| Re: Traveler part for Inter 20
[Re: PTP]
#71540 04/09/06 12:43 PM 04/09/06 12:43 PM |
Posts: 1,449 | Many boats do this. It is a better way of ensuring the traveller is held in the centre when under load upwind. A single line tends to allow the traveller to move slightly off centre.
[Re: SteveT]
#71541 04/09/06 01:32 PM 04/09/06 01:32 PM | Anonymous
| Anonymous
Unregistered | Remeber that when you torque the bolt with the scredriver it could possibly break the tape on the end of the batten/tiller extension, so try an aluminum piece that is "u" shaped to fit the wrench into. | | | Re: Traveler part for Inter 20
[Re: ]
#71542 04/09/06 02:09 PM 04/09/06 02:09 PM |
Posts: 1,449 | I've fitted all my traveller tracks by bolting the track to the beam and taping a ring spanner to a batten. I put a small piece of tape in the ring and press the nyloc nut in. Then sit a washer on top and duralac on top of the washer to prevent a corrosion between the beam and washer. It takes a steady hand some patience and an assistant to make this happen. The invent of the electrc screw driver was a godsend for this job.
BTW:- I've just taped the spanner to the batten with masking tape and never had a problem.
21,945
guests, and 382
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online23,979 Sep 24th, 2025 | | | |
