| Sheets -- What line to get? #7166 05/20/02 12:01 AM 05/20/02 12:01 AM |
Posts: 283 | It's time to get new mainsheet and jibsheet line for my Hobie 20. The yale light I have is quite worn, and has gotten faded, stiff, and stubborn.
So what would be the good line choice? Why do you like what you have?
I don't like the fuzzy stuff, and am thinking I want something that doesn't get water logged when wet.
Thanks for your input!
Tim J.
Tim D. Johnson
Hobie 20 #690
Bald Eagle Yacht Club, Fleet 52
www.beyc.org | | | Re: Sheets -- What line to get?
[Re: hobie541]
#7167 05/20/02 09:59 AM 05/20/02 09:59 AM |
Posts: 1,459 Annapolis,MD | Time for NEW Yale Light! At least when new it doesn't soak up water, runs nice, and resists tangles. It does wear, though, like I suspect everything does. Just replaced my mainsheet's worn Yale Light (was soaking up water, among other things) with some new, back to normal!
[Re: Keith]
#7168 05/20/02 10:15 AM 05/20/02 10:15 AM |
Posts: 283 | Yep, you may be right! But, I just figured I should be open to new possibilities.....
Tim J.
Tim D. Johnson
Hobie 20 #690
[Re: hobie541]
#7169 05/20/02 11:37 AM 05/20/02 11:37 AM |
Joined: Jul 2001 Posts: 397 Burlington, Vermont USA Kevin Rose
Posts: 397 Burlington, Vermont USA | Tim,
I just replaced my sheets with Yale Vizzion. Too early for a verdict on wear, etc., but it feels good, runs through the blocks well, and doesn't soak up water. (The line came highly recommended by other sailors.)
Kevin Rose
N6.0na #215
Lake Champlain (New England's "west coast")
Burlington, Vermont
[Re: Kevin Rose]
#7170 05/21/02 12:03 AM 05/21/02 12:03 AM |
Posts: 283 | So all of your sheets are now Yale Vizzion?
Good and light I presume, so as not to weigh down a jib in light air?
Thanks,
Tim J.
Tim D. Johnson
Hobie 20 #690
[Re: CMerrell]
#7172 05/21/02 08:57 AM 05/21/02 08:57 AM |
Joined: Jun 2001 Posts: 292 Long Island, NY Ed Norris
Posts: 292 Long Island, NY | Hi Guys,
A little advice here? Basics for us semi-hardcore sailors struggling to make the jump to get "real gear" :-)
My new Smyth pentex laminates arrive in a couple o' weeks, and using waterlogged old sheets on 'em just gives me the willies.
1. Where do you buy this "yale [xxx]" brand of rope (never saw it in West Marine)
2. Price per foot?
3. Can you taper it? How?
4. Is it easy to grip, or has that atribute been traded off for low friction in the block/low absorbancy? Do you guys recommend "grippy" gloves?
Thanks,
Ed Norris
Sail Fast,
Ed Norris
[Re: hobie541]
#7173 05/21/02 10:07 AM 05/21/02 10:07 AM |
I've gone with the Vizzion on both main and jib.
The weight on Yale Vizzion is a bit heavier than the YaleLight (3/8 inch line = 4.1 lbs per 100 ft vs. 3.1 lbs). I was concerned about going too light and not having enough weight to flick the sheet out of the cleat. The Yale Vizzion is about the same weight as the Samson Trophy Braid (commonly used fuzzy cover double braid) when dry, but the Trophy Braid soaks up a lot of water.
Kevin Rose
N6.0na #215
Burlington, Vermont
[Re: Ed Norris]
#7174 05/21/02 10:07 AM 05/21/02 10:07 AM |
Posts: 5,590 Naples, FL | Ed, These days, prices are coming down to downright reasonable for cored lines, which I have and recommend due to their ability to be tapered (weight savings), and the outer covering can almost be customized to your grip needs. The tapering also allows you to use smaller blocks, saving additional weight. I replaced my mainsheet (I-20) with tapered spectra core from www.layline.com (I think that's the site). With the new blocks, I saved substantial weight on the mainsail. I chose a covering that does not absorb water, and was relatively easy to grab (course, I still use Obrien waterski gloves for padding). We were impressed enough by the weight savings to replace the spinnaker sheets as well with a similar cord and tapered it, too. It ain't cheap, so if you're a guy who parks his boat on the beach and ignores it for the weeks between sailing, stay with the heavy stuff. If you want to get out and race, and take pretty good care of your boat, drop the extra $$ for the "good stuff". I hate to admit it (being the tightwad that I am), but it does make things a little easier. Just some thoughts.
[Re: Ed Norris]
#7177 05/21/02 12:27 PM 05/21/02 12:27 PM |
Posts: 397 Burlington, Vermont USA | Ed, 1. Where do you buy this "yale [xxx]" brand of rope (never saw it in West Marine) West Marine is limited mostly to the New England Ropes selection. I bought the Yale Vizzion from Annapolis Performance Sailing. 2. Price per foot? Pricing on the Vizzion 5/16 (jib sheet) was $1.14/ft, and 3/8 (mainsheet) was $1.37/ft (about 30 cents a foot cheaper than Layline's pricing). 3. Can you taper it? How? Yalelight is strippable, but I don't believe you can with the Vizzion. 4. Is it easy to grip, or has that atribute been traded off for low friction in the block/low absorbancy? Do you guys recommend "grippy" gloves? Vizzion has a polyester cover vs. a polypropylene cover on the Yalelight. One of the reasons I went with the Vizzion is because it has a good "hand". While I do like the feel of the fuzzy polyester cover on Samson's Trophy Braid, I wasn't thrilled with the other characteristics of the line, especially the way it absorbs water, leaving the jib sheets pretty heavy. I would highly recommend gloves. Either Ronstan or Harken. My personal preference is the 3-finger model (with the half-finger only on the index finger). I used to wear the half-finger gloves and would lose too much skin on the tips of my fingers.
Kevin Rose
N6.0na #215
Burlington, Vermont
[Re: Kevin Rose]
#7178 05/21/02 08:32 PM 05/21/02 08:32 PM |
Posts: 292 Long Island, NY | Thanks, Kevin!
I currently use cheap gloves, but have my eye on the "Black magic" ones from RonstanorisitHarken in Murrays.
I'll be ordering the VIzzion.
How do you 'strip' it? I'm planning to get some nice fat stuff and taper the part that usually lives inside the blocks, and keep the stock blocks. Reason is, my left hand's been acting up lately... tight fist ain't what it used to be.
Thanks again,
Ed Norris
Sail Fast,
Ed Norris
[Re: Ed Norris]
#7180 05/21/02 09:15 PM 05/21/02 09:15 PM |
Better check about tapering the Vizzion. I'm not sure if it's possible. (It is possible with YaleLight.)
Kevin Rose
N6.0na #215
Burlington, Vermont
| | | Duh. Reading your post while awake this time...
[Re: Kevin Rose]
#7181 05/21/02 09:26 PM 05/21/02 09:26 PM |
Posts: 292 Long Island, NY | ... I see that you said that.
But how do you actually strip it?
Ed
Sail Fast,
Ed Norris
[Re: Kevin Rose]
#7182 05/21/02 11:07 PM 05/21/02 11:07 PM |
Posts: 283 | Hey all,
I ended up getting a whole bunch of Yale Light from Layline at such a killer deal, that it really eliminated any other considerations.
If you go to their site, and do a search for yale light, you'll run across any "tails" that they have for sale at rock bottom prices.
I got 80' of 3/8" green yale light for $47, a bit less than 60 cents per foot! I tried to order 100 feet of Yale Vizzion for an absolute killer deal of $32, or 32 cents per foot, but after placing the order last night, they wrote to me this morning, and said they were out of stock, and that the web site was wrong.
Anyway, I called them and told them I was looking for 5/16" line for the jib. The lady I talked to said she would check in back to see what other tails they had. She came back and informed me that they had 80 feet of red, and 50 feet of blue, and that they'd sell it for 40 cents a foot if I remember right. Can't remember exactly, but it was such a great deal that I bought it all, figuring that if I didn't use it, I could find someone who would!
Anyway, keep an eye on that Layline bunch, you never know what kind of deal you might get!
Sea ya,
Tim J.
Tim D. Johnson
Hobie 20 #690
www.beyc.org | | | Re: Duh. Reading your post while awake this time...
[Re: Ed Norris]
#7183 05/22/02 10:15 AM 05/22/02 10:15 AM |
Posts: 833 St. Louis, MO, | Ed,
Be careful about splicing line together for a mainsheet. I've tried it a few times and I've never been happy with the result. The problem is that no matter where you put the splice you end up with it in the wrong place at one time or another. It seemed like when I was going upwind I always ended up holding the small line anyway. If you change your mast rake you will change where the splice should be because your blocks will be closer or farther apart. I absolutely hate having the splice right where I'm sheeting in and out downwind because it tends to stick a little at times. Anyway I just wanted to let you know this as to save you a little time and money if I could. I use some old Lionbraid which I love but I'm just about to switch it out for some 3/8 Yale Light which came stock on my H20.
Good Luck with you decision.
Keep One Hull Flying,
Mike Hill
H20 #791
Mike Hill N20 #1005
| | | Re: "Stripping" line vs. Splicing
[Re: Mike Hill]
#7185 05/22/02 10:55 AM 05/22/02 10:55 AM |
Posts: 292 Long Island, NY | I heard "from a guy on the beach" you can take one long length of line, and partially remove some of the core material, especially the fibers included for bulk only, from the portion of the line which resides in your blocks. Is this what Kevin's referring to as "stripping"?
Ed Norris
Sail Fast,
Ed Norris
1 registered members (vasil),
521
guests, and 47
