Re: Traveler part for Inter 20 [Re: SteveT] #71539
04/09/06 11:49 AM
04/09/06 11:49 AM
Hey, while we're sort of on the subject. Why does the N20 traveler line have a twin tail and ties to two different spots on the back beam?
Re: Traveler part for Inter 20 [Re: PTP] #71540
04/09/06 12:43 PM
04/09/06 12:43 PM
Many boats do this.
It is a better way of ensuring the traveller is held in the centre when under load upwind. A single line tends to allow the traveller to move slightly off centre.
Re: Traveler part for Inter 20 [Re: SteveT] #71541
04/09/06 01:32 PM
04/09/06 01:32 PM
Remeber that when you torque the bolt with the scredriver it could possibly break the tape on the end of the batten/tiller extension, so try an aluminum piece that is "u" shaped to fit the wrench into.
Re: Traveler part for Inter 20 [Re: ] #71542
04/09/06 02:09 PM
04/09/06 02:09 PM
I've fitted all my traveller tracks by bolting the track to the beam and taping a ring spanner to a batten.
I put a small piece of tape in the ring and press the nyloc nut in. Then sit a washer on top and duralac on top of the washer to prevent a corrosion between the beam and washer.
It takes a steady hand some patience and an assistant to make this happen.
The invent of the electrc screw driver was a godsend for this job.
BTW:- I've just taped the spanner to the batten with masking tape and never had a problem.
0 registered members (), 20,211 guests, and 491 spiders.
Yesterday at 04:54 AM
