have an endpole snuffer and only pull by two points. That saves some wear on that light material as well. I could splice that last 18 inches and save some weight aloft but have not gone that far yet.
Later,
Dan
Re: Best line for Spin Halyard? [Re: Isotope235] #70435
03/29/06 07:04 PM
03/29/06 07:04 PM
Vancouver, BC
Tornado Offline
Tornado  Offline
Vancouver, BC
Re gloves...one of the biggest diff I notice with the very grippy gloves...hand fatigue is very much reduced. You don't need to squeeze much at all to hold line even under high loads...great for long off-wind spin sheet or upwind main sheet holding periods.
Mike.
Mike Dobbs
0 registered members (), 293 guests, and 44 spiders.
