| Re: Mainsheet blocks
[Re: mmiller]
#70759 04/07/06 05:27 PM 04/07/06 05:27 PM |
I agree with Matt on this one. A bit overkill to it otherwise on the H16.
[Re: Wouter]
#70760 04/07/06 09:48 PM 04/07/06 09:48 PM |
Posts: 306 St. Louis, MO | You don't want to over-complicated an otherwise simple boat. You may have heard of the KISS axiom: Keep It Simple Stupid.
When you add complicated parts to a mechanism you are asking for it to fail at an inopportune time. Unless you really need the "upgraded" feature it is not worth the cost or risk of failure.
I understand the need to have neat gadgets. I am a techie myself.
Nick
Current Boat Looking for one
[Re: hobienick]
#70761 04/08/06 10:11 AM 04/08/06 10:11 AM |
Posts: 321 Albuquerque NM | Like I said, I only needed to think on this for a very short time. I live by KISS (most of the time). This time I will keep it simple also.
Thanks for all of your input. Sam
[b] Sail Like you have a Pair
[Re: RickWhite]
#70762 06/29/06 05:41 AM 06/29/06 05:41 AM |
Joined: Apr 2005 Posts: 53 The Netherlands, Europe flying_dutchman
Posts: 53 The Netherlands, Europe | Have to get new blocks and sheet as mine got lost/stolen??? Lent some Nacra F18 blocks which I had to modify (too high...) Have seen so many reactions already that I'm rather confused. Sailing quite often alone and with less mast rake (like a neutral steering behaviour as I only got 2 hands...) also with rather much wind the 6:1 is on the edge. Although I like to think I'm having quite a physical condition I have my limits when sailing for a couple of hours.. Read your (Rick White) comment stating you like the 8:1 option with a lite mainsheet. See quote below: I think the Ratchamatics are awesome myself and use them on every boat I have had since they came out. On my F16 I am using the 8:1 Ratchamatic with 1/4" mainsheet. Sounds small,but with the 8:1 purchase it is easy to sheet and it also runs out very well when you ease the sheet.
Might enable to sail longer and with les/no use of the clamps? Checked some sites but cannot find the 8:1 blocks you are refering to. I assume both blocks have 4 sheaves on a row (low profile required) and the lower with cleat as well. Do you use the 1/4" mainsheet for the full length or id you keep the last 3 m' (12') the original thickness? And what length do you use? Can somebody (Rick ??) give me some help? Thanks in advance / greeting from Europe Eddie #99173 [1992]
Happy sailing from The Netherlands!
Eddie
Hobie 16 (1992) # 99173 & CT11 - with spi
[Re: RickWhite]
#70764 06/30/06 03:19 PM 06/30/06 03:19 PM |
Joined: Jun 2006 Posts: 110 Northern California, USA RyanMcHale
Posts: 110 Northern California, USA | Hey everybody, I have a Hobie 14 Turbo that still has the old 4 to 1 Seaway blocks, and when it's really blowing I have a hard time getting block to block (must be getting old). So, I'm thinking about a new sheeting system, my question is what should I go with, find a sixteen owner who is upgrading their 5 to 1 system and buy their old Seaways (cheapest), buy a new 5 to 1 low profile Harken setup, or buy a new 6 to 1 low profile Harken setup (most expensive)? Maybe try what Rick was talking about and go with 1/4" or maybe 5/16" on a 6 to 1 setup would be the best or would 6 to 1 be overkill on a 14? <img src="http://www.catsailor.com/forums/images/graemlins/confused.gif" alt="" /> Thanks for any advice.
Ryan McHale Hobie 14 (battened jib)
[Re: Mac05]
#70766 07/07/06 01:17 PM 07/07/06 01:17 PM |
Posts: 321 Albuquerque NM | Sam - I think the 194's are easier to adjust the angle on. From Matt's previous post: Get the H194 lower and the Carbo upper H2640. Standard on new Hobie 16's.
We do not recommend the Carbo ratchet lower. It is a PITA to adjust the jaw angles.
After this last weekend, I have to strongly dissagree with the PITA, It took me all of 4 minutes to adjust the angle the first time and maybe 3 minutes the second time on the 2630. I did have to do it twice because the first time everybody suggested go 3 notches, when 2 was really enough. Yes they are more expensive then the non-carbo, but the ratchmatic is real nice. and with a becket on both top and bottom, I could rig it 6,7 or 8(w/added pully):1 Right now it is 7:1 and again, 46 or 48 feet of 9mm red Maffioli Swiftcord Very very happy. Sam
[Re: TEAMVMG]
#70767 07/25/06 07:24 AM 07/25/06 07:24 AM |
Posts: 53 The Netherlands, Europe | As my complete mainsheet go lost / stolen last year I’m still using the set of a fellow catsailer. Although a great lead indeed I’m getting a little confused now. I’ll try to explain:
My 1992 H16 is more or less standard (I think..). Mats rake I adjust reluctantly. In 5-th position (from below) the steering is neutral which I think is a major advantage – especially when sailing alone. In 4-th or even 3-rd hole she will immediately turn into the wind when releasing the joystick. Added bushes (Hobie Tiger) and new rods in the rudders so play is close to zero now. Rudder blades are in max forward position. But even in 5-th hole I manage to sail “block to block” quite easily – with a 6:1 configuration. How should I be able to use a 8:1 set (Ricks’ recommendation) as I don’t have enough height available. Is my main sail worn out? I doesn’t look that way. I connect both blocks – to traverse ar and beam – with shackles only, to keep profile as low as possible.
By the way: Mast rake is still a tricky business for me anyway. Maybe I am not sensitive / skilled enough but tacking is not my favourite course. And when the nose dips you’ll loose in most cases anyway. But isn’t that half the thrill?
Hope somebody can give me some advice.
Eddie The Netherlands # 99173
Eddie
2,475
guests, and 285
