New content for the webpage; Ventilation of hulls #7063
05/14/02 07:18 AM
05/14/02 07:18 AM
Wouter Offline OP
Wouter  Offline OP
Go to :
http://www.geocities.com/f16hpclass/tech_ventilation_of_hulls.html
And see how Kirt solve this problem with a piece of plastic bought at Wallmart.
Thanks for the pictures Kirt,
BTW, that mast rake and measuring mast bend articles should be up before 25 th of may.
Re: New content for the webpage; Ventilation of hulls [Re: Wouter] #7064
05/14/02 08:06 AM
05/14/02 08:06 AM
Ft. Pierce, Fl. USA
Seeker Offline
Seeker  Offline
Ft. Pierce, Fl. USA
Wouter, has Kirt mentioned anything about putting one of these ventilation elbows on the front access port? It would seem if you put a similar arangment on the front port (facing forward instead of aft) in would force air into the hull and acellerate the drying process considerably. You would haver a situation similar to what inboard power boats use to keep fumes out of the bilge.
If you had any distance to tralier you might be bone dry by the time you arrived home. Just a thought...
Bob
Re: New content for the webpage; Ventilation of hulls [Re: Seeker] #7065
05/14/02 11:08 AM
05/14/02 11:08 AM
Bob,
I have two computer muffin fans that I sit on rubber seals over my rear hatches and suck or blow air with the front hatches off. This is only good to accellerate drying when the boat is under cover or a fine day.
I like Kirt's sollution with the elbows for permanent ventilation.
Re: Ventilation of hulls- Front access ports? [Re: phill] #7066
05/14/02 01:13 PM
05/14/02 01:13 PM
Arkansas, USA
Kirt Offline
Kirt  Offline
Arkansas, USA
Phill, Bob-
Umm, are the "woodies" the only ones with front access ports? Haven't seen one on a U.S. Taipan yet-
Where are yours located Phill?
I have considered the fan idea- but even with a port at the front beam you have nearly half the length of the boat (the bow) without "flow-through", although it would be better than with only the rear port- My boat pretty much stays dry (as near as I can tell) while sailing so I use the ventilation ports (which are sold for Recreational vehicles- look in that section of the Wal Mart or at an RV dealer) mostly to allow the hulls to "breathe". You can't keep them dry anyway without constant dessication- Just go out late in the moring after a damp, cool night and feel the inside of your hulls- will be damp or dripping.
Kirt
Kirt Simmons Taipan #159, "A" cat US 48
Re: Ventilation of hulls- Front access ports? [Re: Kirt] #7067
05/14/02 03:15 PM
05/14/02 03:15 PM
Kirt,
The earlier glass boats also had front ports.
From memory:-
The front ports if installed according to plan are centred 340mm back from the main beam and 145mm in from the inside gunwale. Just right so you can get you hand (up to and including elbow) in to do up the beam bolts.
The fact the section forward does not get air blown through has always concernd me and at one stage I was even looking at building in a breather pipe from the front port that I could blow air through. I finally decided I was being paranoid and dropped the idea.
0 registered members (), 2,723 guests, and 296 spiders.
